Espritmodel.com Heli Air
Old Jun 14, 2012, 07:43 AM
jamiedg's Avatar
United Kingdom, Scotland, D & G
Joined Apr 2012
DH 9116 Tx howto Reverse Rudder settings - v911 can fly with this Tx
Hello, since the normal DH9116 thread is getting massive thought it best to start a new thread, hope somone can help.
Anyone know if its possible to swap the left/right rudder control on the DH 9116 Tx.
I've looked at Stormforce's below excellent guide but cant get any expected changes.
http://www.rcgroups.com/forums/member.php?u=384746
Reasons to reverse ?
1) manged to bind the 9116 Tx to my v911 heli, all controls work but rudder needs swapped.
2) The new WLToys Ladybird quadcopter bnf $52 mentioned below works with the v911 Tx.
http://www.rcgroups.com/forums/showthread.php?t=1658847
If I can get the rudder swapped there is a good chance the 9116 Tx will fly the Quadcopter also.
Others with a 9116 Tx may find this interesting also.
At worst a pot change switch will do the stuff but it would be nice to do this via the Tx menu settings.
jamiedg is offline Find More Posts by jamiedg
Old Jun 14, 2012, 11:53 AM
jamiedg's Avatar
Joined Apr 2012
I've managed to reverse the rudder.
Basically navigate to the RUDD REV area then press up/down (left side) to change
displayed "AEU" to read "NOA".
I can now control v911 with the 9116 Tx !
Update:
Buttons to press to rev rudder:
Menu hold - display Mode 2
Menu
Menu
Menu - display ELEV REV
Select
Select
Select - display RUDD REV
UP or DN to change AEU to NOA
Menu hold - to save
Oh, also needs the Aileron control (right cyclic) reversed.
Buttons to press to rev Aileron:
Menu
Menu
Select - display AILE REV
Menu hold - to save
Sorted v911 can now fly fine with DH 9116.
So new WLToys Ladybird quadcopter should now also fly with DH 9116 Tx
Will post back when this is confirmed in about 3-4 wks time.
Note: D/R rates can also be changed using samilar process.
Old Jun 14, 2012, 12:09 PM
Crash and learn
United States, PA
Joined Dec 2011
Extraordinary.
Test fly the V911 with the 9116 transmitter. I didn't think it would be that easy.
Ribble is offline Find More Posts by Ribble
Old Jun 14, 2012, 04:23 PM
jamiedg's Avatar
Joined Apr 2012
Yes v911 flys fine with the 9116 Tx, D/R rates can also be changed to make the rudder less snappy.
Old Jun 15, 2012, 01:29 AM
Closed Account
Joined Nov 2011
You might also find it better to change the ELEV, AILE and RUDD EPA to 120%. I found I had to increase them from 100% to get the same response as I was getting with the 9958 tx.
stormforce is offline Find More Posts by stormforce
Old Jun 15, 2012, 06:47 PM
Finding Creative Ways To Crash
RCCrashTestDummy's Avatar
Joined Jun 2012
Very Cool!
I was wondering about this but was afraid to ask for fear of being beaten for my ignorance.
-Pat
RCCrashTestDummy is offline Find More Posts by RCCrashTestDummy
Old Jun 15, 2012, 06:52 PM
Closed Account
Joined Nov 2011
As they say, "there are no stupid questions".
If you don't ask, you don't learn.
Old Jun 15, 2012, 07:16 PM
Closed Account
Joined Nov 2011
I wish there was more adjustment you could add to the EPA settings, as I find 120% still isn't enough for my liking. It only matches the 9958 tx, but doesn't go beyond it.
I did some modifications to the throttle stick also, to remove the "ratchet" feel of the throttle stick.
Open up the 9116 tx, and find the shiny metal leaf spring on the throttle stick. Remove it and sand down the ridges on the curved part of the throttle stick (not totally, just enough to take the edge off the ridges, as you'll still need some grip). Then flatten the ridge on the leaf spring and slip a few layers of heatshrink tubing over the end of the leaf spring where it contacts the curved part of the throttle stick. Mildly flatten out the section of the leaf spring where it screws into the housing to increase the normal tension on the throttle stick. Re-assemble the mechanism and fine tune the spring tension by tightening the screw to suit your preference.
Or, alternately, replace the leaf spring with a full length, thin slice of steel sheet (metal yard fencing sheet steel works well), and drill two holes in either end and screw in one screw completely on one end of the new leaf spring and use the opposite end screw to increase the tension on the spring to suit your stick resistance preference.
