Old Oct 24, 2012, 04:42 PM
doxilia is online now
Find More Posts by doxilia
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Jeff,
beautiful..., what else can I say.
Question: why such a large battery though? If you could shed a couple of ounces there, you might just wind up golden at 3.5 lbs (56 oz) finished. I don't think you'll add more than ~5-6 oz in the finish tops.
David
doxilia is online now Find More Posts by doxilia
Old Oct 24, 2012, 04:52 PM
Generic Member is online now
Find More Posts by Generic Member
Unregistered abuser
Generic Member's Avatar
Joined Jul 2006
Originally Posted by doxilia View Post
Jeff,
David
Where would I put it?
Generic Member is online now Find More Posts by Generic Member
Old Oct 24, 2012, 07:42 PM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Jeff,
is the issue balance? You need those ~4 oz behind the wing TE?
The engine setup must be heavier than Kato's although I can't see how - the only difference is really the slightly larger pipe which in any case straddles the CG. Maybe the spinner?
For lightness wouldn't it make more sense to put a lighter pack in front of the servos and then a smidgen of weight in the tail? Amazing you wound up nose heavy even with the solid stab...
Nice wing servo setup by the way. Smashing wheels!
David
Old Oct 24, 2012, 08:16 PM
Unregistered abuser
Joined Jul 2006
Only the engine, spinner, prop, fuel tank, and nose wheel retract are in front of the CG. ALL servos, Rx, main gear retracts are aft of the CG. Other than using a ~heavy battery aft of the CG, I could move the rudder and elevator servos to the tail. For all that work, I would save ~2oz? with a lighter battery. Not sure if its worth it.
Old Oct 24, 2012, 08:38 PM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
I wouldn't move the servos to the tail - that's a pain.
All I was thinking is that perhaps you could shed half the battery weight, avoid the hatch and add a few grams to the tail to balance but yes, the net gain might be ~2 oz. Not a biggie.
David
Old Nov 02, 2012, 12:14 PM
Unregistered abuser
Joined Jul 2006
I finally committed to a paint/covering scheme. I wanted to stay with the "box art" theme, just modified it a little to my liking.
I made a hatch in the bottom of the fuse behind the stinger extension for the Rx battery and ordered a custom battery pack from CheapBatteryPacks.com.
Monokote and glass this weekend.
Old Nov 02, 2012, 02:16 PM
CSpaced is offline
Find More Posts by CSpaced
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
I like it, should look pretty cool
CSpaced is offline Find More Posts by CSpaced
Old Nov 13, 2012, 10:23 AM
Unregistered abuser
Joined Jul 2006
The wing has the base color Monokote applied and I'm laying out the stripes.
Fuse bottom got a coat of glass cloth and resin last night.
Old Nov 23, 2012, 11:43 PM
bushpilotx1 is offline
Find More Posts by bushpilotx1
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
Nice,,,,,,, one of my favorite any chance we can get a copy of the instructions and Plans. Id love to build one.. Ill tell you waht Ill trade you a set of plans and instructions for the MK Aurora 25 lmk and thank you for taking the time to post your build , I know it takes time.......away from family and building. lol . thanks again Geoff
bushpilotx1 is offline Find More Posts by bushpilotx1
Old Dec 03, 2012, 05:42 PM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Jeff,
so where are things at? Any primer/paint action?
David
Old Dec 04, 2012, 02:39 PM
Unregistered abuser
Joined Jul 2006
Hi David.
The wing is Monokoted and the fuse is glassed. It has one coat of primer applied and sanded. Ready for the next coat. Winter cought me by surprise. Spraying the KlassKote in 40 deg weather is not an option.
Old Jan 11, 2013, 05:19 AM
whb197929 is offline
Find More Posts by whb197929
Joined Jan 2013
Very good, can learn a lot of things.
whb197929 is offline Find More Posts by whb197929
Old May 27, 2015, 12:03 PM
Unregistered abuser
Joined Jul 2006
I was just looking a this plane on the shelf wondering where/why I abandon this project. It all came down to painting. I think I'm going to pull it down, look it over and see if I can't get some paint on it and get it in the air.
Hard to believe I last worked on it 2 1/2 YEARS ago. Where does the time go??
Old May 27, 2015, 12:11 PM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Goody, goody! Perfect KK weather.
It sure does baffle reason... Where does the time go!
What's the left fuse side opening for?
David
Old May 27, 2015, 12:31 PM
Unregistered abuser
Joined Jul 2006
David
A big ugly switch with charge jack. Funny you noticed that cause it bugs me.... I will come up with a better solution and patch that hole. Also thinking about actually making a wye exhaust and ditching the "through the fuse" stinger. Still don't like where I have to mount the flight battery, but I've got to finish this thing.
Build Log Contra-prop ESM Spitfire Mk. XIX build scatsob Glow to Electric Conversions 340 Dec 15, 2012 05:49 PM
Poll MK Skymaster 20 Generic Member Classic Pattern Flying 10 Jun 03, 2012 09:50 PM
Discussion Frog Build Off Oct 2011-April 2012 - Vanda Mk. 2 vega Vintage & Old-Timer Designs 13 Apr 29, 2012 09:15 AM
Found MK Skymaster Kit Generic Member Aircraft - Fuel - Airplanes (FS/W) 0 Apr 20, 2012 02:44 PM
Discussion snowgoose 20" Mk II-canard for 6400 rx phil alvirez Scratchbuilt Indoor and Micro Models 0 Sep 17, 2011 02:38 PM
