Old Sep 13, 2012, 11:13 AM
phillip57 is offline
Find More Posts by phillip57
S/E Michigan
Joined Jun 2010
The upper wing is secured to the cabanes with nylon bolts.
phillip57 is offline Find More Posts by phillip57
Old Sep 13, 2012, 05:50 PM
Chompwat is offline
Find More Posts by Chompwat
Tally Ho Chaps!
Chompwat's Avatar
United Kingdom, England, Ipswich
Joined Mar 2012
Your summer break has obviously spurred you on Phillip. The build is coming along nicely and looking good. The Goering scheme is going to look superb.
Chompwat is offline Find More Posts by Chompwat
Old Sep 13, 2012, 07:11 PM
S/E Michigan
Joined Jun 2010
Thanks, I had some time away from the bench, now we're back at it. Ought to maiden her before thanksgiving... maybe even halloween! Next up is to install the HS-45's in the wing. I haven't had good luck printing on decal paper, so I bought a set of Northeast Screen Graphics WWI Water slide decals. Kinda pricey, then so is the decal paper. The Screen Graphic decals look far better than anything I could print. Perhaps I need another printer.
Old Sep 14, 2012, 11:21 AM
S/E Michigan
Joined Jun 2010
Lower wing ip strut attachment...
Old Sep 17, 2012, 04:15 PM
S/E Michigan
Joined Jun 2010
The covered aileron is installed.
Old Sep 19, 2012, 06:38 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Very nice build!
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Sep 19, 2012, 08:57 PM
S/E Michigan
Joined Jun 2010
Well, thank you.... it won't be a museum piece, but if she flies well, I'll be happy. The head rest is a hollowed out block of laminated scrap. The instructions with the decals said to lightly rub the surface with 600 grit paper for a flat finish. Well, the surface is not smooth, and very thin. The decal was touched up with flat black, matching the finish on the fuselage, which is kind of rough. I imagine the original wasn't much better.
Old Sep 19, 2012, 09:51 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
I think that this is one of Aerdrome R/C's better flyers - and they generally fly very well. I have a 66" Eindecker that flies like a dream with wing warping.
Site Sponsor
Old Sep 19, 2012, 10:36 PM
S/E Michigan
Joined Jun 2010
I saw your thread and video, Very nice! Is the wing warping in the plans? Or did you do the mod yourself?
Old Sep 19, 2012, 11:24 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
I did the mod myself, which was actually less work than doing the ailerons in the plans.
Site Sponsor
Old Sep 22, 2012, 02:57 PM
NOISY MUSE is offline
Find More Posts by NOISY MUSE
USA, Mt, Billings
Joined Mar 2009
Originally Posted by phillip57 View Post
Flat black Humbrol brushed on the fuselage
Do you prime the Doculam at all or just paint on.
Oil based? Enamel? Acrylic? Does it matter?
Got this kit under the bench with all the bulk wood called out in the bill of materials packaged up next to it. Need to get it out and build it.
NOISY MUSE is offline Find More Posts by NOISY MUSE
Old Sep 23, 2012, 04:06 PM
S/E Michigan
Joined Jun 2010
I have not primed the doculam. Have used both enamel and acrylic, I like the enamel more. Enamel adheres better, it is possible to mask using low adhesion tape. Have masked on acrylic as well, but the acrylic seems to come up with the tape easier, requiring more touch up.
For Sale 1/3 scale Albatros Dv or Dva spinner mcjustis Aircraft - General - Miscellaneous (FS/W) 3 Oct 29, 2014 01:40 PM
Sold Aerodrome RC 54" Albatros D.Va Kit Wolpertinger Aircraft - Electric - Airplanes (FS/W) 2 Apr 16, 2012 09:52 AM
Build Log 1:24 scale DVa Albatros - non ar6400 nemoskull Scratchbuilt Indoor and Micro Models 3 Apr 10, 2012 03:10 PM
AerodromeRC 36" Albatros DVa AerodromeRC Scale Kit/Scratch Built 0 Jul 24, 2005 04:07 PM
