Espritmodel.com Heli Air
Old Jun 13, 2012, 08:01 AM
Joined May 2006
New Copter X 450 PRO V4 FBL heli
I got hold of the new Copter X 450PRO V4.
The new version has upgrades that make it more hard core 3D capable.
The new head is almost the same as the standard FBL PRO head for the V3 but the new one
has a more cleaner finish. the bearings are smooth.. and the new swashplate
is much much better than the old PRO.. this one contains a more smoother bearing and the actual finish is quite good..
Old Copter X pro Swash Plate
Copter X 450 PRO swash VS Black Angel Swash (1 min 0 sec)
New Copter X pro Swash Plate
New Copter X 450 PRO V4 swashplate (0 min 35 sec)
The framework is the same as the old PRO. The only difference I found are the new servo holders. These have better finish.. the aluminum is somewhat matte finished and look to be made of a different kind of aluminum alloy...
other parts seems to be same as the OLD PRO
another upgrade is the tail boom. The new PRO comes with CF tail boom..
very nicely finished..
The tail assembly is another thing that I found to be upgraded.. and WOW what a big change. The quality of the finish is far better than the V1.. The L arm is not metal and the bearings used are really smooth..
and it comes with CF tail blades..
so basically the new PRO kit has all the parts in CF. and the new parts are far better quality than the V3 PRO...
the main blades are also Carbon fiber.. designed for the FBL system
Now the most impressive upgrade is Copter X Canopies.
The new 450 PRO has really good finished canopy.. Gelcoated
and pre painted fiber glass canopy...
The design looks like it came from its larger brother the CX600PRO..
ill get this little gem up and running to see what the new Copter X Pro V4 can offer...
soneebee is offline Find More Posts by soneebee
Old Jun 13, 2012, 11:23 PM
Seattle Area
Joined Aug 2007
Was that from ehirobo for $100? Just their tail blades are plastic it seems. Everything looks the same as your pics... Looks like a heck of a deal ---- http://www.ehirobo.com/shop/product_...ducts_id=11908
eagle777 is offline Find More Posts by eagle777
Old Jun 13, 2012, 11:38 PM
United States, NY, New York
Joined Nov 2010
OP...states that the carbon tail blades are included. Good deal regardless.
ridge_racer is offline Find More Posts by ridge_racer
Old Jun 14, 2012, 12:09 AM
Seattle Area
Joined Aug 2007
I see what I said in my OP Sorry about that OP. Sheesh.
Old Jun 14, 2012, 06:01 AM
Joined May 2006
Yup unit came from eHIROBO...
The heli seems to be upgraded and has better parts.
Ill have to get this up and running to compare it with the original PRO heli
Old Jun 16, 2012, 10:57 PM
Joined May 2006
I got the heli built the other night..
used following electronics to complete the little gem.
Motor : Copter X 3550KV outrunner motor
ESC: Copter X 40A ESC
Servos: Fusonic MG-D04 for cyclics/Fusonic 9257MG for tail
Gyro: Copter X CX3X1000 FBL gyro
The heli looks no different from my old CX 450 PRO V3 heli its mostly the color that changed from the anodized blue to the new Black anodized aluminum...
although the parts on the CX450PRO V4 seems to be better.
The head is nice although its no DFC but it kinda works nicely
the CF boom is kinda cool... test hover was a pain.. as it had the wobbly shakes i never encountered on the Copter X Black Angel. I have the same shakes on the CX500 but had to look for the cause of these vibrations. that tend to shake the hell of the gyro's brain...
Old Jun 16, 2012, 11:09 PM
Seattle Area
Joined Aug 2007
Why do you say it's no DFL head? Are the long control arms on the grip a liability? I am new to FBL, but have RJX and Copter X heads. Still learning.
Old Jun 17, 2012, 12:01 AM
Joined May 2006
oops.. sorry wrong letter typed in.. I meant its no DFC head...
Old Jun 17, 2012, 12:17 AM
Seattle Area
Joined Aug 2007
I repeated your DFC mistake, (DFL DFC) But what is better about the Align head than this?
Old Jun 17, 2012, 01:39 AM
Joined Nov 2010
DFC head sits lower so it lowers the CG of the rotor head. Also you lose the washout arms.
Old Jun 17, 2012, 02:12 AM
Seattle Area
Joined Aug 2007
Appreciate the answer, thanks. I always thought the head sat pretty high above the frame FWIW.
Old Jun 17, 2012, 02:46 AM
Joined May 2006
Well i guess the new DFC head as less likely phasing problem....
Old Jun 17, 2012, 02:48 AM
Joined May 2006
Well still need to get the bugs out of this PRO V4 heli. I am still getting little tail wagging.. but have reduced the vibrations...
The first hover test turned out to be a tree cutter,, hehehe,,
Copter X 450 PRO V4 FBL first maiden hover test (3 min 1 sec)
Old Aug 03, 2012, 07:55 PM
asp
Spain, CN, La Oliva
Joined Apr 2012
Very nice... Keep up news about this heli. It seems to be vey interesting.
asp is offline Find More Posts by asp
Old Aug 07, 2012, 12:46 AM
Joined May 2006
Got the heli the other day at our local field. Heli flies better now with the tail modification i did. Still a little more tweaks with the gyro and this heli will fly good
Sold Copter X FBL unit and Tarot FBL head topgun22 Aircraft - Electric - Helis (FS/W) 1 May 17, 2012 10:46 AM
Sold 450 Heli Align / Copter X - SOLD PENDING PAYMENT kruiser7 Aircraft - Electric - Helis (FS/W) 0 Apr 22, 2012 02:06 PM
For Sale Copter x 450 I'n a heli artist 500 magnum pi fuse ROKJR56 Aircraft - Electric - Helis (FS/W) 0 Feb 11, 2012 02:01 PM
Discussion My new VWIN RC 450 Trex 450 clone from X copter. Ancient Pete Electric Heli Talk 2 Oct 11, 2011 06:50 PM
For Sale Trex 450 pro FBL beast x RTF Vuhuyhoang Aircraft - Electric - Helis (FS/W) 10 May 26, 2011 01:48 PM