If you find it's too tight and you don't have much adjustment, use a light rub of candle wax on the curved part of the throttle housing, but not too much as it may make the throttle stick flop all over the place, especially if you can't apply enough tension to the new spring. You want it to be firm, but to be easily moved.
Old Jun 28, 2012, 03:19 PM
jamiedg's Avatar
Joined Apr 2012
Thanks for the detailed advice on this StormForce, sorry for not thanking you sooner but my 9116 is in the repair hangar !
I was flying fairly high with an 808 #16 camera when I lost radio contact and had motor stop.
I've had this before with a 27MHz S032g and solved the problem with silver paper wrap round the camera see below;
Syma S032g Helicopter with onboard 808 chain Camera over Annan. (3 min 14 sec)
I thought that with the 9116 being on 2.4Ghz camera RF noise would not be a problem, but looks like I was wrong.
Anyway - the 9116 landed on short grass and bounced about 2ft in the air.
The canopy was cracked and will tape fix but the control board is damaged.
Still only $15 / £9 from bg for repair so not too bad, rest of heli looks fine.
It's a testament to the strengh of the 9116 that not more was damaged.
Looking back at your mod I think I'll leave a bit of a ridge just before the throttle off setting.
Lately I've hit a couple of thermals and been unsure how much to reduce power before hitting the off area.
Like many I'm waiting for my Beetle Quad from bg - cant wait, thanks again.
Old Jul 02, 2012, 08:55 PM
Joined Jun 2012
how to bind 9116tx to v911
Hi, a quick question, it is probable answered around here. How do you bind 9116tx to v911? Thanks
eertan is offline Find More Posts by eertan
Old Jul 05, 2012, 04:57 PM
jamiedg's Avatar
Joined Apr 2012
Hi eertan,
see the below 9116 guide which covers the bind process.
http://customers.skymesh.net.au/%7Em...ech_manual.pdf
The simple v911 bind process is;
1. Insert the lipo battery in the v911 heli - Rx board led flashes.
2. Then make sure the Tx throttle is fully down and switch on the 9116 Tx.
3. Once the normal bleeps have finished you should have bind - Rx board led now steady.
4. Follow the previous posts in this thread to reverse the Rudder and Ailerlon controls
cheers,
Old Jul 22, 2012, 04:07 AM
jamiedg's Avatar
Joined Apr 2012
WLtoys beetle v929 tested with 9116 Tx
My Beetle arrived last week
Just a note to confirm that the WLtoys beetle v929 quadcopter works fine with the 9116 Tx. The stock Tx is fine but I like having the individual control on rates, tend to use rudder on 50% which gives a slower turn.
Follow prev post to reverse RUDD and ELEV.
Old Jul 27, 2012, 09:45 AM
Joined Jun 2012
Hi eertan,
cheers,
Thanks jamiedg.
Old Jul 29, 2012, 02:33 AM
Canada, BC, Vancouver
Joined Jul 2012
problematic 9116
I have a problem with my brand new 9116. i didnt record the video i have found it on youtube ..i have the same problem, can anyone help me plz?
MOV 0062 (1 min 14 sec)
letsstart78 is offline Find More Posts by letsstart78
Old Jul 29, 2012, 10:12 AM
He flies-He flies-No, he falls
Makdaddy's Avatar
United States, MI, Sterling Heights
Joined Jul 2012
Kind of a silly question but, if you reverse the settings for the V911, will it effect the settings for the DH9116?
Not familiar with the DH 9116 TX. Does it have memory? Was contemplating getting a DH9116 and if the TX can reduce the sensitivity of the rudder for the V911 it would be a win-win situation until I get the new T9xR - if it ever gets released.
I have not checked - the T9x does bind to the DH 9116?
Makdaddy is offline Find More Posts by Makdaddy
Question DH 9116 new TX won't work, lites work Sculptor Beginner Training Area (Heli-Electric) 12 Jun 28, 2012 03:50 PM
Help! DH 9116 LCD settings question Sculptor Beginner Training Area (Heli-Electric) 17 Apr 20, 2012 07:15 AM
Discussion DH 9116 TX has a speed step in throtle Sculptor Beginner Training Area (Heli-Electric) 2 Mar 10, 2012 07:42 PM
Help! Noob with dh 9116 charging issue Skeye1022 Beginner Training Area (Heli-Electric) 7 Jan 05, 2012 08:41 AM
