Old Jun 13, 2012, 08:47 PM
jake42 is offline
Find More Posts by jake42
Joined Mar 2007
MQX crashed - advice needed.
Well I finally did it. I've managed to break something that I can't fix easily on my own. It was getting dark tonight and I took it up for one more flip and lost orientation in the twilight. It was completely inverted and hit the deck rail flush. Two of the plugs snapped off the board completely. I took both of the booms off and the motors still work fine when plugged into the two remaining plugs on the board. My question is, is it possible to buy those little plugs with the pins and what kind of solder would you suggest to get them back in the board?
I'm hoping to not have to buy a new board, but after 3 months of continual abuse I may have finally killed it.
thanks
Jake
jake42 is offline Find More Posts by jake42
Discussion crashed my plane and need some advice on rxs and escs.. jonasstodart Power Systems 22 Jul 03, 2012 11:58 AM
Discussion hi guys, need advice Udonsushi Micro Helis 21 Feb 27, 2012 05:53 PM
Question Servo advice needed. MIRV Multirotor Talk 0 Feb 22, 2012 06:46 PM
Sold E-Flite Blade MQX $100 (Needs 1 motor) Blucross Aircraft - Electric - Multirotor (FS/W) 1 Jan 30, 2012 12:36 AM
Help! Advice needed for Quad flying: what are the common causes of crashes n how to avoid.. housecall physio Multirotor Talk 11 Dec 04, 2011 07:03 AM
