Old Nov 19, 2012, 02:27 AM
chessgame is offline
Find More Posts by chessgame
Joined Aug 2008
Originally Posted by solentlife View Post
OK - now home from travels and in a few minutes had this little baby together and ready to go.
Nigel
Remember to TONE down the throws.. this plane is really unflyable if you have too much throws...
chessgame is offline Find More Posts by chessgame
Old Nov 19, 2012, 07:22 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I note that many are talking about 5 - 6mm DR on aileron but very little said about elevators.
If anyone would like to quote measurements in mm or inches ... not degrees. Measured at root up / down for full and DR ?
Would really appreciate the info.
Nigel
solentlife is online now Find More Posts by solentlife
Old Nov 19, 2012, 11:44 PM
solentlife's Avatar
Joined Jan 2010
Just as follow on from last post ...
Mine is set up as, throws measured at inboard ends of surfaces :
Aileron Full 10mm, DR 5mm Expo is 60% both
Elevator Full 10mm, DR 5mm Expo is 60% both
Rudder is just at factory setting and plenty of expo for ground work.
I've left quite a large throw on full rate but serious expo to tame it down until I find my ideal setting. The 5mm I reckon is cruise around setting ... but all remains to be seen once she's in the air.
nigel
Old Nov 20, 2012, 05:44 AM
ckleanth is offline
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
well expanding on my last post the aircraft is now dead.
I invested in 3 4s 1800 which are 60g heavier than the 3s 2200. it had plenty of power but at roughly 1.2 kg and a mere 800mm wingspan its still (was) a flying brick.
throws were at maximum with 50% expo if I remember right. at full power its fast but at 1/3 throttle it was falling from the sky. basically I was performing (what I thought it was) a controlled stall/spin but it would not recover and nosedived into the ground.
aircraft fuselage is now in two pieces, wings intact and could be mended but I'm not going to bother as I felt nothing as it crashed. I did made some pics the day before I crashed it so will update with actual flying weights
ckleanth is offline Find More Posts by ckleanth
Old Nov 21, 2012, 06:52 AM
solentlife's Avatar
Joined Jan 2010
Why was yours 1.2kgs ??????
Mine ready to take battery is 524gr ... add a 4S 1600 Zippy Compact now 698gr .. a 3S 2200 Turnigy blue gives 716gr - WITH WHEELS and the extra few gr's for the Pilot figure .......... a long way of 1.2kg !!
Nigel
Old Nov 21, 2012, 09:45 AM
Joined Aug 2008
ok. finally came down to measuring it.
Suggest the following for maiden :
elevator : 4-6 mm . 50% expo
ailerons : 5-7 mm . 50 % expo
Nigel
Old Nov 21, 2012, 10:04 AM
Joined Aug 2008
I agree. I am not sure if it wise to do a stall spin for such a plane especially at recommended setup of 7x6 prop which is built for speed.
And i dont recommend stalling this plane when it is not dialed in.
It is defintely not a "forgiving" plane.
The good news for those who like speed is i ran this plane against funjets recently and i found it have a better turning/banking ability.
looking to setup some foam pylon race.
Old Nov 21, 2012, 10:56 AM
solentlife's Avatar
Joined Jan 2010
OK - cheers ... FYI - I'm a brutal flyer and usually have more movement than many like.
Question - your measurements there - are they DR figures or full rate ? I assume they are DR reduced rates ?
Nigel
Old Nov 21, 2012, 12:10 PM
ckleanth is offline
ckleanth's Avatar
Joined Mar 2011
Nigel
sorry mate I remembered wrong info.
Real Weight
Original LG 3S 883g
Original LG 4S 914g
New Carbon Fibre LG 3S 944g
New Carbon Fibre LG 4S 975g
I changed the LG because the stock was... well shite
my CF LG was proportionally sligtly bigger for the A/C but it was better than the stock one (becasue it would actually take the punishment) but with unfortunately a slight increase in weight
weight brakedown original configuration
Sbach 342 800mm (PNF) pylon thing 883g
fuselage & rear wing & motor & esc & 7x5 prop with spinner 436g
main wing 148g
receiver and telemetry 62g
original Landing Gear with wheels 40g
Turnigy nano-tech 2200mah 3S 45~90C Lipo Pac 197g
the above should sum 883g
with the original LG and a 4S turingy it was 914g
Turnigy nano-tech 1800mah 4S 65~130C Lipo Pack 228g
I was interested to see if it could prop hang so at 0mph speed
(data from APC propellers website) :
prop 7x5 3S 15500 RPM
Weight (g) 914.4
Thrust (N) 9.0
Thrust (Lbf) 2.0165
prop 7x5E 3S 15500 RPM
Weight (g) 924.1
Thrust (N) 9.1
Thrust (Lbf) 2.038
prop 7x5 3S 20000 RPM
Weight (g) 1574.8
Thrust (N) 15.4
Thrust (Lbf) 3.473
Weight (g) 1591.1
Thrust (N) 15.6
Thrust (Lbf) 3.509
I cant be bothered to calculate the stall speed considering the actual wing profile and the real weight, but I can tell you it it would be a relatively high velocity..
