Old Jul 05, 2012, 05:16 AM
gurudutt is offline
Find More Posts by gurudutt
Joined Jul 2009
Originally Posted by jab View Post
Yes, GLB has them, or himodel.com
HL W4822 490kv
http://www.goodluckbuy.com/w4822-490...er-24n22p.html
I was planning to build the same octo with the same Motor,ESC combo as yours But was not sure about the qulity.
What do you feel about the motors? are they good ? are you planning to lift any payload?
gurudutt is offline Find More Posts by gurudutt
Old Jul 05, 2012, 06:16 AM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
I haven't flown the setup yet, but initial impression of the motors is good. They have the look/feel/sound you get from solid motors. They also seem to be properly factory balanced (epoxy droplets). Dry runs on the bench with CF 15x55 while not very scientific, was impressive. I had a hard time holding back the motor at 10A 16V, and there was no excessive heat afterwards. With 8 of them I do not think it will have any problem classifying as a heavy-lifter.
jab is offline Find More Posts by jab
Old Jul 05, 2012, 06:37 AM
John141 is offline
Find More Posts by John141
Underwater Helicopter Badge
John141's Avatar
South Africa, WC, Cape Town
Joined Mar 2011
HL W4822 490kv
Thanks mate, I've seen those before and they look good - 300W and will take up to a 6s. Guess you'll be needing at least 13 inch props on them though.
John141 is offline Find More Posts by John141
Old Jul 05, 2012, 07:13 AM
Crissbrasil is offline
Find More Posts by Crissbrasil
BRAZIL
Joined Jul 2010
Please post a video for us.
Crissbrasil is offline Find More Posts by Crissbrasil
Old Jul 05, 2012, 07:55 AM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
Originally Posted by John141 View Post
I want to use props in the 15-16" range for better lift efficiency. At 6S I think the 390kv version might be a better choice then. But the 490kv and 12-13" props should be fine also on 6S also.
Old Jul 05, 2012, 08:11 AM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
JAB, do you think I will be fine with a AUW of 6-6.5Kg with these motors (HL W4822 490kv) and 4S?
Because when I try my possible craft at e-calc I get this:
* The Motor Voltage is close to the Limit - please verify the max. allowed Motor Voltage ** max. current over the limit of the motor. Please verify the limits (current, power, rpm) defined by the
The other alternative of motors is http://www.goodluckbuy.com/w48-30-kv...or-24n22p.html
This motor can take 29A but it weights 50% more, almost 60g x 8 = 480g more weight.
So thats my decision now.. I know you made that calcs when I sent you a PM but thats for lifting, and when I really give the craft a good throttle to speed up. Its just a question... I really want to buy and test this package (frame + motors + 15x5.5 props)
Reginak is offline Find More Posts by Reginak
Old Jul 05, 2012, 08:29 AM
gurudutt is offline
Joined Jul 2009
can't wait to see your pics/vids online...
Old Jul 05, 2012, 10:04 AM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
Reginak: I think the W48-30 would be overkill for 6.5KG AUW. You are spending a lot of energy just lifting the weight of larger motors and battery.
If you look at the specifications for the W48-22 490kv, at 4S spinning a APC14x47 you have peak efficiency at 4.5A - 67W giving 720g (10.81g/W) of lift. That means for a octo, you should have 5.8kg of lift using just 67W on each motor.
So it is not a matter of being able to lift 6.5KG (they can), but how efficient they will be. I am guessing that the more efficient CF 15" propellers will raise the sweet spot to around the 6-7KG mark.
Old Jul 05, 2012, 12:02 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
hey everyone, i saw a few pages back that some one said that it is bad if bolts are in direct contact with CF. why is this? and what should be used as a "spacer". i think i noticed this on my CF center plate when i took out a bolt(a bit of rust/dirt was built up on the bolt)
sirbow2 is offline Find More Posts by sirbow2
Old Jul 05, 2012, 05:00 PM
JanHenning is offline
Find More Posts by JanHenning
JanHenning's Avatar
Norge, Vestfold, Tønsberg
Joined Apr 2010
That can happen, but steel bolts will hold for a very long time. The process will be accelerated if the joint between the two materials is exposed to an electrolyte like salt water, but in most multicopter environments that doesen't apply.
From Wikipedia: Galvanic corrosion is an electrochemical process in which one metal corrodes preferentially to another when both metals are in electrical contact and immersed in an electrolyte.
JanHenning is offline Find More Posts by JanHenning
Old Jul 06, 2012, 07:13 PM
Reginak is offline
Reginak's Avatar
Joined Jul 2011
JAB,
Do you have any picture of the frame with the 15x5,5 props? I would like to see how it looks....
Old Jul 07, 2012, 04:52 AM
Remy is offline
Find More Posts by Remy
Netherlands
Joined Feb 2004
Can anyone -who has this Goodluckbuy frame already- confirm that you can also make a hexa with it?
I ordered the Glasfiber Hexacopter, but one day after my order they have the octa from for just 20 dollars more.
They say that you can also change it in a hexacopter. Great! I ordered the octa, make a hexa with it, and have two spare armes.
Already changes the order, so hopefully you can confirm that you can make a hexa with it.
It's already shipped, I think it's here in a few days. (netherlands)
( the discription say's it can )
Remy is offline Find More Posts by Remy
Old Jul 07, 2012, 06:29 AM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
Yes, the CF octa version can at least be made into a hexa instead.
Old Jul 07, 2012, 07:12 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Cant wait to check out your build!
koolkiwikat is offline Find More Posts by koolkiwikat
Old Jul 09, 2012, 06:29 PM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
Originally Posted by Reginak View Post
JAB,
Did some more work today, very close to lift-off now. Just need to CNC some new battery trays, one for each side so that I can mount two batteries.
Discussion Another site like Goodluckbuy, Eforchina DJI450 frame half price bakchos Multirotor Talk 39 Aug 22, 2014 02:26 AM
Question Newbie dreaming...600mm spider quad frame at GoodLuckBuy Jonathan Ott Multirotor Talk 109 Jan 16, 2013 09:17 AM
New Product New inertia camera frame from Goodluckbuy kaz1104 Multirotor Talk 18 Aug 18, 2012 03:35 PM
Discussion Goodluckbuy ST450 Frame flitelab Multirotor Talk 12 Mar 17, 2012 07:09 PM
Discussion Opinions on the <$50 quad frames from GoodLuckBuy? Dax Multirotor Talk 23 Jan 26, 2012 02:43 PM
