Old Jun 29, 2012, 11:17 AM
S/E Michigan
Joined Jun 2010
I very much looking forward to flying this one!
phillip57 is offline Find More Posts by phillip57
Old Jul 16, 2012, 08:24 PM
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
coming along very nicely mate.
Cheers
Craig
trumps is online now Find More Posts by trumps
Old Jul 17, 2012, 05:36 AM
Tally Ho Chaps!
Chompwat's Avatar
United Kingdom, England, Ipswich
Joined Mar 2012
Originally Posted by phillip57 View Post
Progress is slow, other projects to contend with...
But progress nonetheless. Looking good!
Chompwat is offline Find More Posts by Chompwat
Old Jul 17, 2012, 05:39 AM
Tally Ho Chaps!
Chompwat's Avatar
Joined Mar 2012
What adhesive do you use for fixing the planking?
Old Jul 17, 2012, 06:40 AM
S/E Michigan
Joined Jun 2010
Been using thin ca. A small drop will crawl along a join quite a distance.
Old Jul 17, 2012, 07:37 AM
What's 3D?
trumps's Avatar
Joined Feb 2008
heya mate, you should give some ambroid a try, ( balsa cement ) it is great for planking, obviously takes longer to dry than CA, but quicker than aliphatic, and it sands beautifully,
which is a real bonus when dealing with thin planking.
Craig
Old Jul 22, 2012, 07:52 PM
S/E Michigan
Joined Jun 2010
Thanks for the suggestion Trumps. I used to use Ambroid exclusively.... before I discovered ca. For some things I find infinite patience, other times it goes away. This is why I'll never be an ultra scale modeler.
Old Jul 27, 2012, 03:08 PM
S/E Michigan
Joined Jun 2010
dummy motor
There was no string of appropriate diameter for simulating cooling fins, so 20lb. test nylon fishing line was used.
Old Jul 27, 2012, 05:41 PM
S/E Michigan
Joined Jun 2010
I am informed the Mercedes was water cooled... no fins. Well, mine will be the only air cooled Albatros. Cooked rear cyliders and all!
Old Jul 27, 2012, 06:32 PM
Seven Swabians
Shnokey's Avatar
United States, MA, Holliston
Joined May 2004
Sounds cool - Pun Intended -
Shnokey is online now Find More Posts by Shnokey
Sold Aerodrome RC 54" Albatros D.Va Kit vonJaerschky Aircraft - Electric - Airplanes (FS/W) 2 Apr 16, 2012 08:52 AM
Build Log 1:24 scale DVa Albatros - non ar6400 nemoskull Indoor and Micro Models 3 Apr 10, 2012 02:10 PM
For Sale 1/3 scale Albatros Dv or Dva spinner mcjustis Aircraft - General - Miscellaneous (FS/W) 1 Dec 13, 2011 05:53 AM
AerodromeRC 36" Albatros DVa Bengtson Scale Electric Planes 0 Jul 24, 2005 03:07 PM
