Old Nov 08, 2003, 12:52 PM
jhamm is offline
Find More Posts by jhamm
USA, NY, Rochester
Joined Jan 2003
GWS A-10 with E Tec 1200 2SP1
Are the E tec 1200mah batteries rated @ 5C or 6C? I see both answers on different threads.
GWS says the A-10 EDF 55 motor draws 3.39amp x 2 = 6.78amp.
5C=6 amp which is not enough
6C=7.2amp which works.
Thanks for the info.
Jim
jhamm is offline Find More Posts by jhamm
Old Nov 08, 2003, 01:52 PM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
6C is ok. Life duration might be somewhat shorter, but they will handle it.
luc is offline Find More Posts by luc
Old Nov 08, 2003, 02:09 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I've seen 6C as the max, but 4C as the recommended discharge rate if one cares about longevity.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 08, 2003, 11:57 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Takao Shimizu did life cycle testing on an Etec 1200 2S1P pack(see this thread). After 100 cycles at 8.2A discharge (almost 7C), it was still delivering 96% capacity.
This configuration should suit the GWS A10 well, the only problem being how to get the CG far enough forward. My solution was to build a battery box in the nose. The battery will be loaded through the original hatch (that way I can still use a heavier battery if desired).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Nov 09, 2003, 01:51 AM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
I did fly the a-10 with a single etec 1200 pack in the nose (2s1p) but it got quite warmish hot (too hot for my comfort) so I went to 2s2p. I also had to wedge the 2s1p pack as far as physically possible into the nose area for it to balance.
Edit - Now that it is winter I wonder if I should go back to 2s1p as the heat may actually help some
Mikey-flies is offline Find More Posts by Mikey-flies
GWS Zero and E-Tec 1200 cells? Radioguy GWS (Grand Wing Servo) 21 Apr 15, 2004 12:25 PM
CC Phoenix 25 with BEC on 4 E-Tec 1200? Wheazel Power Systems 17 Jun 09, 2003 07:03 AM
Will E-Tec 1200 2S1P 8.4V burn up GWS DX-A? Mesmer Power Systems 7 May 04, 2003 07:54 PM
will a GWS motor make too many amps for E-Tec 1200's? aeropenguin Batteries and Chargers 10 Apr 23, 2003 12:31 AM
GWS P-51 & 3 Cell E-Tec 1200's graphiteman Parkflyers 8 Mar 22, 2003 02:30 PM
