Old Jun 13, 2012, 09:20 PM
Frisk151 is offline
Find More Posts by Frisk151
The Toy Man
Frisk151's Avatar
United States, TX, The Woodlands
Joined Aug 2004
Need help with using the Flight Data Recorder w/OSD Pro, expanders & sensors, etc
Hi all,
I'm fairly new to FPV but not R/C. I'm hoping someone can help me out with possibly a schematic or information on how to properly setup my system. I’ve done some searching and haven’t come across a schematic of anyone using the Eagle Tree OSD Pro with the data recorder, rather than a e-Logger.
A few years ago I purchased the Eagle Tree Seagull Pro with Dashboard, wireless downlink (900mhz) and a bunch of accessories. It has spent a lot of time sitting on the shelf until I recently got bit with the FPV bug..
I've now purchased the OSD Pro, Eagle Eyes and most all of the current add-ons. (list below)
My main question is how to connect the OSD Pro to the data recorder? There was no OSD Pro when I bought my original equipment.
My second question is can I / should I / do I have to use the 900 mhz transmitter that I originally purchased with Seagull Pro / dashboard, OR can I pipe all of this information through the video down-link to the Eagle Eyes and then to the dashboard and finally to my laptop? I haven't been able to find anyone using the OSD Pro w/data recorder & dashboard, etc. +I'm fairly certain my video range is going to be greater than the Eagle Tree 900 mhz down-link, thou I do have a Yagi 900mhz rx antenna.
Some of my other questions is when you have things like GPS inputs located on both the data recorder and the OSD Pro.. Which do I hook it up to?
If someone would be willing to create a schematic of how all of my gear should go together, I'd be ever so grateful.. If that requires more time (and experience using the OSDPro w/data recorder, etc) I’d probably be willing to spend a little bit for a professional and easy to understand schematic.
Below is a list of my equipment / setup.
Airplane: Senior Telemaster Plus
Motor: RIMFIRE .80
ESC: Castle Creations ICE100
RX BEC: Castle Creations 10 AMP
R/C RX: DragonLink v2
vTX: Immersion RC 5.8GHz 600mW w/ Bluebeam 3 lobe cloverleaf antenna
Video: GoPro HD w/Pan & Tilt mount.
Batteries:
2x 5000mah 5s 18.5v for motor
Dedicated Lipo for R/C system
Dedicated Lipo for Video System (cam & transmitter)
EagleTree Equipment for Plane:
Flight Data Recorder Pro – 4 servo monitoring, pitot airspeed, barometric altitude. etc.
900mhz data transmitter
OSD Pro
10 Hz GPS
G-Force Sensor
Brushless RPM Sensor
Guardian Stabilization Expander
100-AMP Electric Expander (mah & voltage)
Servo Current Logger
Micro Temperature Sensor (would like to use two of these to monitor battery pack temps)
Temperature Sensor Loop (Motor temp)
Battery backup harness
Remote (external) extension for programming and connecting to the Flight Data Recorder outside of the fuselage
I don’t think this is relevant but I’ll include my base station gear list below:
Eagle Eyes Tracker, diversity & distribution
Power Panel LCD Display
Eagle Eyes Pan / Tilt Mount
2x Immersion RC 5.8G Receivers
1x Bluebeam 4 lobe skewer planer wheel RX Antenna
1x 5.8G 5 Turn Helical 9.5dbi
LCD Monitor
Fatshark Dominator w/5.8G Immersion Module & head tracker chip for pan & tilt
Thanks a bunch in advance!
David
Frisk151 is offline Find More Posts by Frisk151
Old Jun 14, 2012, 03:43 AM
Megafluffy is offline
Find More Posts by Megafluffy
Norway, Hordaland, Bergen
Joined Feb 2009
Hi,
The OsdPro manual show where you shall connect the osd to the (pro)Recorder.
You connect the GPS to the Recorder, to the port labeled GPS (there is no connection pins on the osd for GPS, it gets the gps-data from the recorder)
No, you don't need to use the Seagull system, you can get live data from the eagle eyes when using the osdpro.
Download the newest manuals for all your equipments, most of them have been updated compared to the manuals delivered with the products.
Megafluffy is offline Find More Posts by Megafluffy
Old Jan 07, 2015, 11:14 PM
Stubby01 is offline
Find More Posts by Stubby01
Joined Jan 2015
help needing hooking up head tracker and spagetti
Howdy
New to RC Groups. I am in the same situation as Frisk.
I am new to the FPV and quads.
I am trying to use a pan/tilt/roll camera platform and can not figure out how to setup it up.
Equipment:
Fatshark VS1100 with head tracker
Eagletree Vector + OSD
Immersion 5.8 ghz audio/video transmitter
new camera on the way since I was being stupid
JR 9 channel XP8103 transmitter with 2.4 ghz Spectrum module
I have, on the way, a 9 channel RX on the way since I don't think I can do what I want with a 7 channel RX.
I think I have an idea how it should work but a little scared since being stupid with the camera.
How does the PTR platform get the signal from the head tracking googles to do their movement?
Suggestion, diagrams, or directions to look on the web would be greatly appreciated. My head hurts banging it against the wall.
Stubby01 is offline Find More Posts by Stubby01
Old Jan 07, 2015, 11:37 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by Stubby01 View Post
Howdy
Equipment:
stubby,
That is a fatshark question, not a vector question.
Your pan/tilt runs directly from your receiver to your servos, and has nothing to do with vector, or Eagle Tree.
Your head tracker will most likely run from your buddy port in your Tx (JR radio). You will hook up the ppm out of the head tracker to the ppm in on the jr, then it will likely inject a ppm signal in to two channels. You need to read the manual, or seek advice on a fatshark thread.
If I could help you, I would
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Jan 13, 2015, 10:41 PM
Stubby01 is offline
Joined Jan 2015
I did get the camera to manual use using Aux2 and Aux3 on the receiver. I am still concerned that I might not have things right. I submitted a ticket of my arming of the motor issue and seems to work but intermittent.
For Sale EagleTree Data Recorder-OSD; LOWERED PRICE cadzilla FPV Equipment (FS/W) 0 Jun 11, 2012 12:18 PM
Sold Eagle Tree OSD Pro Complete Setup (eLogger, OSD Pro, GPS Expander) picassolsus FPV Equipment (FS/W) 4 May 11, 2012 11:59 AM
Help! Firmware update error with OSD pro ONLY Data Logger and Gardian firmware update works whosthebaddest Eagle Tree Systems 10 Mar 17, 2012 05:26 AM
Sold Eagle Tree Data Logger V3, OSD Pro, GPS Expander $150 bcucoach2 FPV Equipment (FS/W) 1 Dec 10, 2011 09:36 PM
Sold TM1000 with data lead, y harness, Voltage sensor,Temperature sensor 45.00, OBO bonner Aircraft - General - Radio Equipment (FS/W) 2 Dec 02, 2011 01:22 AM
