Old Jun 13, 2012, 09:54 AM
old_dude is offline
Find More Posts by old_dude
Groundloop World Champion
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
Question
EDF Impeller Balance
Hi,
I'm in the process of balancing the fan of a HET 6404 EDF.
I'm using a Tower Hobbies magnetic balancer.
Seems the fan was balanced at the factory BUT my magnetic
balancer says the factory put the epoxy weight in the WRONG
place !! Yep, Every time I spin the fan the side with the factory
added weight comes out on the bottom
Has anybody experienced such an error by the factory ???
Old_dude
My first venture into the EDF world
old_dude is offline Find More Posts by old_dude
Old Jun 13, 2012, 10:45 AM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
There is a difference between static balance and dynamic balance. Have you tried running it up? HET are dynamic balanced.
Bob
bruff is online now Find More Posts by bruff
Old Jun 13, 2012, 11:07 AM
old_dude is offline
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
Waiting for the motor ... not yet.
Old Jun 28, 2012, 08:46 AM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
I was under the impression that dynamic balancing is done on the combination of both the fan and the motor married together. Seperating and not using the two components together would disrupt the combined balance. Am I wrong?
If I'm not wrong, then there's a possibility the factory motor used for the balancing is imbalanced itself. The factory would have added the weight to account for this during the process. The result would be a fan, that by itself, is not in balance. It would only be balanced on the motor it was calibrated on, and only if it remained in the same clock position on the motor shaft at the time of calibration.
I would readjust the weight as you see needed with your own balancing methods, since you don't have the full set up that the fan was balanced with.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Jun 28, 2012, 09:00 AM
ex-racr is online now
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
If you're talking about the Top Flite balancer, most of the shafts are not absolutely straight.
If it's bent a little, it'll give you misleading results.
If you use the finger tip balancer with the magnets you get much better results:
http://www3.towerhobbies.com/cgi-bin...?&I=LXK247&P=7
You should be able to move the fan by barely breathing on it. If you can't, there's too much friction somewhere.
FWIW, I've had to refine the balance of the 6904 70mm fans with little bits of tape to get them perfectly smooth.
It's also possible some one at the factory put the putty on the wrong side. It is HET after all
ex-racr is online now Find More Posts by ex-racr
Old Jun 28, 2012, 03:57 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
the rotor should have arrived balanced. half the rotors they send out are poorly balanced. same goes for wemo rotors. using a magnetic balancer is fine and gives the same end results as a dynamic
stoneenforcer is offline Find More Posts by stoneenforcer
Old Jun 28, 2012, 04:34 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
The over the counter magnetic balancer is good for 10" props but not for an edf impeller. the friction cones are molded out of whack. Du-Bro is about the best you can get easily and the shaft is ground hardened steel one cone is fixed while the other cone is twist lock and machined, the shaft rides on 2" wheels. Next best thing is a short Helli blade type machined, threaded, balance tool and your own mfg magnet towers. Factory dynamic balancing is done on a balanced low rpm motor and stroboscope(electronic) Efflux RC uses one!
The easiest way to tune an impeller is, mounted with lower voltage to feel for vibrations, loosen the nut, tweak the blade on the adpter shaft a few degrees, tighten down and do again and again until you get it smooth! Then try higher rpms otherwise you just may blow up your fan. Low rpms at the start of tweaking an impeller yields way less scrubbing and impeller tip damage. Ask me how I know!
ApexAero is offline Find More Posts by ApexAero
Old Aug 23, 2012, 06:44 PM
old_dude is offline
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
Epilogue
Well Guys,
i finally discovered that the motor was the source of the vibrations !!
Yes, I decided to change out Warp4 2-turn for a cheap C2835-3900KV. And, Walla.... very very little vibration and now I have a 400+ watt setup to power my HL/HK SkyRay EDF.
Old_dude
Old Nov 16, 2012, 04:24 AM
dynexhobby is offline
Find More Posts by dynexhobby
Good vibrations.
dynexhobby's Avatar
Joined Nov 2012
Might want to consider the Vortex. It will perform dynamic balancing.
www.dynexhobby.com
regards
DH
dynexhobby is offline Find More Posts by dynexhobby
Discussion Free Dynamic Balancer (good for turbine, EDF or prop balancing). dwalsh62 DIY Electronics 12 Nov 29, 2015 05:51 PM
Discussion Graupner Impeller Fans teckbot Electric Ducted Fan Jet Talk 5 Aug 01, 2012 09:58 PM
Sold Multiplex DF 69 Impeller Unit and Himax 2825-3600 Brushless EDF motor Jbray Aircraft - Electric - Power Systems (FS/W) 3 Jul 05, 2012 11:45 AM
gws edf 64 gw/edf-64 4600kv impeller housing MIKEYOUR Non R/C Items (FS/W) 0 May 03, 2012 11:45 AM
Discussion Free Dynamic Balancer (good for turbine, EDF or prop balancing). dwalsh62 Jet Turbines 13 Nov 24, 2011 06:40 AM
