Old Jun 12, 2012, 08:26 PM
Screw is offline
Find More Posts by Screw
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Twin Engine Rudder Mixing
Screw-In
The question is how to program. I am wanting to set up a twin engine (electric) so that the engines throttle up normally together, but when givin left or right aileron, the appropriate engine loses power proportioned to the amount of aileron input I give it.
Any help wopuld be appriciated.
Just FYI, I am setting up a twin pusher configuation like a blimp. I want to use the motors as a rudder, but on my Aileron stick. I'm using a JR 9503 radio, 2 small electric motors 2208-17, 2 ESC (only 1 has a BEC).
Screw-Out
Screw is offline Find More Posts by Screw
Old Jun 12, 2012, 08:30 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Sorry re-read... Not sure on the JR
Old Jun 13, 2012, 05:39 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Try these threads -
Differential Thrust Set-up Help
Differential throttle-steering on an elec. twin
This one may save some reading -
The Twins: multi purpose cargo plane - and scroll down to post #116
eflightray is offline Find More Posts by eflightray
Old Jun 13, 2012, 09:10 AM
rcshirt is online now
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
oh your in for a fun time. most esc for aircraft are one direction 0- 100%.
so since you sticks center one will wan tot be at 50 all the time.
if it is a blimb.. i would get two small car/boat esc that go forward and reverse. now center stick can be 0 and you could drive it similar to a tank and mix the the ail chanell to the throttles.
rcshirt is online now Find More Posts by rcshirt
Old Jun 13, 2012, 09:21 AM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Eflightray's links should help. What you're talking about is differential thrust, and you'll need a v-tail mixer. I have it on a couple of my twins and like it.
SAFETY ALERT! Be sure to setup with props removed!
Also, mine are coupled to the rudder. I'm not sure it would be wise to couple it to ailerons.
signflyer is offline Find More Posts by signflyer
Old Jun 13, 2012, 10:25 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I don't think he actually wants to reverse one side, (I hope ), just add differential thrust. I have it on my Sunderland, (avatar), for better water steering mixed with rudder, works a treat.
Many very cheap toy twin planes only have the one RC channel, and steer using differential thrust, climb and descend using full and low power.
Old Jun 13, 2012, 11:52 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Here's how to do it on a Spektrum DX7, which should be similar to JR:
http://www.rcgroups.com/forums/showp...0&postcount=64
P.S. - most mix the differential on the Rudder rather than the Aileron, since it affects the yaw more than roll-axis.
warhead_71 is offline Find More Posts by warhead_71
Old Jun 13, 2012, 05:24 PM
Screw is offline
Samurai KIIAAAAAAA
Screw's Avatar
Loganville, Ga.
Joined Dec 2006
Screw in
Thanks guys for the help, I'll read up on those post. No I am not using counterotating props, and yes I'm wanting to use the motors to steer left and right. Because I don't have a wing there are no ailerons, but I would like to steer with that stick rather than the rudder stick.
Screw out
Discussion Extreme flight elevator/rudder/rudder mix 7oneWo1f 3D Flying 2 Aug 10, 2012 02:11 PM
Discussion Question about aileron rudder mix function Riodiler1 Electric Plane Talk 12 May 09, 2012 07:53 AM
Discussion Spektrum Settings Dual Rates and Rudder Mix ofd23 Electric Plane Talk 6 Mar 18, 2012 05:50 PM
Discussion Twin rudder mix setup? mike_cj0 Electric Plane Talk 11 Apr 22, 2010 02:48 PM
Yippee! T6XA Super: Twin motor, throttle-rudder mix (here's how it's done) Zeuser Radios 2 Jan 22, 2003 06:29 PM
