Old Aug 29, 2012, 12:07 PM
Spyde is offline
Find More Posts by Spyde
Denmark, Region Zealand, Jyderup
Joined Jun 2010
Try beedrone.com
Spyde is offline Find More Posts by Spyde
Old Aug 29, 2012, 01:21 PM
Papajeff is offline
Find More Posts by Papajeff
AMA 869451 / FAA 13675
United States, NY, Rochester
Joined Jan 2006
Originally Posted by Reginak View Post
Papajeff,
Its ok for me and I want to thank you for the effort.
And a question, does goodluckbuy or other place carry the boom clamps used in this octo? A place where I can get spare parts like this one?
Reginak, I just saw that this is the best place to get parts from;
http://www.omgfly.com/index.php?main...dex&cPath=1_41
It was in a post from a few pages ago. Looks like they have just
about everything and I wonder why Good Luck Buy does not!
Papajeff is offline Find More Posts by Papajeff
Old Aug 30, 2012, 07:36 AM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
Parajeff,
Two questions.
- What power distro is you using?
- What is your expected AUW? I'm asking this because I already have a skyjib (currently crashed and being rebuild) and now I want something cheaper as an AP backup, and I think my AUW will be something like 7kg (15.5lbs) and I will be using 15" like JAB.
My only worry is that the frame is not stiff enought for this kind of AUW... I think JAB was the only one what tested it with a lot of weight but it was only 4 seconds and I can't tell if it was stiff or not during this short flight..
Reginak is offline Find More Posts by Reginak
Old Aug 30, 2012, 08:06 AM
Papajeff is offline
Joined Jan 2006
Parajeff,
Two questions.
I will be using a Spectrum DX-18 Tx, AR8000 Rx, 8 Castle ICE50 ESC, 8 HL
48-22 490kv motors, and 2 x 3S or 4S - 40C 5000mAh packs in parallel to give
3S or 4S 10,000mAh.
My AUW should be around 10lbs with out a camera and around 15 with a Canon 7D.
I will definately refine these estimates as the Octo build is completed, weighed, and
tested. I hope that this helps.
Old Aug 30, 2012, 08:05 PM
Papajeff is offline
Joined Jan 2006
Question for Batfire
Hey Bat,
Is it necessary to use a washer between the Hex motor attachment
screw and the CF motor mounts? As you can see in this photo, I did
not, but before I use thread lock I wanted to be safe and ask you first.
Old Aug 30, 2012, 10:10 PM
batfire is offline
Find More Posts by batfire
Connecticut Quad Hacker
batfire's Avatar
Joined Dec 2009
Originally Posted by Papajeff View Post
Hey Bat,
Hi Papajeff
Just reading the thread here and see you posted a question for me, caught me off guard. Anyway to answer your question top and bottom see pic below dont have a bottom pic sorry but I do to reduce ware on CF.
batfire is offline Find More Posts by batfire
Old Aug 30, 2012, 10:13 PM
batfire is offline
batfire's Avatar
Joined Dec 2009
Originally Posted by batfire View Post
Hi Papajeff
BTW thats a heck of a nice build you got going there. I picked up the quadframe Hexacopter but wont start actual construction until after mid October due to very busy and finishing th X830 project.
Old Aug 30, 2012, 11:56 PM
manvsuav is offline
Find More Posts by manvsuav
Closed Account
Joined Mar 2012
hey papajeff,
if i can ask, are the plates easily bendable, as in, if you grab both sides and try to flex or bend them? i just want to know the quality and stiffness of these copies. its the shine that deceives me
It seemed logical to start with the Hub assembly and I took the top plate and inserted 32 of the Hex head bolts
(M3x 40mm) into the proper holes, 4 per rectangular cutout in the plate to accept the arm clamps.
manvsuav is offline Find More Posts by manvsuav
Old Aug 31, 2012, 02:56 AM
hugy is offline
Find More Posts by hugy
hugy's Avatar
Joined Apr 2010
Building mine as a x8.
hugy is offline Find More Posts by hugy
Old Aug 31, 2012, 07:04 AM
Papajeff is offline
Joined Jan 2006
Originally Posted by manvsuav View Post
hey papajeff,
IHMO the CF plates and the booms do not flex at all and I have seen some very
cheap CF used on other models. Also, I believe that CF is now available in many
different finishes and they all look slightly different.
Old Aug 31, 2012, 07:12 AM
Papajeff is offline
Joined Jan 2006
Hi Papajeff
Thanks Bat, I had a feeling that was the way to go and now I know for sure!
Have a great Holiday weekend!
Old Sep 01, 2012, 08:27 AM
flozano is offline
Find More Posts by flozano
Santiago, Chile
Chile, Región Metropolitana, Stgo
Joined Oct 2011
Papajeff
Wich propeller do you want to use with 4S?
Nice build.
flozano is offline Find More Posts by flozano
Old Sep 02, 2012, 06:31 PM
Papajeff is offline
Joined Jan 2006
Flozano, I had planned to start with 12x4.5 props and go from there. However,
from what I have seen on the posts here, I have a feeling that because my
motors (HL Model: W48-22 490KV) are going to be extremely powerful on the
Octo using a 6S pack, I might have to test several smaller size props (11, 10,
9 inch) or go with a 4S pack. Obviously, I will know for sure when I get to the
testing stage of my build.
Old Sep 02, 2012, 07:58 PM
rabone is offline
Find More Posts by rabone
United Kingdom, England, North York
Joined Oct 2010
bad news the GoodLuckBuy have cancelled my orders ? because i op-end a dispute about the 13x6.5" Propeller For MultiCopter, they have come and all going ccw and not ccw & cw,now because i opened a dispute they have cancelled my order for the big hexa and refunded my money and stoped me from buying from GoodLuckBuy, what did they expect sending me the rung Propeller out i don't know ,so GoodLuckBuy strike again and took me for £50 ,
ho and get this in my pay pal i bought the
CW CCW APC 13x6.5" Propeller For MultiCopter
now iv contacted GoodLuckBuy and complained they have alerted there listing to say APC 13x6.5" Propeller for RC Airplane ,so beware of what you buy if you use GoodLuckBuy
rabone is offline Find More Posts by rabone
Old Sep 03, 2012, 02:57 AM
Vojec is offline
Find More Posts by Vojec
Slovenia, Ljubljana
Joined Jan 2012
Hi Papajeff,
Just wonder how high or long landing legs are? Thanks.
Vojec is offline Find More Posts by Vojec
Discussion Another site like Goodluckbuy, Eforchina DJI450 frame half price bakchos Multirotor Talk 39 Aug 22, 2014 02:26 AM
Question Newbie dreaming...600mm spider quad frame at GoodLuckBuy Jonathan Ott Multirotor Talk 109 Jan 16, 2013 09:17 AM
New Product New inertia camera frame from Goodluckbuy kaz1104 Multirotor Talk 18 Aug 18, 2012 03:35 PM
Discussion Goodluckbuy ST450 Frame flitelab Multirotor Talk 12 Mar 17, 2012 07:09 PM
Discussion Opinions on the <$50 quad frames from GoodLuckBuy? Dax Multirotor Talk 23 Jan 26, 2012 02:43 PM
