Old Jun 12, 2012, 11:32 PM
signal15 is offline
Find More Posts by signal15
Atomic Playboy
United States, MN, Inver Grove Heights
Joined Jun 2012
Interesting idea for setting gains/PIDs
I was doing this with my KK board tricopter tonight, but had to stop because my servo went bad. Until the servo failed, it really seemed like a good way to adjust the gains... if not a little dangerous.
The KK board is running 1.6 acro. So as I understand:
Yaw pot = P and I for yaw
Roll pot = P for roll and pitch
Pitch pot = I for roll and pitch
So my plan is/was to hold it level over my head at half throttle. Then:
- Adjust trims so it doesn't feel like it's tilting in any direction
- Adjust yaw pot, twist it quickly and see if it oscillates side to side. If not, increase gain. If so, decrease.
- Adjust roll pot. Roll or pitch it by hand or with stick, feel for oscillation. Increase gain if none, decrease if some.
- Lightly move tricopter laterally in any direction and feel it try to move back to the original position. Adjust Pitch pot (I).
I am assuming I'm testing each one of these correctly. Remember the 1.6 firmware doesn't do what the pots say. They are P, I, and P+I for yaw. If anyone has a better way to test, I'm all ears. I keep crashing when I fly it, and I cannot keep it hovering long enough to figure out where the pots need to be. I'm just trying to at least get it as good as possible before I take it up again.
Thoughts? Suggestions on better ways to twist/turn/tilt it for testing each pot?
signal15 is offline Find More Posts by signal15
Old Jun 13, 2012, 01:42 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
If the trims and/or gains are way off then that's not a bad way to test... just be careful of those props!!
Set up a throttle curve (or endpoint) that prevents you applying full throttle, so that you can't accidentally knock the stick and rip it out of your hand.
Hold it out sideways and out to the side instead of over your head, so it can't fall on you if you lose your grip. It does not have to be held horizontal if your board is an ordinary KK and does not have accelerometers.
Once you've got it roughly set up and trimmed, do some test flights to fine tune the gyros and trim. Holding it in your hand will affect the gyro operation because you'll probably dampen the movements a bit.
mattcro is offline Find More Posts by mattcro
Old Jun 13, 2012, 02:04 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Ya, matts on it. Was going to mention you'll notice some difference in actual flight and wind as well. I also found thermal drift is huge on mine. If its sunny out, after 1 minute flight itll vear off sharply. Disconecting lipo and waiting a couple minutes solves it.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Jun 13, 2012, 04:29 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
You only need to lower the throttle to zero for a few seconds to get rid of thermal drifting.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Jun 13, 2012, 05:38 PM
signal15 is offline
Atomic Playboy
Joined Jun 2012
I grabbed a new servo that truly has all metal gears in it (Spektrum A4020). Tonight I was able to hold the thing above my head and start doing some adjustments. It's WAY better than it was when I started. It really wanted to drift all over the place and oscillate before.
I've got Yaw at about 10%, Roll at 5%, and Pitch at 25%. Reducing the roll pot really reduced the drift, and reducing the roll pot significantly reduced pitch and roll oscillations.
One thing I noticed though, when I put the rudder stick to the right, the rear motor doesn't tilt at all, but works fine in the other direction. I thought it might be the servo, but I put the servo directly into the transmitter, and it's got full travel in both directions. I haven't flown it outside yet, waiting for my battery to charge. Maybe it's a non-issue, but it sure seems like something is up.
Discussion Interesting house idea dll932 Life, The Universe, and Politics 11 Jun 05, 2012 11:28 AM
Discussion Interesting idea dll932 Life, The Universe, and Politics 7 May 26, 2012 09:27 AM
Discussion What to look for when setting main gain? rkenosha Hoverfly Technologies 3 Mar 03, 2012 07:52 AM
Discussion Ideas for a 25Kw set up wanted - Full scale OzparkPilot Giant Electric Planes 5 Oct 27, 2011 07:01 PM
Careful! SOLVED: Setting EPA for AL on 3 way switch - 0 gain switch of death tahoelight Hoverfly Technologies 5 Oct 25, 2011 09:41 PM
