E-flight 101 by RCG member Ken Myers, will at least save you a ruined LiPo (or worse!), a burnt motor and a fried ESC:
http://www.theampeer.org/framesefo.html -> Electric Power Basics and this e-book -> Everything youw wanted to know about e-flight (Ed Anderson) |
If you don't mind an external BEC, here is a 50 amp ESC that can do up to 7S.
http://www.hobbyking.com/hobbyking/s...dProduct=18006 Suggestion based on numbers, I haven't used that. |
Latest blog entry: Powerpoles explained by Oz
The voltage applied to a brushless motor is switched on and off by an ESC even at WOT (wide open throttle). If you change props, the current demanded would change at WOT. Connecting the wires of a brushless motor directly to a battery won't perform the commutation that the ESC does. If you skip the ESC, the inductor would saturate, heat up, and your battery will be damaged if the inductor wires don't open quickly enough.
| Thread Tools | |
| Discussion High Kv and Low Voltage or Low Kv and High Voltage | PatrickRC | Power Systems | 32 | Sep 19, 2012 09:49 PM |
| Discussion High voltage, low kv brushless for 55mm EDF | Red Baron | Power Systems | 3 | May 03, 2012 08:30 AM |
| For Sale 12S High Voltage & High Power Setup For 600 Size Heli | helinut4ever | Aircraft - Electric - Helis (FS/W) | 0 | Dec 31, 2011 09:00 AM |
| Help! Big prop, high pitch, low rpm, low voltage | invertmast | Power Systems | 16 | Dec 25, 2011 10:38 PM |
| high kv low kv high amp low amp | what_the?! | Electric Ducted Fan Jet Talk | 56 | Sep 23, 2005 08:35 AM |
