Old Jul 19, 2012, 04:06 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Himodel has the motors much cheaper then GLB, there the fastest in shipping I have ever dealt with
http://www.himodel.com/electric/HL_W..._Aircraft.html
koolkiwikat is offline Find More Posts by koolkiwikat
Old Jul 19, 2012, 07:23 AM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
A question. What happens if you break somehting? Is there any replacement parts to buy?
Reginak is offline Find More Posts by Reginak
Old Jul 19, 2012, 09:20 AM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
Not that I know of. But the arms are standard 22mm CF tubes found at many online retailers. The tube clamps are solid pieces of aluminum, so you would really have to try very hard to bend them, and even so they are aluminum so you should be able to bend them back again.
The possible source of problems is the base plates. Personally I have a CNC machine and have made photocopies of the original base plates before I built it, so I can make my own. But I guess other may not have that possibility.
Edit: But you can look at it like this. A single crash with an original Cinestar, would probably cost more in replacement parts then the entire BlackStar8 kit.
jab is offline Find More Posts by jab
Old Jul 19, 2012, 09:49 AM
DroneBuilder is offline
Find More Posts by DroneBuilder
United States, TN, Brentwood
Joined Oct 2010
Originally Posted by jab View Post
So today I had a very uneventful and successful maiden flight. Very smooth in the air, even with default YS-X6 settings and no expo on the radio. Gave a feeling of being in control even on the maiden flight.
jab -
Thanks for posting your video! I definitely wanted to see it prior to buying one of those frames. Now I definitely want one.
I noticed that you are not using the battery mounting plate, obviously because you don't have to! I have built a Cinestar-ish frame with the batteries on top, and while it flies well, when I carry it around (from my workroom to my backyard) it wants to flip - because all the weight is on the top!
Do you have a similar tendency on your build?
Anyway - looks like that bird has quite a bit of 'punch' when you goose the throttle! It looks like it would be fun to fly - with OR without a camera. Do you plan on mounting a camera?
Thanks again for posting the video. I think sometimes folks forget that it is kinda a PITA to take/post a video.
DroneBuilder is offline Find More Posts by DroneBuilder
Old Jul 19, 2012, 10:09 AM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
DroneBuilder: I am going to install a camera gimbal, so I am waiting with a permanent battery mounts until then. Most likely I will place two batteries at the top sideds of the gimbal under the frame. Better to be bottom heavy then top heavy, so that the copter is more naturally stable.
Old Jul 19, 2012, 12:02 PM
Reginak is offline
Reginak's Avatar
Joined Jul 2011
Whats the gimbal you'll be using and what camera?
And last, whats the distance from the botton plate to the ground.
Old Jul 19, 2012, 12:25 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i think the real downside of this frame of the real cinestar is the vibration isolation gimbal mount that is on the real CS
to be completely honest, i would rather build rusty's frame (aglhobbies) and use his floating plate to mount a gimbal on.
This frame just "looks" like a cinestar..... which i dont need a kockoff to feel cool about myself
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 19, 2012, 07:04 PM
Percalotor - Quad_Addict is offline
Find More Posts by Percalotor - Quad_Addict
Joined Jun 2012
nothing unique or new move along...
Percalotor - Quad_Addict is offline Find More Posts by Percalotor - Quad_Addict
Reply With Quote  (Disabled)
Old Jul 19, 2012, 09:36 PM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
So a couple of dampeners at $75 a piece makes the Cinstar8 worth the extra $1300? I am pretty sure I can order some and make some holes myself, if I want to use that dampening system.
The CineStar is a rigid, simple and proven design that works, but the prices for what essentially is a couple of carbon fiber sheets and tubes is insane. And the design is so simple (part of the attraction) that pretty much anyone can make something equivalent.
Old Jul 19, 2012, 09:42 PM
saabguyspg is online now
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
this is a great looking frame, I have no need for any extra vibration dampener junk on the cinstar...
this frame is in my future
Steve
saabguyspg is online now Find More Posts by saabguyspg
Site Sponsor
Old Jul 19, 2012, 09:51 PM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
I am torn between an AV130 or the Cinestar gimbal.
29,4cm from the bottom plate to the ground.
Old Jul 20, 2012, 09:09 AM View Post
whosYOURdaddy - QuadAddict
A moderator felt this post violated the following rule: Trolling (Widespread). Show it to me anyway.
Old Jul 28, 2012, 11:08 PM
Crissbrasil is offline
Find More Posts by Crissbrasil
BRAZIL
Joined Jul 2010
Please post more videos....
Crissbrasil is offline Find More Posts by Crissbrasil
Old Aug 03, 2012, 09:41 AM
flozano is offline
Find More Posts by flozano
Santiago, Chile
Chile, Región Metropolitana, Stgo
Joined Oct 2011
Jab Congratulations for your Octo, it's really nice.
Please post more pictures and videos..
I'm looking this Octo, and I planing to buy.
How much weight your Octo complete.?
I have a Rusty Hexa with AV130, works excellent, The Gimbal is very good and is't Light than Cinestar, but Cinestar Gimbal is more Flexible and configurable for diferent cameras, also the weight and price are High.
The AV200 are for bigger Cameras.
Also I Have the Skyline RSGS, this is the independient Gyro Stabilization for AV130/AV200 This product have some jittering problems now, but in the new firmware may be they will solve.
It's important to solve how to mout the Gimbal to your Multirotor, the AV 130/200 use mounts for Droidworx and have grommets for isolation (it's not the best) and Cinestar have an axcellent and expensive system (I have a CNC too and I planing to build a similar mounting system like Cinestar)
flozano is offline Find More Posts by flozano
Old Aug 06, 2012, 05:22 AM
Remy is offline
Find More Posts by Remy
Netherlands
Joined Feb 2004
Hmm, After a few weeks I received the Glasfiber Octocopter kit!
Everything looks great, also the quality. It's a little heavy for my taste, but nevertheless the thing is great and strong.
There's one thing That I don't understand,
I want to build a hexa out of the octa. But on Goodluckbuy and on the site of omgfly.com they keep saying "magical frame design allows you to turn it into a hexa" I ordered the Octo, with the thought that if I turn it into a hexa I have two spare arms!
Now I received the kit but I cant find out how to turn it onto a hexa.
Please some help!
Remy is offline Find More Posts by Remy
Discussion Another site like Goodluckbuy, Eforchina DJI450 frame half price bakchos Multirotor Talk 39 Aug 22, 2014 02:26 AM
Question Newbie dreaming...600mm spider quad frame at GoodLuckBuy Jonathan Ott Multirotor Talk 109 Jan 16, 2013 09:17 AM
New Product New inertia camera frame from Goodluckbuy kaz1104 Multirotor Talk 18 Aug 18, 2012 03:35 PM
Discussion Goodluckbuy ST450 Frame flitelab Multirotor Talk 12 Mar 17, 2012 07:09 PM
Discussion Opinions on the <$50 quad frames from GoodLuckBuy? Dax Multirotor Talk 23 Jan 26, 2012 02:43 PM
