Joined Aug 2011
9mm EPP Laminated Weight Bearing Test
Lately I have been building wings with 9mm EPP foam and decided to test the weight bearing ability of laminated EPP. I bought the laminate from a copy shop but had to measure it with a micrometer to determine size.
Here are the results of my test with photos. The weights are approximate as my scale is not digital. I just kept adding double a batteries until the foam/laminate collapsed. Single lamination was a single layer on all surfaces. Double was two layers. 10cm * 50cm 9mm EPP Weight Bearing Test Laminate Used..................Weight of Foam with Laminate.....Weight Until Collapse none...................................12 grams.......................................70 grams single .045mm laminate.....25 grams.......................................340 grams double .045mm laminate....35 grams.......................................660 grams single .095mm laminate.....30 grams........................................950 grams Looks like the single layer of .095 laminate is considerably stronger, even than the double layer of .045. Laminated EPP foam is really strong stuff. I am finding that wings made of laminated epp last much longer than ones made of foam board. The foam board wings get soft and mushy after a while and then never fly consistently. The epp wings always stay stiff, the components don't move and they fly the same way everytime.
| Thread Tools | |
| Discussion twist caused by landing gear install on 1.3# 9mm epp | rateoneturn | Foamies (Scratchbuilt) | 2 | Oct 07, 2011 01:28 AM |
| For Sale 9mm Epp 24" x 36" sheets | Erroet | Aircraft - General - Miscellaneous (FS/W) | 3 | Sep 28, 2011 08:51 PM |
| Discussion 9mm OD bearing tube?? | Propjob81 | Electric Motor Design and Construction | 1 | May 26, 2006 08:29 PM |
