Old Jun 14, 2012, 10:29 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
The motor/mix stuff makes sense, thanks
I just made a quick range test:
- builtin antennas (aka hanging wires), untunned
- I live in San Francisco and did the test where I could right now, aka even thus im near the water, the TX was in my apartment at the window (12 meters high, 200 meters from the sea, there are about 8 houses of the same height before the sea)
- I do not currently have a radio scanner so I used the license-free 467.587mhz starting freq
-I do not have the telemetry LCD monitor
- walked away until fail safe with the wing (RX)
Non-LOS, first fail safe at ~280m (measured with GPS). Could reproduce the fail-safe reliably.
I find it a little low but I probably should tune the antennas and try the other frequencies as well. I wish I had a scanner. Anyone in SF? :P
Going to fly it nevertheless tonight I think, just wont go far yet.
CrashMeUp is offline Find More Posts by CrashMeUp
Old Jun 14, 2012, 11:59 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Why freq. in middle of FRS band ? It was set 427, the nunchuck normally outputs 25-40mW, With such low power I just pick any clean channel in 400-428.
LowPass filter in RFM22B modules takes 3-4 db away if going up from 433 MHz and there is no attenuation at if using lower frequencies.
With nunchuck alone,without repeater, you should be ableto fly 1km radius with 0.5w 2.4GHz vid.TX, I know for sure cause the receiver you got was removed from working wing -few videos in my youtube channel were ecorded with this RX.
When doing range check set Z4 (click Z 4times shortly), this will keep Nunchuck active, all other modes timed out in about 15-20seconds if stick hasn.t moved or no buttons were pushed the nunchuck goes into power save mode outputting only 2 packets per. sec (2Hz) instead of normal 270Hz
Could be it fell asleep while you walked range checking
fmkit is offline Find More Posts by fmkit
Old Jun 15, 2012, 12:34 AM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
Alright I'll try. It's actually quite possible that it happened.
The freq i used is one of the lowest legal freqs (as in license-free) I could find that's why
Even at low power i'd rather scan. Military ships are well in range xD
I'm going to try to night-fly it now tho hehe.
Old Jun 15, 2012, 01:19 AM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
and i'm back. well, flying by night (the wing has leds) a tiny, light wing with strong wings, on a rc control system you haven't tried before ain't the brightest thing in the world... I know that
After a few attempts tho, it flew well. While filming at night just shows leds moving, I'll try to get it filmed during the daylight.
Here's my current feedback:
- I like Z3 a little better than Z2 on this wing in fact
- the gyro auto gain works very, very well. It flew on tracks. Did I mention <200gr and strong pacific wind?
- since there's no trim as far as i know, better get your screw driver or whatever you use to manually set the trims. The only solution I can see to that would be to implement auto trim (eg Z+C pushed = remember stick position as trim)
- flying with the joystick is natural and extremely, extremely easy
- managing the throttle is not natural and takes a little time to get used to, but, it's not that bad. I wish the motor cut was instant tho, specially during my first throws
Oh and best of all is I can carry it in my pocket, no bags, or bulky stuff. In fact I could even fly from my pocket as it's a little cold outside at night. So cool!
Old Jun 15, 2012, 01:57 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Z1/Z3 not normal modes, you have to move CG back or ncrease throws- move pushrods to outer holes of servo horns
- expected ! the more you fly, gyros will make you lazy, you'll start flying ugliest palnes, why fix them if they fly good anyway ?
You can do that but only temporarily, enter 6.3.1 and hold joystick to compensate offset, say needed trim aileron right hold stick left while storing neutral. I will never implement auto-trim cause it will shrink available resolution, original Nintendo joystick has only 220-230usable counts (+/-115)
you have to adjust trims mechanically
Don't get used to shut motor off with Z1 command, whenever you need motor cut-off tilt hand down 1st then click if needed. When clicking nunchuck waits for inactivity then command is registered, When starting clicking nunchuck doesn't know 1st click was Z1 or is part of longer command.
In winter you'll like it even more while holding nunchuck inside sweatshirt pockets - no numb fingers, also when flying at beach peiple have hard time finding out who's controlling the plane.
