Old Jun 13, 2012, 11:01 AM
bear57 is offline
Find More Posts by bear57
Central B.C.
Joined May 2008
HELP for a newbie
For several years now I have had a desire to build a model tugboat. I wanted something fairly large, 30 to 40 inches, simple to build with common materials.
I am interested in stand off scale. A more detailed scale subject may follow. I have some modelling experience, having dabbled with model aircraft the last 30 years.
I have aquired several plans, but each seems to either lack in one area or another(in my opinion), or is too complex.
I know nothing about the propulsion system, batteries etc that I may need or the actual building of the boat for that matter, although I am not "electrically challenged".
I suppose the question I have is can someone recommend a fairly simple project in terms of construction and drive requiremnets that would address the needs of a rank beginer? Possibly a kit?
Thanks in advance.
bear57 is offline Find More Posts by bear57
Old Jun 13, 2012, 11:20 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
It is simple look at MACK he got your kit and advice, and you can call him. http://www.mackproductsrc.com/ scale boats page 1 The question is then if you want to build the hull of wood or get one of those ABS hull and structure boats, it's up to you. If you want another Dumas http://www.dumasproducts.com/index.php?cPath=136 (not on his homepage) he can get it for you. i got this on the shelf from MACK (http://www.rcgroups.com/forums/showthread.php?t=1558895)
Anyway its your choice, and fun to come...
Best of luck and be certain you can get ALL the advice you going to need here...
Sharky1dk is offline Find More Posts by Sharky1dk
Old Jun 13, 2012, 11:48 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
I always recommend for beginners: Build a kit first to get an idea of what's going on... then try scratch builds...
patmat2350 is offline Find More Posts by patmat2350
Old Jun 13, 2012, 05:29 PM
rctugger is offline
Find More Posts by rctugger
United States, FL, Sebastian
Joined Feb 2010
that's good advice from patmat and I agree it's the best way to go. Start with a complete kit, then semi kit, and on to scratch if you want the challenge. But there is always plenty of challenge in just doing a precise job on a kit and adding lots of your own detail items. And lastly, there is no shortage of advise and help on this forum when it comes to props, motors esc's, radios, whatever. Welcome aboard !!!!
rctugger is offline Find More Posts by rctugger
Old Jun 13, 2012, 05:43 PM
Rustbucket is offline
Find More Posts by Rustbucket
Portland Oregon
Joined Aug 2006
Well that is how I started I pick up the old Lindburg PT 109 at the 1.32nd scale built it got it runing in the pond then decided to try to scratch build that was over 20 years ago and only stop a few times to take a brake . YUP Pat is 100 percent right get a kit learn from it then go with what ever you want . DON THE Portland Rustbucket
Rustbucket is offline Find More Posts by Rustbucket
Old Jun 13, 2012, 06:27 PM
JOHN SCALE BOAT is offline
Find More Posts by JOHN SCALE BOAT
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
For a wood tug I would recommend this one. It was my first kit build back in the late 80's.
http://www.dumasproducts.com/product...roducts_id=352
The other kit I would recommend it the Jim Wilder. There has been several build threads over the years here. This is a step up in building skill but not much. This kit has good instructions and plans. You will find plenty of help and support on this model.
http://www.rcgroups.com/forums/showthread.php?t=1506688
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Jun 13, 2012, 07:19 PM
onfinal32 is offline
Find More Posts by onfinal32
onfinal32's Avatar
Joined Dec 2011
I agree with these guys. I have a scratch built beautiful tug and that is all I have.The cost will exceed that of a kit and you will have all the goodies.
onfinal32 is offline Find More Posts by onfinal32
Old Jun 14, 2012, 09:59 AM
lslewis is offline
Find More Posts by lslewis
Stilwell Shipyard
lslewis's Avatar
United States, FL, Cape Coral
Joined Nov 2003
I started with a Vac-U-tow boat as embellished by towboatjoe http://towboatjoe.tripod.com/ and enjoyed every minute building and running. Learned a lot, no wood so that might be your second build.
lslewis is offline Find More Posts by lslewis
Old Jun 17, 2012, 11:20 AM
bear57 is offline
Central B.C.
Joined May 2008
Help for newbie
Some very good information here.
I will digest all this and possibly later in the summer I will get to the point of making sawdust.
thanks to all
Old Jun 18, 2012, 10:27 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
30-40'' Tug
I would agree, get a good kit, but add with a fiberglass hull. You are talking a model that will have a ready to run weight, of 25-50lbs. You need a good strong hull, to hold up under transport, and storage. My 25'' pushboat, that draws less than 3'' of water, weighs in at 16-17lbs. CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Jun 19, 2012, 07:42 PM
Olscuzbut is offline
Find More Posts by Olscuzbut
Kamloops BC Can.
Welcome to the Group Bear,
Notice you're addr. is central BC. If you are in and around the Kamloops area, let me know and you can check out my lineup of tugs.
Norm
Olscuzbut is offline Find More Posts by Olscuzbut
Old Jun 25, 2012, 05:26 PM
bear57 is offline
Central B.C.
Joined May 2008
help for newbie
Hi Norm, I sent you a PM.
Discussion help for a newbie! springerfreak Beginner Training Area (Heli-Electric) 2 Apr 25, 2012 10:55 AM
Discussion Newby Seeking Help for Hobbyking T-28 Funfighter LosLocos Electric Warbirds 4 Apr 17, 2012 08:27 AM
Discussion HELP- suggest a Radio for FPV for a newbie garik111 Radios 6 Dec 03, 2011 10:18 AM
Discussion HELP- suggest a Radio for FPV for a newbie garik111 Beginner Training Area (Aircraft-Electric) 4 Dec 01, 2011 09:59 PM
Help! Newbie looking for some help. alaimar Beginner Training Area (Fuel) 5 Sep 14, 2011 10:29 AM
