Old Jun 10, 2012, 01:23 PM
jmc67 is online now
Find More Posts by jmc67
United States, NY, Dutchess County
Joined May 2005
Walkera UFO MX400 - No More
Original Walkera MX400 frame, motors and props.
KK board v5.5 running firmware v4.7
Power distribution board
Hobbywing FlyFun 30A Brushless ESC
Spektrum AR600 rx
Spektrum DX7 tx
Power distribution board is mounted where the original walkera esc was. The round disc like plastic is from a pack of DVD's I had. This is semi hard plastic. Had to use this in order to set the quad for X mode. Without this, my only option was + mode.
I setup the board and then did a test hover with default pots set at 50, 0, 50 with some trimming and was perfect. All I have to do now is to do some final adjustments on the pots. The quad now is faster and has a nice climb.
jmc67 is online now Find More Posts by jmc67
Old Jun 12, 2012, 08:52 AM
Ariete is offline
Find More Posts by Ariete
Madrid, Spain
Joined Oct 2009
Why did you do that?
Did you fried walkera electronics or never had them?
Ariete is offline Find More Posts by Ariete
Old Jun 12, 2012, 01:18 PM
jmc67 is online now
Joined May 2005
I do have the original walkera electronics and are in working order. I like to experiment especially with this hobby.
Old Jun 12, 2012, 02:09 PM
ToniCH is offline
Find More Posts by ToniCH
Total newbie
ToniCH's Avatar
Joined May 2012
Hi, Jmc67
What a cool co-incidence. I today received parts to do something like that. My motivation is based on the fact that I did fry the original Walkera ESC/BEC board and as its priced pretty high here in europe I opted to spend just a few bucks more and change everything.
Here is what I got planned:
- Eagle N6 v2 flight controller
- Turnigy Plush 30A ESC's
- Walkeras RX1002 10 channel receiver (my MX400 came with DEVO 10)
- HK power distribution board
- wires, connectors etc.
Will tackle this some day soon. Started today by soldering connectors to the ESCs.
Good idea about the CD-box disc. I was wondering what to use to cover that hole.
ToniCH is offline Find More Posts by ToniCH
Old Jun 12, 2012, 03:04 PM
poprocz is offline
Find More Posts by poprocz
United States, GA, Flowery Branch
Joined Apr 2012
I'm waiting on four motors for my MX400, how might I know if the board is bad or if it is the motors themselves?
Back left feels like it's binding, not spinning as freely as the others and the front left just won't spin at all.
poprocz is offline Find More Posts by poprocz
Old Jun 12, 2012, 03:08 PM
ToniCH is offline
Total newbie
ToniCH's Avatar
Joined May 2012
Swap the motor wires to other ESC connections and see what happens. I am sure you can identify a connection or two which work for sure. Try your motors in these connections. If they do not work even in those connections then the motors are bad. If all work ok then your board is most likely bad.
Also, take the motor tops off and check if you still have all the motor top bearings left. They can fly away if motor top comes off for any reason.
Old Jun 13, 2012, 02:59 AM
Ariete is offline
Madrid, Spain
Joined Oct 2009
Originally Posted by ToniCH View Post
Hi, Jmc67
I think you will also need a control board (kk, multiwii, ..), the heart of the system.
Old Jun 13, 2012, 05:17 AM
poprocz is offline
Joined Apr 2012
ThanksToniCH, being a total newbie this will be my first repair, diagnostics type of operation.
Not looking forward to it but am looking forward to the learning process.
First of many to come I understand from reading the forums on RC flying. lol
Old Jun 13, 2012, 07:13 AM
ToniCH is offline
Total newbie
ToniCH's Avatar
Joined May 2012
Yeah, I think I have that covered.The first thing on the component list is "Eagle N6 v2 flight controller"
Its in the photo too, the little bag containing the control board - below its box which says "Eagle".
Here it is out of its bag (battery for scale):
Old Jun 14, 2012, 05:26 AM
Ariete is offline
Madrid, Spain
Joined Oct 2009
Sure it is tiny.
Didn't know of this controller I will see how it's rated.
Old Jun 14, 2012, 02:14 PM
ToniCH is offline
Total newbie
ToniCH's Avatar
Joined May 2012
Sure it is tiny.
This video and the fact there isn't much hassle with firmwares made me choose it over KK etc.
Quadrocopter - Eagle N6 V2 (6 min 14 sec)
Old Jun 23, 2012, 10:58 PM
jmc67 is online now
Joined May 2005
Today I decided to try different props using the original walkera motors. It was successful but was unable to balance out one of the props. However, it flew ok without any adjustments to the board. I had to use one of the plastic prop shaft adapter and force install around the hex type head on the motor. The three bearings used inside the prop shaft is to help keep the prop balanced.
Board used: KK board v5.5 running 4.7 firmware (X mode)
10x4.5 props with multiple shaft adapter.
3mmx12mm hex screw with washer
3 each 3x6x2.5 bearings
Test1 - Different props using original MX400 motors (1 min 26 sec)
Test2 - Different props using original MX400 motors (1 min 49 sec)
Old Mar 15, 2013, 09:00 AM
tolazy2 is offline
Find More Posts by tolazy2
Joined Mar 2013
Did you ever complete your project. My board fried and want to try something new.
tolazy2 is offline Find More Posts by tolazy2
Old Mar 21, 2013, 08:52 AM
jmc67 is online now
Joined May 2005
I did. I changed the control board to the kk2.0, updated the motors and added lights. Had this setup for a while and was a blast. After that, I moved to the naza with a different frame.
Old Apr 19, 2013, 08:43 PM
shisso is offline
Find More Posts by shisso
Joined Mar 2013
If anyone needs parts for the MX400 I have them!
shisso is offline Find More Posts by shisso
Discussion Walkera UFO MX400 w/gps!! Hot_Wheels Multirotor Talk 387 May 18, 2014 04:47 AM
Discussion What All Do You Get With The Walkera UFO MX400? ChrisMohrSr Multirotor Talk 72 Nov 03, 2013 01:38 AM
Discussion Gau 330X-S VS Walkera MX400 (ufo) persja Multirotor Talk 2 May 06, 2012 04:11 PM
Discussion Walkera UFO mx400/ Devo 8 Atomiton Multirotor Talk 13 Apr 09, 2012 08:09 PM
