Old Oct 08, 2012, 08:10 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by Papajeff View Post
Thanks for the suggestion, Andy. What do think of the XT 60's?
Good connectors but for what you are going to lift I would not trust it. I've seen S800s have the XT60 desolder from sustained high current.
Sid3ways is offline Find More Posts by Sid3ways
Old Oct 10, 2012, 03:04 PM
JetFire21 is offline
Find More Posts by JetFire21
Too much of a good thing...
JetFire21's Avatar
Joined Mar 2011
Does anyone know if GLB removed the 25mm version of the octocopter from they're site? I cant seem to find it anymore, at the same time I noticed that omgfly has increased the price on theirs to $495.
JetFire21 is offline Find More Posts by JetFire21
Old Oct 10, 2012, 04:25 PM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
Seems so.
But do you really need the 25mm version? The 22mm is plenty rigid enough. Using 25mm tubes only adds weight, and makes repair more expensive.
jab is offline Find More Posts by jab
Old Oct 10, 2012, 06:28 PM
roalddogge is offline
Find More Posts by roalddogge
Singapore
Joined Jul 2006
indeed it looks that 25mm is only in RTF version.
I bought the 25mm and indeed it seems to be overkill. 22mm or maybe 16mm should be more than enough.
Ro
roalddogge is offline Find More Posts by roalddogge
Old Oct 11, 2012, 01:26 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
500 bucks for a CF Octo frame? I'll take it! Haven't seen anything this cheap anywhere else.
WiseDuck is offline Find More Posts by WiseDuck
Old Oct 11, 2012, 01:56 AM
JetFire21's Avatar
Joined Mar 2011
Originally Posted by jab View Post
Seems so.
Thanks Jab! I wasn't sure yet about which version to get, I figured the original cinestar frame used the 25mm so i thought of going with that. Im gonna be using dual 5000 6s packs and carrying a Canon 7D so I wanna be sure it can handle the weight. One other thing, are the kits sold at GLB the same as the ones from Omgfly?
Old Oct 11, 2012, 04:33 AM
jab is offline
jab
jab
Unregistered User
Joined Aug 2007
As long as the frame is rigid enough, lift capacity is decided by motors and propellers. Lifting a camera like 7D is what octo's are "made" for.
Judging by the pictures, the omgfly frame and the goodluckbuy one are the same.
Old Oct 12, 2012, 01:06 AM
JetFire21's Avatar
Joined Mar 2011
Originally Posted by LucioleMC30 View Post
Received mine this morning, gonna equip it with a 2axis gimbal
Very good quality, just had to pay 40 to customs with DHL.
Very interesting posts Papajeff, what flight controller will you be using?
And other question: is it necessary to flash the escs? haven't done that yet..
Hey Luciole, How did that booy 2 axis gimbal workout for you? Do you like it?
Old Oct 15, 2012, 07:54 PM
Papajeff is offline
Find More Posts by Papajeff
AMA 869451 / FAA 13675
United States, NY, Rochester
Joined Jan 2006
JetFire, I am also interested in finding out if Luciole likes his Booy 2 gimbal
from Good Luck Buy. I am so surprised that they have such a large selection
of camera gimbals and MRC products.
Papajeff is offline Find More Posts by Papajeff
Old Oct 15, 2012, 08:49 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
Joined Sep 2008
I am pleased to hear that, as my Octo-clone "Egor," is finally taking shape and should be ready for
test flight in a week or so. How about a few links to where you are posting now, as I have learned
a great deal from you and would like to follow your MRC adventures
Not sure what motors you are using but if they draw more than 10a(guessing they are since you are using expensive 50a ESC's)you will melt that cheap distro board.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Oct 15, 2012, 10:15 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
I take the distro boards (whatever make) and sand off all the plastic coating, then you are left with large traces of + and -
then lay gobs of solder all along the nice wide traces.... then you have a nice light efficient board good for lots more amps than originally designed for... how many amps? who knows but its loads better than before.
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Oct 16, 2012, 01:41 AM
JetFire21's Avatar
Joined Mar 2011
Indeed Papajeff, they even have one with the fancy white ball for under $400!! I did however end up purchasing the 2 Axis Booy gimbal for my Octo and hopefully should have it soon. But if you have a chance Luciole let us know your thoughts on the gimbal. Thanks!
Old Oct 16, 2012, 10:52 AM
Papajeff is offline
Joined Jan 2006
Tony, thanks for the heads up on the power dist board. I'm using the HL 48-22-490kv motors which run
at <12A with a max of 17A. I never thought that I might have a problem with that $4.00 HK board. My
motor wires are about 16 guage and that is the extension size that I used and the 3.5mm gold pin
connectors were a perfect fit.
I did add solder to each (F) connector on the board and never thought that I could develope enough heat
to "un-solder" a connection. However, you ought to know with your MRC experience. Do you suggest
changing it out for another option, because I certainly do not want any problems like this with such an
expensive MRC.
Yeah, the ICE 50's are overkill, but with their new "multi-rotor" catagory on their Castle Link, I thought that
they would give me the ability to test using 4S to 6S and 10" to 15" props to see which combination would
be the best for this big Octo.
Old Oct 16, 2012, 11:28 AM
Jason Cole is offline
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
Jeff,
I'll be using the PowerHungrySystems Distro Board on mine. Although I am using eRC 25 motors and eRC 65A ESC's which will be more power.
Here's a link to the board. http://www.hobby-lobby.com/multi_rot...41392_prd1.htm
Jason Cole is offline Find More Posts by Jason Cole
Administrator
Old Oct 16, 2012, 02:56 PM
LucioleMC30 is offline
Find More Posts by LucioleMC30
ToucanWings.fr
LucioleMC30's Avatar
France, IdF, Paris
Hi guys,
well haven't flown it yet, I just received my simonk flashed escs and have to maiden my hexa now.
However I tested the gimbal and even though it's great quality for this price, it might need modification on the roll axis cause it's not moving fast enough (small gearwheel driving a long belt) so i'll either need a faster servo or a bigger gearwheel.
Also i'm a beginner at using belt driven gimbals so i've to find out the best way to stabilise it since I can't use the Naza gimbal outputs. For testing i'm thinking about using a plane stabiliser (Fy-20A) but not sure wether it's a good choice...
Some pics of my advance on this amazing frame:
LucioleMC30 is offline Find More Posts by LucioleMC30
Discussion Another site like Goodluckbuy, Eforchina DJI450 frame half price bakchos Multirotor Talk 39 Aug 22, 2014 02:26 AM
Question Newbie dreaming...600mm spider quad frame at GoodLuckBuy Jonathan Ott Multirotor Talk 109 Jan 16, 2013 09:17 AM
New Product New inertia camera frame from Goodluckbuy kaz1104 Multirotor Talk 18 Aug 18, 2012 03:35 PM
Discussion Goodluckbuy ST450 Frame flitelab Multirotor Talk 12 Mar 17, 2012 07:09 PM
Discussion Opinions on the <$50 quad frames from GoodLuckBuy? Dax Multirotor Talk 23 Jan 26, 2012 02:43 PM
