Old Aug 08, 2012, 04:30 AM
soneebee is offline
Find More Posts by soneebee
Joined May 2006
well I have crashed numerous times on a 450 heli with belt system.. in about a dozen of more crashes.. i have only replace the belt 1 time... but have replaced the boom a dozen times... shafts, blades and main gear.. but for the belt only once.
I guess when you crash with a boom hit.. normally the boom bends so the belt looses tension at this point it does not snap.. but there are instances that it does snap.. at times when the boom sticks to the ground and the belt is pulled out of the frame.... but this rarely happens i guess...
Originally Posted by MX48 View Post
What will happen on a hard tail hit with a belt drive, like in a moderate crash. Never had a belt drive before.
Moto
soneebee is offline Find More Posts by soneebee
Old Aug 08, 2012, 04:33 AM
MX48 is offline
Find More Posts by MX48
United States, GA
Joined Dec 2011
Thanks man, definitely will get a belt version. Stripped many gears on my V200D03 until I rigged up a clutch for it.
Moto
MX48 is offline Find More Posts by MX48
Old Aug 08, 2012, 10:43 AM
asp is offline
asp
Find More Posts by asp
asp
Spain, CN, Villaverde
Joined Apr 2012
That's exactly why I'm thinking to go with the belt version... Thanks
asp is offline Find More Posts by asp
Old Aug 08, 2012, 07:24 PM
soneebee is offline
Joined May 2006
For the belt version... just make sure the tension is correct as to save a little power and less load on the motor... of if you can get a thinner belt.. the one that align released for the SPORT.. or the one on the net the kevlar ones.. these belts are thin and will hug the pulleys lighly.. it will have less load on the motor
Old Aug 09, 2012, 01:11 PM
Torch8 is offline
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
trhodes,
It still looks like it ships form Hong Kong tho. Does just look like an offshoot of Ehirobo, probably the same.
Edit: They are the same, even the same P.O. Box.
Moto
Any US dealers carrying the Copterx BA FBL?
Torch8 is offline Find More Posts by Torch8
Old Aug 09, 2012, 03:43 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Unfortunately not. If you get it, you'll always have to order parts from ehirobo in HK. Nice bird otherwise, got one myself, but not US distributor.
Dr.M is offline Find More Posts by Dr.M
Old Aug 09, 2012, 03:47 PM
Torch8 is offline
Torch8's Avatar
NYC
Joined Aug 2010
Thanks.
Old Aug 09, 2012, 05:04 PM
asp is offline
asp
asp
Joined Apr 2012
Thin belt than.
Thanks for the whole lot of information!
Old Aug 18, 2012, 04:19 AM
asp is offline
asp
asp
Joined Apr 2012
Hey Soneebee, have you been flying your copter x more?
How about it? Thanks man.
Old Aug 18, 2012, 07:53 AM
soneebee is offline
Joined May 2006
I did fly some of my heli last weekend when i went the the field.. I tested the CX600 with the CX electronics... it worked fine.. power was really good.. although too much but it was a nice heli to fly....
Copter X 600E Pro (2 min 33 sec)
i also had a few flights the CX450PRO V4.. but I flew the BA more as I was more at in with flying the Black Angel...
Old Aug 19, 2012, 04:23 AM
asp is offline
asp
asp
Joined Apr 2012
http://www.youtube.com/watch?v=Xn5H4IKYl5Y
It seems like you don't like V4 too much?
Old Aug 19, 2012, 09:52 PM
soneebee is offline
Joined May 2006
It does fly okay... I have 3 PRO 2X V3 and the V4. all of these helis are in working order.. but 1of the V3's I converted to have a scale fuse
Copter X 450 PRO with Scale Fuse Jet Ranger (5 min 9 sec)
the other V3 is the belt version that eventually I did a complete conversion and restoration and turned it to a TT version which i was flying before
Copter X 450 PRO (0 min 35 sec)
and when i got hold of the new V4.. i did assemble this heli and placed all the CX electronics to test this out.. This came with the FBL head so it flies different from the other Pro's i have but its not really that different. Its just a little faster than the flybared but its still the same feel in flight...
If i will compare it with the other 450 helis from the CX line.
So far the best that I have tested runs in this order..
and these started way back 07 when the first ones came out
Copter X 450 Black Angel
Copter X 450 Black Angel PROTO
Copter X 450 SE V2
Copter X 450 Pro V4
Copter X 450 SE V1.5
Copter X 450 SE V1
Copter X 450 Pro V3 / V3.5
Copter X 450 AE
Copter X 450 ME
Copter X 450 XL
Now If I will try to rate the CX helis in order this is I guess what I will come up
Copter X 600E PRO
Copter X 450 SE V2
Copter X 450 Pro V4
Copter X 250 SE FBL
Copter X 250 SE
Copter X 450 SE V1
Copter X 450 AE
Copter X 450 ME
Copter X 200
Copter X 480 SE
Copter X 450 XL
tests were based on Copter X Electronics ( Fusonics servos, MGpower lipo, CX ESC)
older helis were based on older electronics ( Futaba GY401/9257, Castle creation ESC/ Hitec HS65Mg servos)
but so far the CX electronics that came out are kinda good. Never had any failures yet on the ESC and motors..
on the Fusonic servos these are forgiving servos (12g Mg's are good but the D-04 are far better even in resolution)
lipo packs are okay.. they are not really that powerful on hard 3D. I prefer the HC's Rhino's even at 30C's these really packs great power for its price.. as good as FP or TP before. The new Violet or light blue colored packs Nano techs... they are okay for the first few cycles but eventually loose its perk after more cycles on the packs...
Old Aug 21, 2012, 03:49 AM
asp is offline
asp
asp
Joined Apr 2012
http://www.youtube.com/watch?v=EHY078F5SvA
http://www.youtube.com/watch?v=9aeHKbfFptY
Copter X 450 SE V2
Copter X 450 Pro V4
Copter X 450 SE V1
Copter X 450 AE
Copter X 450 ME
Copter X 450 XL
Copter X 600E PRO
Copter X 450 SE V2
Copter X 450 Pro V4
Copter X 250 SE FBL
Copter X 250 SE
Copter X 450 SE V1
Copter X 450 AE
Copter X 450 ME
Copter X 200
Copter X 480 SE
Copter X 450 XL
Wow, thank you so much... Very useful info here
Old Aug 21, 2012, 05:27 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Does CopterX sell a 250 FBL kit?
ridge_racer is offline Find More Posts by ridge_racer
Old Aug 22, 2012, 04:58 AM
asp is offline
asp
asp
Joined Apr 2012
Yes. Check ehirobo has it.
Discussion My new VWIN RC 450 Trex 450 clone from X copter. Ancient Pete Electric Heli Talk 3 Nov 10, 2014 04:40 AM
Sold Copter X FBL unit and Tarot FBL head topgun22 Aircraft - Electric - Helis (FS/W) 1 May 17, 2012 10:46 AM
Sold 450 Heli Align / Copter X - SOLD PENDING PAYMENT kruiser7 Aircraft - Electric - Helis (FS/W) 0 Apr 22, 2012 02:06 PM
For Sale Copter x 450 I'n a heli artist 500 magnum pi fuse ROKJR56 Aircraft - Electric - Helis (FS/W) 0 Feb 11, 2012 02:01 PM
For Sale Trex 450 pro FBL beast x RTF Vuhuyhoang Aircraft - Electric - Helis (FS/W) 10 May 26, 2011 01:48 PM
