Old Jun 11, 2012, 12:44 PM
wewprez is offline
Find More Posts by wewprez
Joined Jan 2012
Video
Agri-Duck dropping candy
It's time for the West End Wings 34th Annual Father's Day Airshow, so I was practicing this past Sunday.
My dad and I built this last August to drop some serious candy for the little kids at the airshow. It is 110" in span, weighs 25 lbs wet, has a 45cc RCGF 2-stroke for power and is dropping 2.0 lbs of candy in the video. Construction is mostly 3/16th foam board. We re-engineered much of the structure, but not the geometry and general layout.
It's big, loud, slow, and orange...what else could you want?
Hope people like it.
wewprez is offline Find More Posts by wewprez
Old Jun 11, 2012, 06:23 PM
drsgfire is offline
Find More Posts by drsgfire
United States, NC, Kinston
Joined Mar 2012
Nice. Good landing too.
drsgfire is offline Find More Posts by drsgfire
Old Aug 20, 2012, 12:14 PM
gromitvt10 is offline
Find More Posts by gromitvt10
gromitvt10's Avatar
United States, MD, Solomons
Joined Feb 2002
Very cool, i'm building one now. Is your horizontal stab removable? What other mods did you make? I planned on making a "working hopper" on mine.
Kyle
gromitvt10 is offline Find More Posts by gromitvt10
Old Sep 10, 2012, 03:10 PM
wewprez is offline
Joined Jan 2012
Mods
Kyle,
Tail and fuse is all one piece but each wing comes off.
We didn't change the planform lines of the plane, but upped the structure since it was way weak as designed; especially where the wing attached. Use 1/2" or 3/8" aircraft ply for where the wing bolts will go. We also made the wing struts from 2 steel broom handles (from the dollar store); do NOT try the balsa struts at all!
We put a 45cc RCGF engine on it instead of the .61 glow, so more structure was required. Use fiberglass drywall tape along high stress areas on the foam board as you build...it really helped. Use cable rigging from the stab to the fuse to cut down on wiggling.
We made the gear out of pvc. I used 1/4 scale servos for each aileron and rudder, and two standards on the elevator. Used a 6V 2000 Ni-mH
for the flight pack and a separate one for the engine ignition.
Good luck with it.
Herb
Old Sep 11, 2012, 01:24 PM
gromitvt10's Avatar
Joined Feb 2002
Herb,
Thanks for the info, mine is about 10lbs lighter than yours. I'm using an electric setup, 2 flights on her so far and she is still in one piece, although i'm still perfecting my power setup. As soon as i get everything squared away i'll start my powder drop runs. Here is my bird.
http://www.rcgroups.com/forums/showthread.php?t=1725238
Old Sep 13, 2012, 03:06 PM
stevenmurrell is online now
Find More Posts by stevenmurrell
stevenmurrell's Avatar
Garden Grove, CA
Joined Mar 2010
VERY NICE landing!!!!
stevenmurrell is online now Find More Posts by stevenmurrell
Discussion Agri-Duck sport hfenn Giant Scale Airplanes 0 Dec 11, 2011 06:45 PM
Discussion Agri-Duck sport hfenn Foamies (Scratchbuilt) 0 Dec 11, 2011 06:38 PM
Discussion Mini Agri Duck; the Agri Duckling! parrot pilot Foamies (Scratchbuilt) 4 Oct 21, 2008 03:24 PM
Build Log Blue Agri Duck Sport Come on in duck fans cars4fun2001 Foamies (Scratchbuilt) 101 Aug 15, 2008 09:16 PM
