Thanks for the flight report Rudd.
That sounds very wierd indeed. I started with the factory CG (cheers mate for that!). It was OK but the plane was wagging a bit. I moved the battery forward in the compartment, which is not a lot as the compartment is not much bigger than my batt. The plane did fly better a bit after that. I did not have that porpoising with throttle cut. It sounds like a thrust line issue. Did your EDF get misaligned in the plane by any chance? Or did you have some mix on? I also did shave off the black plastic thing over the exhaust that was overhanging the exhaust and interrupting the airflow, as advised by you. Good call on that. I just saw this video today and I'm looking forward to the 68mm 10 bladed 4S alloy EDF from HK. I am guessing that it won't break the bank. Scott mentions that there is going to be a 4 cell version at the 1:28 mark.
Hi Rudy and Korts
casey fields is one place we use to fly at 2 years ago in the middle of that bike track. But I believe if you fly there now you will get kicked off They have band flying in Casey and that is one place they patrol.... I know some guys that have been told to pack up and don't come back. |
worse by cricketters
cheers for posting,good looking birds i have a gws that i still have to build,it has been advised to me to keep the stock edfs and get het motors for them,the big wings put me off at first but then i thought that it would be a great first twin edf to start with,i have already in project to cut the wings like you did,apart from the looks, does it make a VERY noticeable difference with them cut?
Joined Feb 2007
No negative effects. It only gets better. Still has a great glide slope and lands slow. I had this power system iin my last GWS f -15. It was the EPO version of this kit with the full wing and it was about 10mph slower based on a doppler. This kit should have the wing clipped at the factory.
i'm with you,anyways it looks wrong with those massive wings and above all not scale at all,
i know it has nothing to do with f-15's but here is all we could do this week-end,as usual weather was crap i was an angry bird![]()
the onboard cam of that session
| Thread Tools | |
| Discussion Sky e Matser F-15 EDF | RCPLIOTTW | Electric Ducted Fan Jet Talk | 416 | Mar 11, 2013 09:33 PM |
| Discussion Byron F-15 EDF conversion | inpieces | Electric Ducted Fan Jet Talk | 61 | Feb 27, 2013 01:10 AM |
| For Sale nib gws twin 64mm edf f-15 kit with xtras 130 shipped | crash8384 | Aircraft - Electric - Jets (FS/W) | 0 | Apr 18, 2012 11:44 PM |
| For Sale SKYANGEL F-15 Twin 35mm EDF RC Fighter Jet | www.hobbyb.com | Aircraft - Electric - Jets (FS/W) | 14 | Apr 07, 2012 01:16 PM |
