Old Jun 11, 2012, 05:33 AM
wenney2009 is offline
Find More Posts by wenney2009
Joined Nov 2011
New Product
JCX-M6 Flight Controller for RC Airplane RC Model Plane FPV Fixed-wing Airplane
Technical Specifications:
1. Dimension: 30 x 42 mm
2. Weight: 6 g
3. Voltage: 4-9 V DC
4. Current: 40 MA(max)
5. Sample Rate of Gyro: 2 KHz
6. PWM Input: 5 0Hz PMW
7. PMW Output: 50 Hz PMW
8. Operating temperature: -25℃ to 80℃
JCX-M6 is a flight controller especially designed for fixed-wing airplanes. It can perform calculation for flying wings, elevators, and rudders and output compensation rudder volume for channels in real time to facilitate stability of airplanes during flight. JCX-M6 features special flight assistance function which can help control flight modes. Inverted flight, slanting flight, and hanging flight are available without compromise. Under a fourth or fifth wind force, airplane KT330 can still have inverted flight, slanting flight, and hanging flight. With proper power and driving force, wind is not a problem now. fixed wings, flying wings (triangular wings), and V-tails (aero-engine airplanes, CESSNA, and 3D devices) are supported.
Functions:
1.Stable flight: In enhanced-stability mode, the gyroscope automatically adjusts to compensate for fixed wings, elevators,and rudders. This enhances wind-resistance capability and reduces speed failure to allow for stable flight. 3D flights such as inverted flight, slanting flight, and hanging flight become easy and do not compromise the controllability of airplanes. Flight
become so easy for us.
2.Stunt flight assistance: Stunt flight modes, besides facilitating stability of flight, feature the flight locked function by high-precision digital gyro automatically locking the channels of Aileron, Elevator, and Rudder. This function makes inverted flight, slanting flight, hanging flight, and even 360-degree rotation available without compromise which indicates a more accurate flight control with flexibility at the same time. Take off and landing become quite easy, if without considering center of gravity had adjust, the difficult flight's plane also will be easy to control. More information will be demonstrated in the 8th item of Notice for the first use.
3.Independent gyro gain adjustment potentiometer and the algorithm of software gyro gain make the gyro into its best automatically.
4.4-digit DIP switcher makes the functional settings for board become easy and convenient.
5.Controlling switcher of flight manual is used through the channel of on-and-o仟 on the remote control to controlthe start function. When at high altitudes, flight manual control is able to be achieved by this switch so that you can feel the flight tunctions of plane whether it is controlled or not, practice flight control in none-flight manual mode, and improve your skills easily.
6.Red and blue LED lights make it easier to tell the work mode and the opposite.
7.Its small size of 30x42mm, the weight of 6g, and perfect configuration make it easily to be installed and used in any size of planes.
8.lt is supportive to various types of fixed-wing, flying-wing,and V-tail.
Test video:
[JCX-M6 Flight Controller for RC Airplane] Mini 330 (50cm) KT Board 3D Small plane (0 min 0 sec)
More M6 Flight Controller
http://www.rc4y.com/jcxm6-flight-con...ane-p-458.html
wenney2009 is offline Find More Posts by wenney2009
Old Jun 12, 2012, 02:28 AM
wazoo22 is offline
Find More Posts by wazoo22
wazoo22's Avatar
France, Bourgogne, Nevers
Joined Feb 2012
Sorry, but your post is almost incoherent.
Everyone realizes that foreign languages can be a problem, but if you want your product to be taken seriously, you gotta do better than this.
Hire someone.
wazoo22 is offline Find More Posts by wazoo22
Old Jun 12, 2012, 05:04 AM
RC4YFPV is offline
Find More Posts by RC4YFPV
Joined Jun 2012
Hire someone.
Thanks for your advice.
Have a good time.
RC4YFPV is offline Find More Posts by RC4YFPV
Old Jun 19, 2012, 06:10 AM
9XTremist is offline
Find More Posts by 9XTremist
AMA 962750
9XTremist's Avatar
United States, CA, San Bernardino
Joined Feb 2010
His lack of English seems no worse than your grammatically in-correct placement of commas.
Perhaps you should hire someone.
Thanks for your continued support,
Michael Clyde
9XTremist is offline Find More Posts by 9XTremist
New Product Flight Controller for Quadcopter Multicopter with Fixed Hight Direction Care Free CF iseekk Multirotor Electronics 9161 Dec 03, 2015 08:28 AM
Discussion Jcx-m6 flight controller DAVID.KADMAC Power Systems 14 Oct 26, 2013 04:35 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 04:38 PM
