Old Jun 13, 2012, 10:20 AM
ImAcracker is online now
Find More Posts by ImAcracker
ImAcracker's Avatar
Austin
Joined May 2006
Can someone tell me what type of connector this is?
Greetings fellow RC'ers. I purchased this VRX from Hobbywirless.com and was wondering what type of connector this was. At first I thought it was a cheap version of a standard SMA, but when I try to thread on a standard SMA connector to it, it does not fit. The threads wont start. It feels as if the inner diameter of the connector on RX is smaller than a standard SMA. I guess I should have takes some measurements. I will do that when I get home.
http://hobbywireless.com/index.php?m...roducts_id=512
ImAcracker is online now Find More Posts by ImAcracker
Old Jun 13, 2012, 11:00 AM
Technoweenie is offline
Find More Posts by Technoweenie
Technoweenie's Avatar
Canada, ON, Welland
Joined Jan 2011
Looks to be an "F" connector similar to cable TV connectors. This is fairly typical of video RXs for FPV.
Technoweenie is offline Find More Posts by Technoweenie
Old Jun 13, 2012, 11:07 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
The page does say "Detachable SMA Omini antenna " which suggests it is an sma.
F connectors are much larger diameter than sma.
NDw is offline Find More Posts by NDw
Old Jun 13, 2012, 12:49 PM
malcr001 is offline
Find More Posts by malcr001
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
Those type of recievers are normally SMA. I have two that look exactly the same but from RMRC and they are SMA connectors.
malcr001 is offline Find More Posts by malcr001
Old Jun 13, 2012, 01:41 PM
ImAcracker's Avatar
Austin
Joined May 2006
I went home for lunch and grabbed the RX. Took some measurements and the RX connector inside diameter is about 4.45mm to 4.5mm. Standard SMA inner diameter is about 4.6MM. Amazing that the difference is that close. I have measure about 5 different SMA connectors laying around and all of them are about 4.6MM. Looks to be power quality control on this "SMA" wannabe connector on the RX? I wonder if anyone else has ordered this same RX from Hobbywireless. I'll probably end up replacing the connector on the RX with a real SMA connector of some sort.
Old Jun 14, 2012, 01:10 AM
alexedit is offline
Find More Posts by alexedit
alexedit's Avatar
United States, FL, Miami
Joined Dec 2008
If it is an F connector you can just use this to make it ab sma
http://www.urbandrones.com/F-Male-to...ter_p_109.html
alexedit is offline Find More Posts by alexedit
Old Jun 14, 2012, 08:26 AM
ImAcracker's Avatar
Austin
Joined May 2006
It is not an F connector. The outer diameter of the connector is way to small to be an F connector.
Discussion Can someone tell me what this is bradenj Fuel Plane Talk 17 Jun 07, 2012 08:36 PM
Help! Can anyone tell me what heli this is? skyjacker07 Micro Helis 11 Dec 10, 2011 11:25 PM
Discussion Somebody can tell me what wrong with this motor? nexxa Electric Motor Design and Construction 4 Oct 14, 2011 11:49 AM
Question Can someone tell me what this is called? 3d astronaut DIY Electronics 0 Oct 13, 2011 12:21 AM
Sold Ill close tomorrow but can someone tell me if this is new or older version?? trex 500 blueindian Aircraft - Electric - Helis (FS/W) 1 Sep 26, 2011 03:24 AM
