Old Jun 13, 2012, 09:12 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
fmkit's ULink (review/discussion/etc)
I've received fmkit's rx/tx LRS solution a little while ago and I wanted to share my experience. (got it from http://fmtv.us/ )
Please note that this is a home made version and you'll be able to tell that. However, solder points, etc, were all well made and it looks reliable.
I had some issue at the beginning with my submicro analog servos, even thus the board supports analog and digital servos, the first channel would jitter a lot for some reason.
I have bought new digital submicro servos for testing due to this, and those work perfectly fine.
Here's a quick demo video:
Sorry, no sound, mic is broken. You can see the 2 control servos and the pan and the tilt servos. You can see the WMP gyro/accelerometers in action.
The movement is (very) quick, smooth and relatively precise. Pan&tilt is done via presets (hit a button), but can also be done via joystick (obviously if you move the camera via the joystick your plane better go straight..)
fmkit ulink (1 min 42 sec)
I'm going to install the new servos in one of my wing and go for a range test, then a flight, and report.
CrashMeUp is offline Find More Posts by CrashMeUp
Old Jun 13, 2012, 11:35 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
1st ch. you mean trottle ? It always has rate faster than analog, every ESC drom China thatI tried works at fast refresh rate.
There is no full description of setup codes used w/Ulink so I'll post most used codes here:
1st you have to set starting frequency of nunchuck and RX
enter 6 digits into RX and same into Nunchuck after clicking "C" 6 times.:
U-Link RX, setting RF channel (1 min 1 sec)
Then set sub-channels on both, RX use codes 1.x and nunchuck as all setup codes the same but starting with 6, that is 6.1.x
Sub-channels are pre-defined groups of frequencies so RX can track multiple transmitters (repeaters and nunchucks) when flying in multimaster mode or when you fly and someone else control your P/T
The RX has beacon function, to enter new frequenc y enter 6digits same as RX frequency set but substituteleading "4" with "1" , if entered 162622 actual frequency stored will be 462.822MHz (CH5 FRS)
single digits codes:
1 click - calibrate gyros (never used, it's easier to push elevator stick while holding Z-btn on nunchuck
2 clicks - reverse both servos(only works if active flying wing mix)
3clicks -reverse pan direction
4clicks - reverse tilt direction
5clicks activates video switcher( if installed) or switches between cormal pan servo and continuoes totation servo
group 2.x used to set gyro gain (normally not needed)
group 3.x used to reverse gyros:
3.1 X gyro reverse
3.2 Y :reverse
3.3 Yaw gyro revers
3.4 swap X and Y axis ( same effect as if rotate RX board 90degree), thus the board can be installed in 8 positions (4 with 90deg. pitch face up and 4 upside down)
4.1 and 4,2 flying wing mixes , 4.3 classic mix, 4.4 - base installation for camera or antenna P/T (not flying mode)
5.x AUX B modes:
5.1 fireworks igniter - connect nichrome wire to high current FET (oboard)
5.2 random LED lights (same FET used to control power LEDs)
5.3 PPM input, incoming PPM is master -overtakes control if 1st 2 channels not centered(1.5ms)
5.4 the same but control signal is ch5
5.5 Power LEDs strobe - double blink every 1.5s
6.X Aux-A codes:
6.1 Fireworks igniter 2nd channel
6.2 3-position switch (PWM 1ms,1.5ms,2ms)
6.3 Rudder PWM out
6.4 PPM out
6.5 LEDs blinks fast
7.x frequency hopping step (0-2MHz)
8. servo reverse, for mixes 4.3 and up:
8.1 reverse Aileron
8.2 reverse Elevator
8.3 rudder
9.1 digital servos 9.2 analog
Beacon starts to transmit only if motor was active atleast 1s,, when you connect power to RX buzzer and beacon won't activate till 1st failsave then timed 2minutes on old receivers and 50seconds on new.
fmkit is offline Find More Posts by fmkit
Old Jun 13, 2012, 11:52 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Nunchuck setup. all codes start with 6, wait for"ready" tone then input codes
6.1x sub-channel
6.2.x used on old nunchucks to switch starting frequencies
6.3.1 if you replaced joystick board calibrate accelerometers just once, hold nunchuck neutral till "stored" tone - have to hold neutral only for this code
6.3.2 sets Nunchuck output PPM
6.3.3 PWM out -servo tester
6.3.4 PPM-in (can mix incoming PPM )
6.3.5 Automatic switch, when powered the nunchuck samples PPM-n for 1/2s, if no input detected switches to PPM-out(use with SIM, or RF hack module)
To activate trottle click Z 2,3 or 4 times - all the same effect, 1click shuts the motor off
to control rudder have to hold Z btn or click Z 3 times
To let other pilot controlyour plane withhis nunchuck enter multimaster mode wih 6 fast clicks (Z ) then whenever you're in Z-3 position and stick is centered others can fly your plane.
Old Jun 13, 2012, 11:58 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Most recent video with Ulink in action, not FPV but RX tracks two nunchucks, friend of mine was controlling P/T while I was controlling the wing.
