Old Aug 12, 2012, 01:29 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Whats the weight Remy? which one did you order, can you post the link?
koolkiwikat is offline Find More Posts by koolkiwikat
Old Aug 12, 2012, 01:32 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Originally Posted by Remy View Post
"magical frame design allows you to turn it into a hexa"
Magical frames? Sounds like DJI was involved.
Can't you just use less arms and mount stuff into the hex-holes in the center board instead of octo-holes?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 12, 2012, 06:57 AM
Remy is offline
Find More Posts by Remy
Netherlands
Joined Feb 2004
Hi Koolkikikat,
I'm sorry, I didn't weight the frame. I already put it together.
The frame is very stiff, not to much wieght.
You can see my hexa in this video at 0:28seconds):
Teaser Riverstone (2 min 56 sec)
Don't mind the discription at goodluckbuy. The octa is a octocopter and you can not use it as a hexacopter. If you want to make it as an hexacopter then you need to buy the hexacopter.
If you still want to turn the octa in a hexacopter then you need to remove two arms like I did.
It looks like a reall spider now, accept for the two missing arms. ( a spider has 8 )
You don't feel is in the flight charastics, and you now have a clear view in front of it.
Remy is offline Find More Posts by Remy
Old Aug 12, 2012, 09:11 AM
Aaalie is offline
Find More Posts by Aaalie
Aaalie's Avatar
Netherlands
Joined May 2006
Wow, like your vid! Smooth moves
Aaalie is offline Find More Posts by Aaalie
Old Aug 12, 2012, 09:35 AM
rampa202 is offline
Find More Posts by rampa202
United States, MD, Annapolis
Joined Jun 2011
I bought this frame at GLB http://www.goodluckbuy.com/professio...wheelbase.html I just starting building it last night. What sold me were the 22mm tubes. I cut the tubes so that I'll have a 800mm wheelbase and can use 15 inch props, which I also bought at GLB http://www.goodluckbuy.com/1540-15x4...r-2-pairs.html
I'm very satified so far. Someone here was saying that the CF frames at GLB where just CF veneer on GF, but I can faintly see the CF weave pattern on the inside of my tubes. I can't say about the bases plates as they are finished on both sides.
My frame, without motor mounts, battery plate and landing gear is 535g
Russ
rampa202 is offline Find More Posts by rampa202
Old Aug 12, 2012, 04:34 PM
Joined Sep 2007
Nice Remy, 1st pics Ive seen of the GF version, cant beat the price with the carbon twice as much and 100grms less, the GF version is much better value!
Old Aug 13, 2012, 10:01 PM
Papajeff is offline
Find More Posts by Papajeff
AMA 869451 / FAA 13675
United States, NY, Rochester
Joined Jan 2006
Originally Posted by jab View Post
I have already done bench tests with the propeller attached on a single arm. No problem with timing during those tests, but I am using 4S and 490kv motors. You will probably want the 390kv motor for 6S.
Jab, you did a great job with your Octo setup and your video was worth a thousand words.
I have a big 800mm CF Hexa on the way and a 3-axis gimbal to fly a Canon 60D. Do you
think that I would be better off using the 4822 490kv which will give me the option to go with
4S to 6S depending which size props give the best lift performance?
Papajeff is offline Find More Posts by Papajeff
Old Aug 14, 2012, 08:02 AM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
Should work.. Assuming 15" is ideal on 4S and using linear math you get:
4S - 15"
5S - 12"
6S - 10"
But considering the 490kv motor is running cold to the touch with 15" and 4S, I am guessing 12" and 6S would be fine. 13" might be pushing things a bit.
jab is offline Find More Posts by jab
Old Aug 14, 2012, 02:23 PM
rsun77 is offline
Find More Posts by rsun77
Danmark, Sjælland, Gørlev
Joined Jul 2008
Jab: What flight time's do you get on your setup... ?
Got a spare AV130, some 40 amp esc's and WKM that I am thinking about putting in the same setup as the one your are using....
rsun77 is offline Find More Posts by rsun77
Old Aug 14, 2012, 03:50 PM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
I just got my new 4S 8000mah batteries, so I haven't tested them yet.
But I got 10min flights testing with 4S 6600mah and no payload. AUW 3.8kg and landing at 14v (3.5v cell). So depending on how much overhead I get when I add payload, I estimate 15-20min flights using 4S 16000mah and AUW 6kg.
Old Aug 14, 2012, 05:46 PM
HexaFlexa is offline
Find More Posts by HexaFlexa
HexaFlexa's Avatar
Joined May 2012
My " Fake" cinestar Copy Clone BARGAIN
I thought id chip in to the snobbery argument about " Fake frames".. I bought the carbon (Fake carbon) Whatever frame and think its a steal for the price. Concidering the truely rediculous price the cinestar frame is , and for what extra.. a few bits of rubber damping.. woweee.. any one with an ounce of common sense can add a plate with some dampers on it to the frame and get a great frame for a way less than the cost of th e cinestar and enough change to stick a DJI wookong on it.. Yee haa i love mine, and as im not planning on working for steven Speilberg any time in the near future its plenty good enough for my needs.. But hey if you have money to burn follow the sheep.. Err I mean crowd and buy a frame that costs 3 times what its worth and leave the bargains to us cheapskates, who will be laughing all the way to the bank..
Oh and it flies too...
wookong carefree / course lock test (6 min 44 sec)
HexaFlexa is offline Find More Posts by HexaFlexa
Old Aug 14, 2012, 07:23 PM
rabone is offline
Find More Posts by rabone
United Kingdom, England, North York
Joined Oct 2010
verey nice bit of kits Remy
rabone is offline Find More Posts by rabone
Old Aug 14, 2012, 07:26 PM
diakatche is offline
Find More Posts by diakatche
Joined Jul 2009
Can someone tell me the thickness of the tubing walls and base plates on the "fake" frame. I'm just curious because the Cinestar frame, of which we have built two for customers, uses 4mm carbon plate for the base plates and tubing with 2.5 mm wall thickness. They tubes appear to be spiral wound with a cloth outer layer. Pretty good stuff.
diakatche is offline Find More Posts by diakatche
Old Aug 14, 2012, 07:30 PM
rampa202 is offline
Joined Jun 2011
Nice video and photo.
Regarding motor mounts that clamp on to tubes - is there a trick to making sure the mounts are all in the same plane, perfectly perpendicular to the ground? In my case I had to mount the motor to the mounting plate before I could mount it on the tube. So I couldn't use a level. I just made sure that the ends of the motor mount bolts sat flat on the floor. But I was wondering if there is a more precise method.
Russ
Old Aug 14, 2012, 07:33 PM
rampa202 is offline
Joined Jun 2011
My fake frame uses 22mm by 1mm thick tubing, and everything else is 2mm thick. I can't imagine needing 4mm thick, but 2mm thick tubing would be nice.
Discussion Another site like Goodluckbuy, Eforchina DJI450 frame half price bakchos Multirotor Talk 39 Aug 22, 2014 02:26 AM
Question Newbie dreaming...600mm spider quad frame at GoodLuckBuy Jonathan Ott Multirotor Talk 109 Jan 16, 2013 09:17 AM
New Product New inertia camera frame from Goodluckbuy kaz1104 Multirotor Talk 18 Aug 18, 2012 03:35 PM
Discussion Goodluckbuy ST450 Frame flitelab Multirotor Talk 12 Mar 17, 2012 07:09 PM
Discussion Opinions on the <$50 quad frames from GoodLuckBuy? Dax Multirotor Talk 23 Jan 26, 2012 02:43 PM
