Germany, BY, Neubiberg
Joined Aug 2012
Whats the diameter of this hexa? I heard Naza GPS doesn't do well in large frames but your setup seems to prove it wrong! Have you tested flight times with gimbal and big camera? I guess you will need another battery in parallel to keep flight times over 5 minutes. |
@ Papajeff: I used FY-20A to stabilize the gimbal that's the wires+battery you see ehind the gopro
![]() @ Saabguyspg: The Booy BY2 is quite good quality regarding the price, I found it too slow on the roll axis but it can easily be modified for someone handy. I hadn't time to test it very much since a friend at FlyingCopter offered me to test his 'Monroe' Gimbal: http://www.flying-copter.com/fr/nace.../3-monroe.html @ Velociraptor: Diameter is 1m, and I can tell you Naza handles it really great at 130% gain it's more stable than my previous quad. I'm using SimonK flashed escs btw. Flight time is around 5' with gimbal and gopro, so you're right i'll have to use a 2nd battery in parallel. Anyone have an idea wether the use of 6s battery can change anything to the flight time? |
Joined Mar 2008
Flyboone i think you need to change your esc location, you can burn them like that.
Read http://www.rcgroups.com/forums/showthread.php?t=952523 better place them between plates. Also some hight magnetic interference from fire thru arms. Best is to have motor-esc wire thru arms, no esc-battery wire thru arms. |
| Thread Tools | |
| Question Newbie dreaming...600mm spider quad frame at GoodLuckBuy | Jonathan Ott | Multirotor Talk | 109 | Jan 16, 2013 09:17 AM |
| New Product New inertia camera frame from Goodluckbuy | kaz1104 | Multirotor Talk | 18 | Aug 18, 2012 03:35 PM |
| Discussion Goodluckbuy ST450 Frame | flitelab | Multirotor Talk | 12 | Mar 17, 2012 07:09 PM |
| Discussion Another site like Goodluckbuy, Eforchina DJI450 frame half price | bakchos | Multirotor Talk | 38 | Mar 10, 2012 08:21 AM |
| Discussion Opinions on the <$50 quad frames from GoodLuckBuy? | Dax | Multirotor Talk | 23 | Jan 26, 2012 02:43 PM |
