Thanks a bunch putter
The prop is a flying styro 3 blade that I cut about 0.5 inch off the tips of and tried my best to balance. I used the stock backplate and a spinner from an old simprop su-31 I had (which is 40mm BTW). I cut down the spinner till it fit over the backplate. Then I glued the spinner to the backplate. Yes I glued it (not one of my better ideas). One side of the spinner came loose during the first flight. I have since secured the spinner to the backplate using 3 micro screws from a eye glass repair kit Now it works great and wont be going anywhere (I hope) I still may have to break down and get a tru-turn spinner and MAS 7x6 three blade. The tail wheel was made from wire that is the same diameter as the stock one (so it would still fit in to the stock holder) I also put a aluminum tube on it to fatten it up a bit. The wheel is made from 3 pieces of aluminum tube with a rubber faucet washer for the tire. Parkguy ![]() Oh and hey if Scott from hobbyking is still on this thread it would be great if the MXS and the Edge 540 was offered unpainted like the rarebear funfighter |
I put some more flights on the Edge today. On one of the flights, I tried it with a 3S battery. Size 1600 mAh, shoved full forward. It flew just fine, except of course for being slower...to the point that I had to use 90 to 100 percent power most of the time, since I don't want to let this bird get too slow. Of course, that was with the stock 7x6 prop on it. I might pick up a 7x8 prop when I get a chance, and give that a try on 3S.
I was going to do another experiment, swapping out the stock motor to the 2826 motor that I ordered as an alternate/backup for the plane. That motor has a higher kv (2200), so it's better suited to 3S LiPo. Only problem is, the plane has an odd motor mount interface. One corner is angled forward. The built-in X-mount on the stock motor base has the corresponding corner bent in the same direction to mate to it. See photo. This makes no sense to me. It would make sense if they angled the whole motor mount base for thrust-angle purposes. But to warp one corner, and then bend the x-mount in the same way serves no purpose that I can see. Plus, it makes it harder to get that one screw on and off. So the upshot of it is: you can't mate the new motor's flat X-mount onto that curved plastic base (unless maybe you put it in a vise and manage to bend it in exactly the same way). And you can't reuse the included bent X-mount because it's integral to the stock motor. I don't see how this design accomplishes anything, except making it more difficult to work with. So it looks like people who buy the bare-airframe kit are in for a rude surprise when they go to attach a motor. |
herk1,
That's an extremely odd motor mount. Anyone else wanna open their cowl and see if that is indeed a design feature? Certainly adding washer to the mount or customizing the plastic mount would be quicker and cheaper in the long run than to have employees sitting there bending each one... |
Saw this new gyro thingy under HK new items: http://www.hobbyking.com/hobbyking/s...tabilizer.html
This particular plane seems like it might be a good candidate to use with the gyro device, if it really works. For example, it might make flight at more aft CGs less tricky. And it might provide some recovery help in the event of a nasty tip-stall-and-spin like I experienced. Just a thought. And in any event, the thing is already on back-order. |
| Thread Tools | |
| New Product Hobby King High Performance Racer Series - 800mm | nniibb | 3D Foamies | 6 | Nov 11, 2012 01:46 PM |
| New Product HobbyKing - Mini Racers Edge 540 V3 & Sbach | Mikemynameis | Parkflyers | 13 | Jun 24, 2012 10:55 PM |
| Sold (NIB) Durafly Edge 540 V3 Micro 3D 490mm (PNF) | luvmykids2 | Aircraft - Electric - Airplanes (FS/W) | 7 | Mar 20, 2012 01:37 PM |
| Sold Greatplanes Edge 540 EP performance series Rx-Ready lpu | Chopper1 | Aircraft - Electric - Airplanes (FS/W) | 0 | Nov 11, 2011 12:32 AM |
| New Product HobbyKing Mini Racers Edge 540 V3 & Sbach... | micromantis | Foamies (Kits) | 6 | Oct 31, 2011 02:25 PM |
