Is it too late to patch those holes????
Got it. I've been thinking some about this business because I've been drawing up a CAD version of the 40 size MK Arrow. I haven't touched it in a quite a while but I wanted the exhaust to come out the bottom and debated whether it would be better to offset the exhaust and keep the pushrods closer to the fuse center or vice versa. In the end, I decided to go with Jeff's SM approach primarily due to how the tail boom is built (the bottom is contour sheeted rather than flat) and it made it easier to keep the pushrods centered and not make a hole in the center of the fuse bottom. On a 60 size Arrow though, one option would be to use a pair of mini servos to actuate the elevators. If placed close to the sides of the fuse, the pushrods would run down the length in such a way that the exhaust can exit center bottom with the pushrods on either side. One could presumably do this with a single servo too but with a little more pushrod routing. In any event, if your Arrow is built and flying, it's probably irrelevant and I should stop digressing Jeff's excellent thread! David |
![]() Behold, for the mind is an expansive thing... plenty of thinkin' to go around! I will be bouncing some ideas off you in the not too distant future. End of digression, David |
SF Bay Area
Joined Sep 2001
I think I know exactly why this is -- it is mostly a sales/marketing reason. In Asia and in Japan, the most popular size by far for R/C aircraft is the 30 class (.25~.36). It is like a .40 size is the most popular size in US. There are dozens engine choices in that size and modelers all had them. However they were all side exhaust - OS 25VF being the only rear exhaust. If limited to OS 25VF it restricted the modeler to the only one expensive DF engine. If using side exhaust, everyone had many cheaper Enya 30BB or OS 32F laying around to use and Hatori made matching S-headers for each. It's like if you made a kit in US only for a rear exhaust 40 how many would you sell. Now if you made it a side exhaust, you had a much bigger market. The 25-sized planes were not really for pattern competition but a cool looking sport plane, so by making it side-exhaust it was more practical and MK had a much broader market to sell to. This is what made the Skymaster 20 so special and why there were so few... it is truly unique in this configuration. In Hanno's write up on the Magic in '81 he said he designed the inverted engine with enclosed pipe on top deck because it reduced pipe temperature by separating engine cooling and pipe cooling (vs. a design like the Arrow). He also said the inverted engine reduced noise because it was cowled, something that if true would carry over to the Skymaster 20. All in all it just looks so damn cool, right? So that we can continue here chatting about Jeff's cool plane and pollute his thread...
SF Bay Area
Joined Sep 2001
Those hobbico exhaust stacks you mocked up are hilarious, I almost fell off my chair when I saw that. ![]() David, on the Arrow 60 I even thought of using an MK bell crank and offsetting the center horn and pushrod so that I can make space for the exhaust to come through in the middle. But as you said it's already built and flying so it's too much work. And if coolness was the factor, the Arrows look coolest with the exhaust straight out back! OK no more polluting Jeff's fine build thread!
For example, the Aurora 30 that we've been redesigning is going to be more like a mini A60: glass pan, plug-in wings, inverted RE engine (OS 25, MVVS 28, OPS 29, Enya 32), Hatori 300, all the cool stuff. As for the Cosmos, it uses a SE engine but with a pipe tucked into a tunnel in the fuse under the wing. The Skymaster, well, it's taken care of. The Magic, we're modifying. Last but not least, I will one day create an Arrow 25 setup like the Arrow 40 except for the 25 VF or MVVS. The Blue Angel, Mattlas and Curare are vintage classics ('70's), smaller and I plan to leave them as is with SE engines and fixed gear.Quote:
David PS Jeff, I think I mostly kept it within the realm of MK 20 size classics. Please don't lynch us for our transgressions!
| Thread Tools | |
| Build Log Contra-prop ESM Spitfire Mk. XIX build | scatsob | Glow to Electric Conversions | 340 | Dec 15, 2012 05:49 PM |
| Poll MK Skymaster 20 | Generic Member | Classic Pattern Flying | 10 | Jun 03, 2012 09:50 PM |
| Discussion Frog Build Off Oct 2011-April 2012 - Vanda Mk. 2 | vega | Vintage & Old-Timer Designs | 13 | Apr 29, 2012 09:15 AM |
| Found MK Skymaster Kit | Generic Member | Aircraft - Fuel - Airplanes (FS/W) | 0 | Apr 20, 2012 02:44 PM |
| Discussion snowgoose 20" Mk II-canard for 6400 rx | phil alvirez | Indoor and Micro Models | 0 | Sep 17, 2011 02:38 PM |
