Old Aug 24, 2012, 04:05 PM
Salinas, CA
Joined Dec 2007
Pulled the trigger today -- ordered the 450 pro FBL TT with electronic package.
jl449 is offline Find More Posts by jl449
Old Aug 25, 2012, 02:24 AM
asp
Spain, CN, La Oliva
Joined Apr 2012
Great! Keep us updated.
asp is offline Find More Posts by asp
Old Sep 06, 2012, 03:08 PM
Salinas, CA
Joined Dec 2007
Originally Posted by soneebee View Post
This is the mod that i did with the PRO
to fix this geometry problem of the PRo
Soneebee, can you elaborate on the geometry modification? I just got my V4 and planing to start building it this weekend.
maraming salamat Boss
Old Sep 06, 2012, 05:33 PM
Joined May 2006
well what i did was to push out the shaft a few ,mm out of the bevel gear. just to increase the shaft length by a few mm. then i used a demel tool to increase the shafts flat spot so as to get the blade grip holder to extend farthest from the end of the shaft. with this mod i have increased the shaft effective length by just a few mm's this will be enough to give the pitch a more positive side making the geometry a little close to equal pitches..
soneebee is offline Find More Posts by soneebee
Old Sep 07, 2012, 11:52 PM
Salinas, CA
Joined Dec 2007
Thanks Soneebee...
Old Sep 12, 2012, 01:55 PM
Salinas, CA
Joined Dec 2007
I've started my build a few days ago (taking my time). I have a question.....
What lenght should the linkage rod be adjusted to from the servos to the swash plate? Is it the same lenght in the Align Trex pro manual? 32.5mm x3 and 44.5mm x 2 for blade holder pitch?
Old Sep 13, 2012, 06:31 AM
Joined May 2006
For what type is this the fb or fbl heli you got so I can try any measure my helis link lengths
Old Sep 13, 2012, 02:18 PM
Salinas, CA
Joined Dec 2007
I got the Copterx 450 pro V4 FBL TT version.
Thank you Soneebee!!
Old Sep 13, 2012, 10:53 PM
Joined May 2006
ill try to measure my FBL heli later when i get home from work.. ill post the measurements
Old Sep 14, 2012, 05:15 AM
Norway
Joined Jun 2011
Hi!
Just got a complete CX V4 TT tail conversion kit in the mail to convert my V3 belt version. But, noticed that at max and min pitch there is parts hitting eachother. Is this normal? My belt version ones don't have this issue. And this problem will limit the max pitch quite alot.
TurboLeon is offline Find More Posts by TurboLeon
Old Sep 14, 2012, 10:11 PM
Joined May 2006
Yup I encountered this on the Pro TT version.. the L arm hits part of the Y arm at full defection .. i just limit the full extent throws so as the parts dont rub each other
Originally Posted by TurboLeon View Post
Hi!
Old Sep 15, 2012, 08:59 PM
Joined May 2006
Here is what i got from my PRO
Old Sep 16, 2012, 02:15 AM
Salinas, CA
Joined Dec 2007
Thanks again soneebee. I'm finishing up and I'm currently leveling the swash.
I got it all wired up and today I hooked up the laptop to the cx-3x1000 using the Jon_nz software. WOW first time doing this. I 'm upgrading from a blade400 which I had for over 4yrs and helis sure came a long ways. I got lots of reading to do. I got my dx6i setup for 120 degree swash and seems the elevator is acting pretty funny. Got lots of learning to do.
Old Sep 16, 2012, 09:55 AM
Joined May 2006
thats nice to hear jl449. hope to see some flight vids of your new project
Old Sep 17, 2012, 03:56 AM
rc aircraft crasher
United States, MI, Lansing
Joined Sep 2012
i have the black angel and its my favorite heli, you can buy buy different heads for it and yes it rock solid in flight with no vibration issues. and parts always available.
jnmardister is offline Find More Posts by jnmardister
Sold Copter X FBL unit and Tarot FBL head topgun22 Aircraft - Electric - Helis (FS/W) 1 May 17, 2012 10:46 AM
Sold 450 Heli Align / Copter X - SOLD PENDING PAYMENT kruiser7 Aircraft - Electric - Helis (FS/W) 0 Apr 22, 2012 02:06 PM
For Sale Copter x 450 I'n a heli artist 500 magnum pi fuse ROKJR56 Aircraft - Electric - Helis (FS/W) 0 Feb 11, 2012 02:01 PM
Discussion My new VWIN RC 450 Trex 450 clone from X copter. Ancient Pete Electric Heli Talk 2 Oct 11, 2011 06:50 PM
For Sale Trex 450 pro FBL beast x RTF Vuhuyhoang Aircraft - Electric - Helis (FS/W) 10 May 26, 2011 01:48 PM
