Old Feb 09, 2013, 04:23 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Originally Posted by solentlife View Post
Sorry can you detail a bit more on that ... I assume you mean the screw jobs that connect to the servo arms ?
Nigel
Hi Nigel
Yes the screw that locks the two elev rods down together. I pulled back coming out of the dive and the rods moved through the mount, so as soon as I release the ELEV the change in position put the ELEV in a full down position. It was still like it when I collected the bits out of the mud. Unlucky I guess, but I've had some real fun with this aircraft so I hope to repair again.
Mick
ps- Interesting day at the field actually for mechanical failures. My HK450 heli did a bearing not long after take off, but landed safely. My Sbach 1400mm had a rudder servo fail into jitters, but I stabilized her and got it down. I got two flights in with my Goshawk and one with a Yak55, but my luck ran out with the Edge540, hmm, lawn dart
Bravo47 is offline Find More Posts by Bravo47
Old Feb 10, 2013, 03:38 AM
Bravo47 is offline
Australia
Joined Jun 2010
After pulling apart my aircraft I have to revise my previous suspected cause of crash. The rods still look solid. The timber servo mounting plywood moves about and the ELEV and RUD surfaces with it, but that may have released on impact. So its hard to say for sure. Anyway repairs are under way
Old Feb 10, 2013, 06:24 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Like many crashes ... I think we all assume what happened ... but possibly another reason can be ...
Pretty difficult to diagnose just from what happens at the time.
Like my Gasoline Biplane ... at time I assumeed and say on Youtube vid that I went wrong way when inverted .... but later watching vid and the gear ........ turns out elevator servo failed.
Nigel
solentlife is online now Find More Posts by solentlife
Old Feb 11, 2013, 08:46 AM
gooniac33 is online now
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Had another great weekend with the Edge again! 2 flights with great landings! I have some pix of my spoileron set up and a couple pix of my landings too. But here are the spoilerons first...
Normal flight
Spoilerons in use
It doesn't seem like much but it makes a huge difference in landing speed!
gooniac33 is online now Find More Posts by gooniac33
Old Feb 11, 2013, 09:11 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Here are the higher quality shots that my wife took...
low slow pass
Spoilerons up and ready for landing.
less than a second from touchdown
Spoilerons up
the path that I land on is pretty narrow. you can see it here.
there are benches and trees to avoid as well. and the occasional squirrel too
Old Feb 12, 2013, 03:15 AM
Bravo47 is offline
Australia
Joined Jun 2010
Nice pics Gooniac, and your Edge is still in great shape compared to mine which has copped a beating.
Old Feb 13, 2013, 10:24 AM
solentlife's Avatar
Joined Jan 2010
Have to agree ... great ;pics Gooniac ... and you STILL have the wheels on !!
The real beauty of the pics is to see the amount of UP aileron you use ... more of a wing incidence changer than spoiler ...
Have you thought about increasing the UP angle ? It's certainly making me think more on your line than my flaps ...
Once I get home ... have to try it out ...
Nigel
Old Feb 13, 2013, 11:21 AM
Logan4169 is offline
Find More Posts by Logan4169
Joined Nov 2011
Ahh yes, "spoilerons" by any other name would be just as sweet, but a lot easier to talk about for planes that are not gliders!
Logan4169 is offline Find More Posts by Logan4169
Old Feb 13, 2013, 06:23 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Simply put... spoilerons are ailerons that are moved up on landing. And flaperons are used in the down position. It helps slow it down and in the pix you can see that the plane is in the correct attitude for landing...Flaperons will make the plane nose over...you don't want that....
Old Feb 13, 2013, 07:00 PM
Ben D Wing is online now
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
How come? My slope gliders pitch up with deployment of flapperon and need down elevator mixing in.
Ben D Wing is online now Find More Posts by Ben D Wing
Old Feb 14, 2013, 12:32 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Because they are slope gliders... I am going off of my own experience and what has worked for me. A mid wing tail dragger will go into a nose down attitude with flaperons. I would rather the plane land the way that is sits on its gear. So the spoilerons work best for me. If it had trike gear then the flaperons would work better for me. I should do a couple approaches for the camera and show the attitude that the plane is in with no spoilerons and then a shot with them up. It makes a big difference and the plane will do a three point landing with the spoilerons....it lands on the mains with out them and then rolls much further...
Old Feb 14, 2013, 07:56 PM
solentlife's Avatar
Joined Jan 2010
I have various models with flaps / flaperons and all display the typical nose up on deployment. My Cessna in fact can near loop when full deployed if a little too much speed !
One reason why model may dip nose on flaps being deployed is that we tend to have switched flaps instead of proportional. We slow down the model. flick the switch and BHAM - drag is suddenly made and nose goes down. It's a big reason why I use a rotary knob on mine ... so I can bring in flaps proportionally avoiding that sudden moment.
With the Edge - I think I will utlise the same control - but trial as Spoilerons instead of flaperons ... with more angle possible if full movement made. Being proportional I can find out the 'sweet spot' and then EPA back the control to that as full movement.
I'm raring to give this a go .... real nuisance that I have to work !!
Nigel
Old Feb 15, 2013, 09:16 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Nigel
Doesn't it suck when work gets in the way!! AGH!! This is my last work day of the week. So I get some time to play with the planes again on sunday. I will move the throw up a little bit more and more to see if I can get it to slow down even more. But I am worrying about the stock servos that came with it. If I had my own in there then I would be willing to do more...
Old Feb 15, 2013, 11:52 AM
Joined Nov 2011
Using a higher rate of spoileron shouldn't cause any additional problem for the servos. They are still traveling less than they were already allowed to when used as ailerons. Also they are usually deployed when the airplane is slow, so even if they are set at 100% the aerodynamic load will be less than when they are used as ailerons at speed.
Old Feb 19, 2013, 04:34 AM
solentlife's Avatar
Joined Jan 2010
Yippee !! Finally going home ... wife says there's loads of snow at home - but weather forecast for next weekend is gentle breeze / near calm ... so snow or what - I'm going flying !!
Spoilerons here I come !!
Nigel
New Product Hobby King High Performance Racer Series - 800mm nniibb 3D Foamies 7 Sep 22, 2014 11:11 PM
New Product HobbyKing - Mini Racers Edge 540 V3 & Sbach Mikey 68 Parkflyers 13 Jun 24, 2012 10:55 PM
Sold (NIB) Durafly Edge 540 V3 Micro 3D 490mm (PNF) luvmykids2 Aircraft - Electric - Airplanes (FS/W) 7 Mar 20, 2012 01:37 PM
Sold Greatplanes Edge 540 EP performance series Rx-Ready lpu Chopper1 Aircraft - Electric - Airplanes (FS/W) 0 Nov 11, 2011 12:32 AM
New Product HobbyKing Mini Racers Edge 540 V3 & Sbach... micromantis Foamies (Kits) 6 Oct 31, 2011 02:25 PM
