Old Oct 11, 2012, 11:35 AM
Fatherof4 is offline
Find More Posts by Fatherof4
Raised on 80's Pattern
Fatherof4's Avatar
Rancho Santa Margarita, CA
Joined May 2006
Originally Posted by doxilia View Post
Matt, you should post more often, your thoughts and contributions would be great! We want to see that Atlanta going together!
David
+1
Yes Matt, your knowlege and insight is a welcome addition here.
Doug
Fatherof4 is offline Find More Posts by Fatherof4
Old Oct 11, 2012, 04:52 PM
Huang is offline
Find More Posts by Huang
United States, CA, SF
Joined Sep 2001
Thanks for the kind words guys. Funny I've been reading all the great posts from you guys for the past 10 years and never posted. It's not just the cool planes, what I loved about vintage pattern is all the stories and history that came with it, and you guys were always able to piece the stories and history behind the planes together.
There is long line of lineage in the pattern planes and pilots -- from designers to development to building and flying them at WC -- that is wonderful to see and enjoy. And plus they look so cool!!
Huang is offline Find More Posts by Huang
Old Oct 14, 2012, 12:27 AM
frequentflyer1 is offline
Find More Posts by frequentflyer1
AMA MEMBER
frequentflyer1's Avatar
United States, CO, Grand Junction
Joined Mar 2010
Jeff
Great build thread. For what its worth, bending alum tube , rub soap on it , heat with a torch until the soap turns black , let cool, it is annealed and soft, bends much easier now. Next buy a dozen or so pieces of small dia dowels, 1/16" 3/32" or possibly 1/8" x 36". Then slide them in the tube to fill it fairly full make your bends and slide them out. It keeps it from kinking. Next best thing to a mandrel bender I use. The tube will become hard again in a few days all by itself.
Don
RcAiir.com
frequentflyer1 is offline Find More Posts by frequentflyer1
Old Oct 15, 2012, 08:43 AM
Generic Member is offline
Find More Posts by Generic Member
Unregistered abuser
Generic Member's Avatar
Joined Jul 2006
Don, thanks for the tip. I have a few extra lengths of tube left that I might practice on. The only trouble I had was with the thin wall tube. It's soft and easy to bend, but it would tear and kink if the radius was too small. The spring bender produced acceptable results with the thicker walled material.
I "thought" I was pretty close to being ready to apply cloth and resin, but after I stared mocking everything up with the new Airtronics servos, it turns out I still have a bit of work to to. (The whole point of mocking it up...)
It turns out my rudder pushrod was all but touching the exhaust stinger. I decided to re-route it with Nyrod.
I also discovered/remembered that the elevators need to be re-made with the same thickness material as the new stab. The originals are just a bit thicker. Enough for me to notice. Making replacements will be easier than trying to sand the originals to the right thickness.
The last bit I still need to fabricate is a tank hatch. The plans just call for a plank of wood to be glued in place, but a hatch would be smarter in case I ever need to see/access the front of the tank.
I ran the engine on the test stand again. This time with the stinger extension to see if there were any adverse effects and I'm happy to report, the engine runs exactly the same, but with a different exhaust note.
Here is a couple short videos of the engine running... The tach numbers on the second video are far from peaked. (she's still new...) No comments about my dodgy test stand.
VIDEO0003 (2 min 12 sec)
VIDEO0006 (1 min 17 sec)
Generic Member is offline Find More Posts by Generic Member
Old Oct 15, 2012, 12:54 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Use sand in the tube when you bend it. Some have suggested salt as another option.
Bend it around a form, with tension on it.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 15, 2012, 06:12 PM
Huang is offline
Joined Sep 2001
That 25VF sounds fantastic Jeff! I can already see the Skymaster zooming by. Gonna be hard to see! What prop and fuel did you use?
Old Oct 15, 2012, 06:24 PM
Huang is offline
Joined Sep 2001
RcAiir.com
Don, how would soap "aneal" the aluminum and would it then always stay soft afterwards?
