Old Jun 13, 2012, 07:50 AM
philtyphil is offline
Find More Posts by philtyphil
I'm still a big kid
philtyphil's Avatar
Australia, NSW, Oyster Bay
Joined Jan 2012
Problems with brand new Turnigy 9X transmitter
Just received today.
Put in batteries & the beeping starts.
Screen reads "switch error"
Any clues? anyone?
Phil
philtyphil is offline Find More Posts by philtyphil
Old Jun 13, 2012, 07:51 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Check all the switches are in their neutral positions.
Common problem.
Teamsherman is offline Find More Posts by Teamsherman
Old Jun 13, 2012, 08:06 AM
I'm still a big kid
philtyphil's Avatar
Joined Jan 2012
You Ripper
Thank goodness.
It nearly hit the wall (literally!)
Now I just have to learn how to program it!
Thanks for your help.
Phil
Old Jun 13, 2012, 08:32 AM
.Joel is offline
Find More Posts by .Joel
.Joel's Avatar
Australia, VIC, Melbourne
Joined Dec 2011
Flash it with the ER9X firmware and you won't look back! I did mine and it's simply brilliant.
.Joel is offline Find More Posts by .Joel
Old Jun 13, 2012, 09:32 AM
vvV FANG Vvv is offline
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Eurongilly
Joined Aug 2008
Yep with the firmware upgrade its awesome!
Get a smartieparts board and your all set, makes life so much easier!
vvV FANG Vvv is offline Find More Posts by vvV FANG Vvv
Old Jun 13, 2012, 10:08 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
ahh the old turnigy. If only every radio had a "snoproll" switch
Curare is offline Find More Posts by Curare
Old Jun 14, 2012, 12:39 AM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
Just wondering what system those with the 9X are using? Ive heard the Frsky is good?
ozzi supercub is offline Find More Posts by ozzi supercub
Old Jun 14, 2012, 02:39 AM
ace185 is offline
Find More Posts by ace185
Australia, NSW, Spring Farm
Joined Sep 2011
I use the frsky and I find it very good with the rx modules still very resonably priced. I had some interference issues near a cell phone tower on the standard Turnigy rx (several Spektrum Radio tx/rx guys have lost planes at this location due to the same interference) but those issues were not present with the frsky tx/rx system.
Telemetry is also available with Frsky modules if you want to go down that path. I haven't found programming an issue with this radio so I can't comment on the smartipants board change.
Consider also getting a lipo transmitter battery - Hobbyking do one ($15) that you just need to change the battery connector on - you can cut the one of the standard battery carrier. You only need to charge every month or so!
ace185 is offline Find More Posts by ace185
Old Jun 14, 2012, 03:05 AM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Er9x and Open9x are both so much better than the standard firmware that it's hardly worth perservering. Flash it and never look back. Virtually all of the open source 9X firmware builds have features to shame $1000 radios.
Someone suggested the smartieparts board. An excellent solution, but they're sometimes difficult to get because demand far outstrips supply. If you're alright with fiddly soldering, this works well too, for a total outlay of $3.98 including shipping
http://www.ebay.com.au/itm/USBASP-IS...item4163581873
Module-wise, if you just want to upgrade to FrSky with a minimum of fuss, the JR module is a drop-in replacement. Otherwise, for those who like soldering, the "hack" (DHT) module has several advantages, because it's easier to integrate with telemetry than having to pipe everything back into the Tx from the back of the JR module.
H2SO4 is online now Find More Posts by H2SO4
Old Jun 14, 2012, 06:18 AM
GlennS is offline
Find More Posts by GlennS
Flying 3 mistakes high
GlennS's Avatar
Melbourne, Australia
Joined Jun 2004
I am using FrSky and reflashed with TH9X software. Really impressed. I only bought it for an experiment and now use it with the foamies all the time.
GlennS is offline Find More Posts by GlennS
Old Jun 14, 2012, 11:55 AM
planex is offline
Find More Posts by planex
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
http://www.rcgroups.com/forums/showthread.php?t=1266162
planex is offline Find More Posts by planex
For Sale FS-TH9X Turnigy 9X RC Transmitter - Upgraded to er9x & backlight Brand New! MitchellY Aircraft - General - Radio Equipment (FS/W) 0 May 24, 2012 11:11 PM
For Sale BRAND NEW Turnigy 9X with ER9X, SmartieParts Board Joelmusicman Aircraft - General - Radio Equipment (FS/W) 3 May 18, 2012 10:42 AM
For Sale Brand New Turnigy 9x with ER9X TyCarp Aircraft - General - Radio Equipment (FS/W) 9 Mar 11, 2012 11:43 AM
Help! PPM problem with Turnigy 9x + HK-TR6A V2 Multicopter Radios 1 Jan 09, 2012 04:53 PM
Sold Turnigy 9x Transmitter with the Smartie Parts board and a blue LED backlight + RXs major.monogram Aircraft - General - Radio Equipment (FS/W) 7 Sep 29, 2011 03:28 PM
