Old Jun 12, 2012, 03:12 PM
Joined Jun 2012
No signal from data recorder
hi guys,
I'm part of a hobby team that has been using eagletree- with no problems- for a while now. But during our last flight, eagletree stopped working. We tried troubleshooting the problem- but when we turn on our vehicle's power, the recorder LED gives two flashes, and then a constant steady flickering.
The dashboard says 'no signal'.
when we tried to hook it up to our laptop- nothing happened. the computer acknowledges that a usb device has been hooked up, but the recorder led doesn't give those 3 flashes to indicate that it's communicating.
any suggestions?
thanks!
xhale is offline Find More Posts by xhale
Old Jun 18, 2012, 10:36 PM
billpa's Avatar
Joined Nov 2003
Hi xhale, sorry to hear about the issue. When you run the software after connecting the recorder to USB, does the recorder show up under "firmware control"? If so, can you update the firmware of the recorder, and then set the "capture rate" to 10 Hz?
If it is not accessible, it sounds like there is an issue with the hardware itself. You'd need to open a ticket with us at http://ticket.eagletreesystems.com.
billpa is offline Find More Posts by billpa
Site Sponsor
Help! How to record data from foreign sensors? Soulkitchen Eagle Tree Systems 39 Feb 07, 2013 03:35 PM
Discussion no tilt signal for tilt comp from board? Huck Norris Hoverfly Technologies 9 Feb 06, 2012 09:34 PM
Discussion No amps data during recording? DaMaDo Eagle Tree Systems 1 Jan 02, 2012 12:58 PM
Question eLogger V4 not recognized by Data Recorder ross_badger Eagle Tree Systems 3 Oct 15, 2011 04:32 PM
Help! Data recorder software issues aa78 Eagle Tree Systems 4 Oct 11, 2011 12:19 PM
