Old Jun 11, 2012, 02:22 PM
Billyisgr8 is offline
Find More Posts by Billyisgr8
Joined Dec 2011
Dollar tree beginer with flaperons
I am a beginner and thought I would build a dollar tree plane using only 1 sheet of foam, and came up with this. I had maybe a 2 x 3 piece of foam left when done. I wanted the largest wing possible, and planned to only use flaperons. First flights with this plane was on a windy day, but got into the air, and the wind just pushed the plane around. 4 attempts, and then we just packed up to go home.
Wing load is right around 5oz per sqft. using a 8 x 4 prop with this motor. http://www.hobbyking.com/hobbyking/s...idProduct=5423 it pulled really good. Plane weighs just a touch under 11 oz (306 grams). I left the paper on the foam, but could maybe loose another 1.5 oz if I selectivlely removed some of the paper, and more if I used my other much lighter motor . Was very happy that it flew how it did in the wind, and I was able to land it without any damage. Will hopefully go out again soon when the wind is not blowing. Was not really sure how the plane would respond with flaperons only but put those questions to rest once it was up in the air.
Billyisgr8 is offline Find More Posts by Billyisgr8
Old Jun 11, 2012, 06:09 PM
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
I wouldn't remove the paper, the sandwich of the foam with paper on both sides makes it like plywood, it adds a LOT of stiffness and strength. Removing the paper from the foam will weaken it substantially, and if you did that you would probably need to add stiffeners, which would probably end up weighing more than the paper you removed.
You might also consider covering it with packing tape, that also adds stiffness and adds a substantial amount to the durability of the plane. You usually have to order packing tape in colors, but you can get clear packing tape at WalMart and it works pretty well, not quite as pretty as the colored tape but looks pretty good and functions the same as the colors.
Wingman26 is offline Find More Posts by Wingman26
Old Jun 11, 2012, 06:59 PM
StewieRC is offline
Find More Posts by StewieRC
This Calls for a Sexy Party
StewieRC's Avatar
Minneapolis
Joined Sep 2010
thats Elevon, not flapperon.
Flapperon is when you combine Flap ( on the wing ) and aileron ( on the wing ) together.
StewieRC is offline Find More Posts by StewieRC
Discussion stryker clone with dollar tree foam 63 nova Foamies (Scratchbuilt) 3 Mar 30, 2012 03:49 PM
Build Log Full fuselage Fokker D-7 designed for dollar tree foam...now with plans! gmwahl Foamies (Scratchbuilt) 110 Mar 22, 2012 11:09 PM
Discussion Has anyone used this foam from the Dollar Tree? bagofbones11 Foamies (Scratchbuilt) 6 Nov 29, 2011 06:04 PM
Discussion Building a jet pusher with Dollar Tree Foam? hoverflyhehe Pusher Prop Jet Models 26 Feb 25, 2010 09:43 AM
