Old Oct 25, 2012, 08:26 AM
F15ROCKETSHIP is offline
Find More Posts by F15ROCKETSHIP
Joined Oct 2012
are these good for the STARMAX F-15? http://www.hobbyking.com/hobbyking/s...g_1_Pair_.html
F15ROCKETSHIP is offline Find More Posts by F15ROCKETSHIP
Old Oct 25, 2012, 09:08 AM
korts04 is offline
Find More Posts by korts04
korts04's Avatar
Australia, VIC, Cranbourne
Joined Jun 2012
Originally Posted by rudeboy579 View Post
jeff here is the vid of the super sabre maiden filmed by marc,cheers for te great bird jeff i love it!!!!
enjoy:
http://www.youtube.com/watch?v=DjPet...ature=youtu.be
Wow rudey that jet looks and sounds f@#kn awsome bro i hope i get to see it fly at pp this weekend
korts04 is offline Find More Posts by korts04
Old Oct 25, 2012, 03:19 PM
rudeboy579 is offline
Find More Posts by rudeboy579
" EMBRACE THE DARK SIDE '
rudeboy579's Avatar
Joined Nov 2011
no rocket,the rotate 90 deg when they retract.get those ones:http://www.hobbyking.com/hobbyking/s...5mm_Mount.html
just put a grub screw to make it fix
rudeboy579 is offline Find More Posts by rudeboy579
Old Oct 25, 2012, 03:23 PM
rudeboy579's Avatar
Joined Nov 2011
what power system are you using,rocket mate when you get to the hobbyking site there is a collm on your right,scrolling through them would save you a lot of questions that already have answers rocket,do your research properly mate and let us know how you go
cheers rudy
Old Oct 25, 2012, 03:45 PM
Joined Oct 2012
Rudy these are the specs i chose (unless they suck):
1. Motor:
http://www.hobbyking.com/hobbyking/s...er_4400KV.html
2. Battery: Turnigy 2200mAh 4S 35C Lipo Pack http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
3.Servos: Need Help here Urgent
4.ESC: http://www.hobbyking.com/hobbyking/s...C_4A_UBEC.html
5. Transmitter: http://www.hobbyking.com/hobbyking/s...Firmware_.html
6. the retract: http://api.viglink.com/api/click?for...13511979443851
Old Oct 25, 2012, 03:52 PM
Joined Oct 2012
cant figure out what charger to get
Old Oct 25, 2012, 10:19 PM
rudeboy579's Avatar
Joined Nov 2011
hi rocket
transmitter good
retracts good
servos:http://www.hobbyking.com/hobbyking/s...cro_Servo.html when they get in stock or there is my friend here who sells tower pro sevos which are almost the same as the hxt 900 from h.k :http://www.ebay.com.au/itm/3-x-Micro...item4abbfd9e98
i use the same sevos in my fibreglass f-16 they are pretty tough and metal gear too.he posts worldwide too,tell him that i referred you to him.
so from what i see you what to be using the stock fan and putting that turnigy motor in,you do know that there is a fair bit of balancing to do to get thm running smoothly,if you are not on a budget i do advise you to go for the extremerc combos:http://www.extremerc.com.au/estore/i...oducts_id=1101 they are not that expensive when you think of what you are getting is ready to go,now i do not know if you will have trouble getting the motor i the housing as i do not know what's the diameter of your motor compartment in your edf,esc go for the hobbywing http://www.extremerc.com.au/estore/i...roducts_id=148 :,once more they are the toughest and the most durable ones,saves you heaps of crashes and therefore money rocket
Old Oct 25, 2012, 10:22 PM
rudeboy579's Avatar
Joined Nov 2011
for the charger i'm using this one :http://www.hobbyking.com/hobbyking/s...cessories.html
works great with the 4s
Old Oct 26, 2012, 01:02 AM
rudeboy579's Avatar
Joined Nov 2011
cheers bro,doesn't look like it bro shez next on packing
Old Oct 26, 2012, 07:06 AM
Joined Oct 2012
last question
how many servos of the hxt900 should i get? (it says on the hobby king required section of the starmax F-15 that i need 9X 9g servos and 1X 17 g servo... i have no idea what this means>?)
and is my battery okay for the Lightning ESC?
Old Oct 26, 2012, 07:07 AM
Joined Oct 2012
and how many retracts?
Old Oct 26, 2012, 07:13 AM
rudeboy579's Avatar
Joined Nov 2011
you only need 5 hxt900(aileron 2,elevator 2,steering 1) as you are using servoless for the retracts,for the battery i would reccommend extremerc's packs :http://www.extremerc.com.au/estore/i...oducts_id=1237
you could go nanotec but the lifespan is not as good as extreme's one's or near it
Old Oct 26, 2012, 07:16 AM
rudeboy579's Avatar
Joined Nov 2011
3 servoless for the retracts
Old Nov 03, 2012, 06:51 AM
pyrojets is offline
Find More Posts by pyrojets
Joined Apr 2011
Anyone knows where is the cg for the starmax F15? Lost my manual. Thank you.
pyrojets is offline Find More Posts by pyrojets
Old Nov 04, 2012, 05:05 PM
pyrojets is offline
Joined Apr 2011
Anyone?
Discussion Sky e Matser F-15 EDF RCPLIOTTW Electric Ducted Fan Jet Talk 584 Apr 25, 2016 02:37 PM
Discussion Byron F-15 EDF conversion inpieces Electric Ducted Fan Jet Talk 66 Aug 30, 2014 07:18 PM
For Sale nib gws twin 64mm edf f-15 kit with xtras 130 shipped crash8384 Aircraft - Electric - Jets (FS/W) 0 Apr 18, 2012 11:44 PM
For Sale SKYANGEL F-15 Twin 35mm EDF RC Fighter Jet www.hobbyb.com Aircraft - Electric - Jets (FS/W) 14 Apr 07, 2012 01:16 PM