Old Oct 15, 2012, 07:33 PM
Pitstop000 is offline
Find More Posts by Pitstop000
Paul Pappas, AMA 42520
Pitstop000's Avatar
United States, CT, Norwalk
Joined Aug 2008
Hey Matt, the process is called annealing, basically softening a metal so it can be worked with.
By using soap stone marks on the piece of aluminum you get a visual aid as to when it’s annealed.
The marks will turn black from white letting you know it’s ready to be worked with, you can also just coat it with some soot from an acetylene flame and when it’s heated and the soot disappears(burns off) the aluminum will be ready for bending etc.
Description: soap stone and marks made on a piece of aluminum tubing before being an anealed.
After the aluminum tubing is annealed it will start to harden again as long as it’s left to cool down on its own. You can also anneal the tubing more than once, especially if you need to set up for multiple bends in the tubing to make a header.
Pitstop000 is offline Find More Posts by Pitstop000
Old Oct 15, 2012, 08:43 PM
Huang is offline
Joined Sep 2001
Thanks Paul! That makes sense. I have to give it a try!! Matt
Old Oct 16, 2012, 10:33 PM
Huang is offline
Joined Sep 2001
Looks very tight! Is the elevator on a carbon pushrod? How did you do the Y in the back?
Old Oct 17, 2012, 12:23 PM
Unregistered abuser
Joined Jul 2006
Hi Matt.
Yes, the elevator is on a carbon pushrod with 2-56 ends. On the wye end, two rods are bent, then wrapped with copper wire and soldered to a short section. The short section is epoxied in the carbon rod about 1" deep.
Old Oct 17, 2012, 05:23 PM
Huang is offline
Joined Sep 2001
Thanks Jeff. Brilliant simple solution! I've been thinking how to get the Y to the carbon rod without drilling. Is the short section is just another piece of 2-56 wire, glued in with 30 min epoxy / JB weld like how we do with the Central Hobbies carbon/titanium pushrod systems?
What is the size of carbon rod used? It looks perfect for the 25 size planes. I would like to use your setup in 40 size Curare. Would this be too flexy on a larger plane?
Old Oct 24, 2012, 04:24 PM
Unregistered abuser
Joined Jul 2006
Matt, yes its the same principal as the Central hobbies product. I use the 4mm OD x 2.5mm ID carbon tube. The ID is a little large so it is best to use JB weld versus epoxy. A better product is EpoGrip epoxy. Its very thick and wont run or drip. Be sure to only insert well cleaned threaded rod into the carbon tube as straight wire might pull out. The threads give the epoxy something to grip on to.
As for it being ok for 40 size models, I would say yes. If done rigt, its as strong as the Dave Brown fiberglass pushrods.
Old Oct 24, 2012, 04:37 PM
Unregistered abuser
Joined Jul 2006
The SM is all mocked up so I can check the balance. The battery (4.2oz 2200mAh 4 cell NiMh) will have to be mounted behind the stinger extension. I will have to make an access hatch and fabricate a mount for the battery. The absolutely last thing prior to finishing.
I weighed it, with everything and it came to 3lbs 5.5oz. I'm happy with that.
Build Log Contra-prop ESM Spitfire Mk. XIX build scatsob Glow to Electric Conversions 340 Dec 15, 2012 05:49 PM
Poll MK Skymaster 20 Generic Member Classic Pattern Flying 10 Jun 03, 2012 09:50 PM
Discussion Frog Build Off Oct 2011-April 2012 - Vanda Mk. 2 vega Vintage & Old-Timer Designs 13 Apr 29, 2012 09:15 AM
Found MK Skymaster Kit Generic Member Aircraft - Fuel - Airplanes (FS/W) 0 Apr 20, 2012 02:44 PM
Discussion snowgoose 20" Mk II-canard for 6400 rx phil alvirez Scratchbuilt Indoor and Micro Models 0 Sep 17, 2011 02:38 PM
