Old Jul 31, 2012, 06:42 PM
danfitz is offline
Find More Posts by danfitz
danfitz's Avatar
United States, CA, Vista
Originally Posted by vespa View Post
No combat. Certainly most radios don't offer the luxury of mode switching on the stick and thus require you to let go and fiddle for switches at crucial moments. That's just the way it is (was) and there's no judgement to be made. If one can adapt to a new style however, Giuseppe's approach is the most intuitive and effective method available. I use a Futaba 8FG which has this same ability and I set it up the exact same way long ago. It's the only intuitive solution I can imagine so I was surprised to see others so shocked by it.
I think your imagination is broken..
danfitz is offline Find More Posts by danfitz
Old Aug 04, 2012, 11:38 AM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
New DX18 has landed
Guys,
I have just this week received my new DX18 and hope to get started playing with it this weekend. I have already found one thing to add to my wish list on the TX and that is for a Tail Option with Dual Elevators in the Glider Mode. That would make it a lot nicer for Scale. I have not tried it yet, but I assume I will be able to just mix elevator with AUX2 and plug my second elevator in accordingly to achieve this, but I would think that would be an easy software upgrade that could be added in future updates. Looks to be a pretty straightforward radio and with the help of Shermans articles it will be even easier.
See Ya,
Pat
pmccleave is offline Find More Posts by pmccleave
Old Aug 04, 2012, 05:15 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Cool Pat,
Hey out of curiosity, what glider are you flying that is using two elevator servos?
Have fun with it.
FLY F3B is offline Find More Posts by FLY F3B
Old Aug 04, 2012, 05:17 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Originally Posted by FLY F3B View Post
Cool Pat,
Have fun with it.
Prolly a big scalie
tkallev is offline Find More Posts by tkallev
Old Aug 04, 2012, 05:27 PM
USA, KS, Wichita
Joined Sep 2002
Dual Elevators
Hey Mike,
TK hit the nail on the head. It is one of the new Phoenix Models 6M K8B.
See Ya,
Pat
Cool Pat,
Have fun with it.
Old Aug 05, 2012, 05:07 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
Yeppers...Thats a big scalie
There is no harm in the ole' Y harness bit for dual elevator servos. Or you could always assign 2 Rx ports to the elevator channel. You just won't have individual adjustments. Your mix idea might be the best way to have what you want.
Old Aug 07, 2012, 08:49 AM
USA, KS, Wichita
Joined Sep 2002
Does anyone know if there is vario that is compatible with the Telemetry Modules for the DX18. I may be missing it but I have not been able to find one yet. I see they have an altimeter available but I have not seen a vario.
Pat
Old Aug 07, 2012, 08:58 AM
Westranm is offline
Find More Posts by Westranm
Westranm's Avatar
United States, AZ, Chandler
Joined Jan 2011
Pat
I have used this successfully: http://www.wingedshadow.com/thermalscout.html
They sell a cable to attach the device to the TM1000.
-Randy
Westranm is offline Find More Posts by Westranm
Old Aug 08, 2012, 12:21 PM
tewatson is offline
Find More Posts by tewatson
Riddle me this...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Charging question
It appears the supplied charger is simply a (12v?) power supply for an internal charging circuit. Thus, charging with anything else requires removing the pack...correct? Since the power supply is AC-sourced, field charging could become a bit of a pain unless a DC-sourced solution is developed.
Tom
tewatson is offline Find More Posts by tewatson
Last edited by tewatson; Aug 08, 2012 at 12:39 PM. Reason: Revised question after RTFM
Old Aug 08, 2012, 12:37 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
I think that there exists a warning to NOT use a lipo charger through the transmitter jack.
I believe that the Wall wart is just a 12v power supply that is designed specifically for the board in the transmitter. Charging the batter outside of the transmitter with a Lipo charger should be possible, but might require splicing on a charge tap lead.
Let me know how you like the 18 Tom.
Old Aug 08, 2012, 12:48 PM
tewatson is offline
Riddle me this...
tewatson's Avatar
Joined Oct 2006
Don't yet have it...just been reading up on things. If the internal charger in fact needs only a constant 12v supply, field charging could be as simple as building a charge lead that just connects to one's flight bag battery (in my case, a 7Ah gel cell).
Tom
Old Aug 08, 2012, 03:47 PM
vespa is offline
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
12V is easy. Either omit the charger and wire directly to your field battery or set your field charger for lead acid.
vespa is offline Find More Posts by vespa
Old Aug 08, 2012, 05:14 PM
Craig Greening is offline
Find More Posts by Craig Greening
Horizon Hobby Employee
United States, IL, Mahomet
Joined Jun 2006
The DX18 'charger' is 14VDC, 500mA output. Anything in the neighborhood and it should work. You can charge directly by removing the pack, I don't bother balancing when doing this. Or, if you have charged any time in the past year or so you can just go fly, the battery lasts a looong time. I flew two weekends prior to the NATS, then UNL and F3J. Never even bothered checking the Tx voltage. Unless it's almost dead when you leave the house I can't see a need to field charge.
Craig Greening is offline Find More Posts by Craig Greening
Old Aug 09, 2012, 12:11 PM
heli-headcase is offline
Find More Posts by heli-headcase
Multifaceted Heli Nut
USA, GA, Atlanta
Balancing is not an option...
Had to add this -- Just took delivery of my DX18 yesterday and did lots of peekin' an' pokin' around the unit. Looked at the 2600mAh LiPo pack and see it only has a two-wire input/output lead. There is no option for balancing or not; balancing is done internally within the battery and happens whether it's wanted or not.
Charging on an external LiPo charger certainly is possible but would be wise to keep the current low (under 1C, maybe use .25C) to give the balance circuitry time to perform its job.
Field charging the TX (containing the battery pack) is super easy as any nominal 12VDC power source (of .5A or better and correct polarity) will do. The TX even has "Charge DC12V" marked on the back down at the battery compartment door.
heli-headcase is offline Find More Posts by heli-headcase
Old Aug 09, 2012, 05:20 PM
tewatson is offline
Riddle me this...
tewatson's Avatar
Joined Oct 2006
Does the 18 fit in the Spektrum single TX stand-up case (SPM 6708)?
Tom
New Product Spektrum DX18 Victory Pete Radios 11853 Jun 25, 2016 01:17 AM
Discussion Questions on Spektrum DX10 vs DX18 willyp Radios 179 Jul 28, 2014 07:28 AM
Question Spektrum DX18 radio msjvista Multirotor Talk 3 May 25, 2014 02:18 PM
Sold New Spektrum DX18 Neck Strap teryn1 Aircraft - General - Miscellaneous (FS/W) 0 Jun 02, 2012 04:08 PM
Discussion Spektrums Future Radio- DX18 Elliot13 Electric Plane Talk 7 Mar 17, 2012 08:40 AM
