Australia
Joined Jun 2010
http://www.rcgroups.com/forums/showp...&postcount=152 |
I am thinking to replace my DIY mount with straight cross beams instead ... I cut a little too close on one side and the screw hole is too near edge. I have thought of buying more original mounts ... but to be honest - why have the hassle of replacing all the timne ! Maybe to buy one and get a pal of mine who's a metal master to make one .. My old one is binned - so no use giving him that. Haven't heard anymore from the guys who had mounts twisted ... ?? Hi Gooniac ... 52A ... that's a big increase over my 32A on stock. My problem is I like speed and that means a lot of WOT ... But I am interested to look at an upgrade on motor .... I reckon a pole mount motor would be better here to fit inside that cowl and also the length needed ... Nigel |
Australia, QLD, Townsville
Joined Jul 2011
My control surfaces are absolutely neutral - indicating that thrust lines are fine. They are stock.... even though I replaced mount with home-made. Nigel |
Australia
Joined Jun 2010
Mick |
OOP's .......
My EDF did similar one day !! ESC and motor were toasted ! Never did find out why. Nice photos though ... Bet she dead-stick'd fine ? Counter to what some reports say. Only niggle I have with mine is the ESC has a bad low throttle area .. when bringing her in and reducing throttle - motor will suddenly stop where I want just a prop turning to help keep nose up ... I've reset throttle range ... tried all sorts but still it has this dead spot. When testing .. the motor suddenly kicks into life instead of controlled in as should be. Seems to be missing the bottom 5% bit .. Maybe I'll swap out the ESC later ... Nigel |
The smoke trail was pretty cool for sure. The winds were gusting around 15mph. I was nervous about the landing to come but when it went poof, the deadstick landing was one of my best landings on this model so far?! No damage at all from my deadstick in roughage other than the breakaway gear (again).
| Thread Tools | |
| New Product Hobby King High Performance Racer Series - 800mm | nniibb | 3D Foamies | 6 | Nov 11, 2012 01:46 PM |
| New Product HobbyKing - Mini Racers Edge 540 V3 & Sbach | Mikemynameis | Parkflyers | 13 | Jun 24, 2012 10:55 PM |
| Sold (NIB) Durafly Edge 540 V3 Micro 3D 490mm (PNF) | luvmykids2 | Aircraft - Electric - Airplanes (FS/W) | 7 | Mar 20, 2012 01:37 PM |
| Sold Greatplanes Edge 540 EP performance series Rx-Ready lpu | Chopper1 | Aircraft - Electric - Airplanes (FS/W) | 0 | Nov 11, 2011 12:32 AM |
| New Product HobbyKing Mini Racers Edge 540 V3 & Sbach... | micromantis | Foamies (Kits) | 6 | Oct 31, 2011 02:25 PM |
