Old Jun 11, 2012, 02:44 AM
bobmixon is offline
Find More Posts by bobmixon
bobmixon's Avatar
United States, AZ, Glendale
Joined Oct 2009
Question
3S 11.1V 2200mAh 30C Battery
Greetings all,
Quick question; I have an e-flite 3S 11.1V 2200mAh 30C battery. What does the 30C stand for? I see the same battery by e-flite with a 50C and it cost a bit more. Whats the difference?
Thank you!
Bob
bobmixon is offline Find More Posts by bobmixon
Old Jun 11, 2012, 05:20 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The C rating is the maximum discharge rating. 30 C means that the maximum current is 30 times the capacity. 2.2 amp hour times 30C is 66 amps. A 50C 2200 is designed for 110 amps.
Advantage of higher C is that the internal resistance is lower and it has heavier wires and sometimes a larger connector to handle the higher current. They also hold voltage better under load.
The disadvantage is higher C is that they are more expensive, usually heavier and sometimes a little larger so check the dimensions before you order.
RC Man is online now Find More Posts by RC Man
Old Jun 11, 2012, 05:26 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Also, before you go and spend more $ thinking "Bigger is better" know that most manufacturers greatly overestimate the C rating of the packs they sell, especially when you start getting up to 50C and higher packs.
Lardog is offline Find More Posts by Lardog
Old Jun 12, 2012, 12:19 AM
djacobox372 is offline
Find More Posts by djacobox372
Joined Mar 2009
Keep in mind that the c rating is what the battery is capable of delivering for a very short time, a 30c 2200mah battery wont typically handle more then 30amps continuously.
djacobox372 is offline Find More Posts by djacobox372
Old Jun 12, 2012, 05:10 AM
United States
Joined Feb 2001
Most batteries now days have a two number like 30c/40c. That indicates that the battery can sustain a continuous discharge or 30c until itís empty with short bursts to 40c. If a manufacturer only states one number that is suppose to be the continuous discharge rating but some are not very truthful in that number.
If you do try to run very high amperage make sure that your ESC and motor are up to the task.
Old Jun 13, 2012, 09:58 AM
bobmixon is offline
bobmixon's Avatar
Joined Oct 2009
Got it! Thank you very much everyone; great information...
I think I am beginning to understand electrics. I certainly am enjoying flying them; so much quicker and less hassle then nitro planes.
Thank you again...
Discussion E-Flite Battery Charger Issue (Youtube Video Included) - 2200mAh 30C 11.1V h8tow8 Batteries and Chargers 17 Feb 18, 2012 09:55 PM
Discussion Where can I find SKY LIPO 2200mAh 3S 11.1V 30C battery? All sold out??? h8tow8 Batteries and Chargers 4 Jan 22, 2012 05:22 PM
Discussion Best Dual Charger for 2 x 2200mAh 11.1V 3S 30C batteries h8tow8 Batteries and Chargers 5 Jan 21, 2012 05:07 PM
Sold 2 Electric Power 3s 20-30C 2200mah 11.1v Lipos (for T-REX 450) ShokWaveRider Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 01, 2011 04:37 PM
Discussion How to charge? 30C (66-Amp) 3S 11.1V 2200mAh lawlist 3D Flying 8 Oct 15, 2011 08:28 PM