Old Jun 15, 2012, 02:14 AM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
that's right i started tilting down then Z1, but it's hard to get used to it (well i only flew like 30min so uhm )
I'll try the auto trim next time i forget my screwdriver its handy even if it lower the precision a bit. I gotta print myself a little card with all the codes.
I must agree the gyro made me lazy already. First few throws i had "not so good landings" while i was adjusting the trim, battery poped out a little, i didn't even put it back in "i'm sure it"ll fly straight" (and it did!).
Old Jun 15, 2012, 02:24 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
remeber to take off in straight line, then gyros will help
if you start with swing then gyros may cause crash
look at my youtube videos- I hold the wing by its nose and let it go straight forward. almost no force.
skyfun beach (2 min 11 sec)
Old Jun 15, 2012, 02:32 AM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
yeah that's how i launched before too, except now i don't need to hurry on the sticks
in fact, i had a gyro on this wing before (some regular heli gyro) on the roll which helped, but it wasn't as fast as yours. also it was roll only so in the wind, even if it was better, it wasn't "on a rail" like it is now. it's amazing how easy it is to fly with it.
Old Jun 15, 2012, 05:46 AM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Well I'm in, just ordered Not really sure I've got the right parts, 1st pic and third pic on the ordering page sound right?
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Jun 15, 2012, 06:01 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
You'll get newer (v4) RX board (35X48mm)
now choose Mumchuck color - White,Black,Blue or Pink !
Old Jun 15, 2012, 07:11 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Awesome, I'll take black.
Mark
Old Jun 17, 2012, 02:01 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Mark
your set is packed and will ship in couple hours,
before I depart with such a good receiver I took picture and made video
to show FS and low (10.2 orless)battery. monitor in action.
Normal digital telemetry deliver lots of data but has limited range
while most important data (FS,Low voltage) always heard on 2-way radio and you can set it very loud. The walkie-talkie used also to locate downed plane (RF beacon built-into RX)
BTW, the receiver was pulled from the wing shown in post #4, the RX has about 15hours airtime.
http://www.youtube.com/watch?v=ZAU5mGnXHFo
Old Jun 17, 2012, 03:04 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
That is awesome that the receiver has a locator beacon built in.
What is the best or easiest way to get 20km range out of this system? I think I will be learning to fly with this system first on a small wing but eventually I would like to get more receivers and setup a long range plane. I presume a relay receiver with a directional antenna but maybe more power would be needed.
Can't wait to fly with this gear.
Mark
Old Jun 17, 2012, 06:03 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Hi Mark,
shipped original Ninendo black nunchuck that was modified to work all frequencies (240-930.000MHz)
default TX/RX freq. is 427.562MHz
you can set New Zealand legal UHF CB Channel 22 and 23 (476.950 and 476.975):
below is picture of repeater,
there is no dedicated page yet
it looks like RF beacon but 2-way
If anyone orders beacon and puts note "repeater" I'll ship repeater
it has ouput power just little over 50mW but if placed high helps a lot
you can fly from inside car or couple floors underground with this repeater or put it as primary RX feeding PPM to MultiWii or other controller that takes PPM
Later I'll prep more powerful (10-15Wt) repeaters.
Old Jun 17, 2012, 04:50 PM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
i think a ~500mW or so repeater would be nice, 10-15W is a lot (or something you can setup), but 50mW is also not much.
Discussion ALES - Let's discuss non-Radian foamies for ALES aeajr Electric Sailplanes 20 Feb 05, 2012 01:26 AM
Discussion So It Is Christmas, Let's Discuss Murocflyer Life, The Universe, and Politics 77 Jan 01, 2007 03:15 PM
Discussion Let's Discuss The Sport Flyer Wasp Slowdoc Beginner Training Area (Aircraft-Electric) 1 Dec 08, 2006 02:24 PM
Killer deals on hs-50,55's, HImax, phoenix 10Berg 4's etc. etc. Astro30 Micro Helis 3 Sep 05, 2004 04:15 AM