Old Nov 22, 2012, 12:18 AM
solentlife's Avatar
Joined Jan 2010
Real Weight
Original LG 3S 883g
Original LG 4S 914g
main wing 148g
WOW that's heavy .... even if I had a 2200 4S in mine - I'm not even close to yours ...lets use your battery as example ie your Nano 1800 at 228gr + my 524gr frame weight = 752gr.
But I thought you were talking about the threads model - the Edge 540 .... the Sbach - I have no idea ...
Nigel
Old Nov 22, 2012, 01:46 AM
Joined Aug 2008
Nigel
I am using a JR TX hence i tone down the throws via flight mode.
ie 50% of original full throws with 50% expo. The figures i quoted earlier is the 50%
The max throw i tried was 75% of original... and it was really bad even at slower speed . My experience with fast planes is that when ur plane speed is really fast, u need to tone it down the throws even further when u full throttle..otherwise even the simple banking or turning is ridiculous to control.
Old Nov 22, 2012, 02:06 AM
Joined Aug 2008
[/IMG][/URL]
Wow ! that is an eye opener photos... and data !
dude no offense, but u got the plane all wrong...
1. I think u r expecting this plane to be a 3D plane like the UMX micro beast .
which is not. It is pylon racer though it looks similiar
2. your LG, wow.. that is some heavy duty LG ... i am not sure what kind of "landing" you are doing... but what is the point of having a LG that can take it when the plane cant ? The point i am making is , if u had a bad landing and there is part that needs to break, which part do you prefer to break. plane or LG. I rather break my LG any day compared to my plane.
3. prop hang at 0 mph ? did you even check the surface throws (not just the amount of throw) on this bird to do this ? No sane 3D i know will have said this plane can do 3d . The surface throws is really too small. Unless you had gyro equipment, i really doubt this plane can do any 3D.
I will suggest you consider the dynam sbach 1.2m for 3d.
It looks suitable for your LG and if a docile 3d plane is really what you want.
But dont go trying to clock 140 mph speed on dynam and find that it does not work. No plane can be all things. ie 3D, aerobatics, speed, etc.
Old Nov 22, 2012, 02:08 AM
Joined Aug 2008
I just re - read my post, and want to say i didnt like my tone of writing.
But i dont know how to say it otherwise.
Not meant to offend but to inform.
Old Nov 22, 2012, 02:37 AM
solentlife's Avatar
Joined Jan 2010
I have ti agree with you that the model is not designed for 3D .. it is put out as a speed machine ... two totally different animals.
I have a number of models that have excessive power to weight and can climb and accelerate vertically ... but slow them down to hover and they just cannot do it...... they topple over.
I'm waiting suitable so I can put this baby in the air and see what she can do ... I expect high speed, to take care when gliding in, keep speed up in turns ... basically fly a hot racer style.
Nigel
Old Nov 22, 2012, 03:27 AM
solentlife's Avatar
Joined Jan 2010
Here's meassured data for anyone looking at this model as per standard set-up with wheels etc.
Model weight with wheels w/o battery : 524 gr
With 4S 1600 35C Zippy Compact RTG : 698 gr
With 3S 2200 35C Turnigy Blue RTG : 718 gr
Motor on Wattmeter :
3S 2200 = 19A / 225W
4S 1600 = 28A / 405W
Ailerons 10mm full, 5mm DR
Elevators 10mm full, 5mm DR
Expo is 60% on all settings ...
Control throws will be adjusted once flown.
CoG came out about 30mm back from LE at root
Nigel
New Product Hobby King High Performance Racer Series - 800mm nniibb 3D Foamies 7 Sep 22, 2014 11:11 PM
New Product HobbyKing - Mini Racers Edge 540 V3 & Sbach FieldofDreamsFlyer Parkflyers 13 Jun 24, 2012 10:55 PM
Sold (NIB) Durafly Edge 540 V3 Micro 3D 490mm (PNF) luvmykids2 Aircraft - Electric - Airplanes (FS/W) 7 Mar 20, 2012 01:37 PM
Sold Greatplanes Edge 540 EP performance series Rx-Ready lpu Chopper1 Aircraft - Electric - Airplanes (FS/W) 0 Nov 11, 2011 12:32 AM
New Product HobbyKing Mini Racers Edge 540 V3 & Sbach... micromantis Foamies (Kits) 6 Oct 31, 2011 02:25 PM