Rosh HaNikra beach flying low and slow (3 min 14 sec)
Ulink was stable while next to noisy car dvr (simiar as HoryzonHD), normal UHF LRS would crash past 300m, Ulink used 2 repeaters by the time
Old Jun 14, 2012, 12:32 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
plenty of stock:
Old Jun 14, 2012, 01:11 AM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
1st channel i mean the first servo channel (or maybe its channel 3 for you)
Old Jun 14, 2012, 01:18 AM
flylite is offline
Find More Posts by flylite
I Like Popcorn
flylite's Avatar
UK, Greater London, London
Joined Oct 2009
All looks very interesting but could you give us an overview!
flylite is offline Find More Posts by flylite
Old Jun 14, 2012, 01:59 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
More info please.
RolandS888 is offline Find More Posts by RolandS888
Old Jun 14, 2012, 02:00 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Originally Posted by fmkit View Post
plenty of stock:
Any information on how to order?
Ian Davidson is offline Find More Posts by Ian Davidson
Old Jun 14, 2012, 02:49 AM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
Here's the ulink on my wing now that I swapped the servos and set it up:
ulink 2 (1 min 54 sec)
I ordered it from http://fmtv.us/
Remember that it's not from a shop but just a person doing this for us so shipping can take a little while, it's home made and so on. On the plus side support is good and as you can see it seems to work quite well
I'm not sure if the video shows how bright the led beacon is. It would blind me at this distance and this is on 2S
Old Jun 14, 2012, 03:05 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
CrashMeUp, when you're in Z1(motor off) or Z3 position rates look very high but that how it suposed to be - this is "hyper" mix when elevones use all available travel, say you about to catch the plane and just turned motor off, now in Z1 mode elevator can go uo and down 100% (normal wings or Z2 only 50%) only while aileron not used and vice versa,
also when you showed gyro response it looked like very high only because the plane was relaxed in your hands, while up and flying the gyros will adjust automatically /set gain per conditions, next time you're in front of camera try to shake the plane hard to imitate oscillation and you'll notice the gyros give up shortly to stop oscillation, the gyros wil reduce gain to zero if needed.,
with stick in extreme position there is no gyro effect so you can loop and roll as you wish.
Old Jun 14, 2012, 04:07 AM
vvV FANG Vvv is online now
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Harden
Joined Aug 2008
I have had a firm belief for a long while that mr fmkit is perhaps the most innovative thinker and designer/manufacturer that the fpv world and perhaps the wider rc world has had for a long while. What he may lack in fancy websites and presentation he makes up for in innovation..... to me he is one of those rare gifted elecronics people who has solder in his veins.
To me something gets lost in translation and what he says may seem complicated but im sure its not.
If his stuff had fancy packaging and was on hobbyking im sure there would be big threads on it.
I dont know him nor was i paid to say this, and I've only brought the rf beacon which is amazing and every long range flier should have one!
fmkit, could u tell us all in point form what this ULINK does?
Perhaps i (or maybe someone who understands it ) could help write it up for you?
vvV FANG Vvv is online now Find More Posts by vvV FANG Vvv
Old Jun 14, 2012, 04:19 AM
Formerly bUd~Fokker
Joined Aug 2008
Here is the original thread i got lost in the first post
Fpvkiwi who i think is another gifted electronics guru seems to have a good handle on it?
http://www.rcgroups.com/forums/showthread.php?t=1543898
Old Jun 14, 2012, 04:39 AM
Jack_LaLanne is offline
Find More Posts by Jack_LaLanne
Jack_LaLanne's Avatar
Germany, Berlin
Joined Feb 2009
I am looking forward to the range test results very much.
Jack_LaLanne is offline Find More Posts by Jack_LaLanne
Old Jun 14, 2012, 05:36 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Ulink is an UHF LRS designed for FPV so pilot and spotter can control one plane as a team even if while miles apart. Single RX tracking pilot's nunchak and his repeaters and the same time spotters nunchack and his repeaters
The RX sends telemetry in two separate channels simultaneously. regular digital telemetry refreshed every 0.25s (4Hz), it sends voltage, amperage, signal quality, packets received,flight time, FS log,mAh used, all tx controls status and more.
2nd channnel is pure analog one, low battery, FS and beacon tones all heard using walkie-talkie, analog telemetry has 10x greater range, whenever digital link breaks you'll instantly know real time status by listening tones
The system has built-in P/T servo stretchers, some RXs have video switcher, all RXs have two high-amp switches for use with LEDs or igniters
Gyro stabilization is buil-inbut can be turned off if you got more advanced IMU.
Giros are very easy to use, beside revrsing there is basically no setup - no PIDs to tune, no gain/delays , When powered up the system calibrates itself and you can take off almost instantly.
Stabilization is very useful if flying small unstable planes such as wings without winglets and almost no sweep. Ugliest palne that looks unfliable behaves differently with gyros
The system is not new - it was evolving for over 2 yearsand still refined, we test updated FW atleast every week.
Discussion ALES - Let's discuss non-Radian foamies for ALES aeajr Electric Sailplanes 20 Feb 05, 2012 12:26 AM
Discussion So It Is Christmas, Let's Discuss Murocflyer Life, The Universe, and Politics 77 Jan 01, 2007 02:15 PM
Discussion Let's Discuss The Sport Flyer Wasp Slowdoc Beginner Training Area (Aircraft-Electric) 1 Dec 08, 2006 01:24 PM
Killer deals on hs-50,55's, HImax, phoenix 10Berg 4's etc. etc. Astro30 Micro Helis 3 Sep 05, 2004 03:15 AM
