Espritmodel.com Heli Air
Old Jun 10, 2012, 07:17 PM
"Spark Chaser"
jokeane's Avatar
United States, WI, Middleton
Joined Jun 2004
Tech One Pop Wing, Mini Pop Wing - anyone tried to slope these?
Kits seem reasonably cheap... but I thought I'd ask the experts first if anyone has tried one sans motor.
http://www.nitroplanes.com/techone.html
jokeane is offline Find More Posts by jokeane
Old Aug 11, 2012, 06:44 PM
wolfv's Avatar
Las Cruces, NM
Joined May 2007
same question
Hi jokeane. I had the same question.
I am deciding between the Bee 2 and the Pop Wing 1200 (both are 4 ft span). I will learn sloping in rocky terrain with no landing zone. So I like a slow glider for easy catching. Also a tough glider for diving into rocks, bouncing off rocks, and cart wheeling over rocks.
The main Pop Wing thread is on http://www.rcgroups.com/forums/showthread.php?t=1428598
I am guessing that a Pop Wing 1200mm glider's wing loading would be 3.8 to 3.9 oz/sq ft (see http://www.rcgroups.com/forums/showp...&postcount=484)
wolfv is offline Find More Posts by wolfv
Old Aug 12, 2012, 02:44 PM
Manilla slope Fest
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Personally, the Bee is a far better choice for a slope introduction ,it will take you from newbie to Combat to DS without any drama ,the pop wing even has foam ailerons which on the slope would last around ten minutes . IMHO
steve wenban is offline Find More Posts by steve wenban
Latest blog entry: 4 days
Old Aug 14, 2012, 01:27 AM
wolfv's Avatar
Las Cruces, NM
Joined May 2007
You're probably right. From reading Slope forum I gather that the Bee 2 is the toughest glider ever made. Why do balsa elevons last longer than EPP elevons? Balsa airplanes crunch on rocks where EPP airplanes bounce.
Old Aug 14, 2012, 01:46 AM
Manilla slope Fest
Joined Dec 2003
hard balsa is used in the TE stock and when fibre taped and covered are vastly stronger and stiffer than any foam at the same thickness can ever hope to be . So they remain responsive in all condition and don't flex at speed
Old Aug 14, 2012, 07:00 AM
wolfv's Avatar
Las Cruces, NM
Joined May 2007
Thanks for the explanation Steve.
Discussion Nitroplanes.com Tech One Pop Wing EPP Kit BACK IN STOCK! Nitro_Nancy Foamies (Kits) 2 Aug 10, 2012 01:22 PM
Discussion tech one pop wing zebtqb Flying Wings 29 Jul 30, 2012 12:20 PM
Yippee! Nitroplanes.com Tech One Pop Wing EPP Kit BACK IN STOCK! Nitro_Nancy Flying Wings 13 May 25, 2012 12:55 AM
Question Anyone Tried One of These?? radiocycle Aerial Photography 3 Mar 03, 2012 09:42 PM
