It can be converted to FrSky using the DIY module and tapping into PPM that is generated for the trainer port. You can even have the best of both worlds by keeping the DSM2 module and setting up to switch between the two. This would require two antennas.
To do this you'll have to do some homework and have decent soldering and related skills, but it shouldn't be too difficult. Not sure if you can find exactly the right conversion, but there should be enough info around In searching for info on how to do it, don't limit yourself to FrSky, as FlyDream and Corona install in essentially the same way. Similarly, your transmitter is essentially the same as the X9303 (the earlier XP9303 is the one with plug-in module). |
Latest blog entry: Polaris Aileron Pushrods
One way to do a "non-destructive" conversion is to copy the AnyLink setup. That simply mounts a module on the back of the transmitter and plugs into the trainer jack for PPM and the charge jack for power. I have one and it works fine with my DX7. No reason it shouldn't with my X9303. Of course the transmitter switch must be OFF for this to work. And you have to remember to unplug the outboard module when not in use or you run the battery down. But it's eminently practical, fairly easy to do (take a look at the stuff on AnyLink and figure out how to fit an FrSky DHT into a small box with antenna suitably located) and its totally reversible. Did you see this thread? http://www.rcgroups.com/forums/showthread.php?t=1641084 |
Guanaba QLD Australia
Joined Jun 2009
I take it that the larger Red is pos + to Frsky module, brown is neg - and the orange is ppm to module? I notice in post #8 you are showing pos + to frsky module from the back of the switch?? Would apprieciate if you could clarify. Thanks David. |
Hi. David sorry for the confusion
I was having problems with my camera and used a pic. from the other thread for showing the location of R33, ignore the other wires shown in that pic. Frsky +ve connects to the Switch Frsky PPM connects to the wire on Pin 4 Cn8 Note. You MUST remove R33 or cut the track between R33 and the Trainer socket to enable a modulated PPM signal. I have returned this Tx to it's owner, so unable to get better photo's now I added more info to this pic. hope it's a help Paul |
Joined Jun 2009
Just a couple of further questions! do you leave the white cable connected to pin 4 and just strip back the cable and connect/solder the ppm from Frsky module to it? Thanks again David. |
Joined Jun 2009
No did not notice the antenna, operated all ok ?? David. |
| Thread Tools | |
| For Sale Multiplex FR module | Rain Maker | Aircraft - General - Radio Equipment (FS/W) | 1 | Mar 31, 2012 09:42 PM |
| Discussion Jr dsx9 v2 | fgollie | Radios | 5 | Feb 11, 2012 06:59 AM |
| Discussion JR dsx9 v2 - pitch curve | jjjjdup | Radios | 0 | Feb 09, 2012 03:46 AM |
| Sold JR DSX9 MK2 with RD921 | 3d astronaut | Aircraft - General - Radio Equipment (FS/W) | 2 | Dec 04, 2011 02:09 PM |
| Discussion FR Sky receivers | cfergie | Beginner Training Area (Heli-Electric) | 2 | Nov 09, 2011 01:22 PM |
