Check out Pete's Pilots on eBay. He's a great guy, a great seller and his pilots are very good. I've bought numerous pilots from him.
Tom |
Also wanted to ask if anyone knows where to get some 1/8 Vickers or Lewis guns? Jim |
Can vouch for the Pete's Pilots - example below to 1/8th scale.
Machine guns in same scale from here: http://wrightbrothersrc.com/products/wwi.htm |
While I have "The Blue Max" playing on the DVD player, I thought I would update the build. During the week I built the lower wings. They are about as simple as they come. I did make one big goof, I forgot to add the dihedral to the root rib when I glued it in. So I fixed that with a my sanding disc.
Yesterday I built one side of the fuse. Peter's plans call for the fuse to be built in two sections, front box and rear stringers. I decided to make them full sides and will glued the two sides together in one piece. The reason I decided to do this is because the bottom longeron has a very distinct curve in the first bay. I did not think I could duplicate this without it being attached to the front box. It should be fairly easy to attach the two sides together later as the top is flat from front to back. Hopefully what I am describing will be easier to understand int the pictures. Just reached that part in the movie where our dark hero meets Ursula Andress. She sure was a hottie in her day. Jim
More progress
I will be making the rudder from laminations. Jim |
Charlie,
I searched your web site but could not find Vint's propeller kits. I thought you were making them. Also, I have been reading your MS A1 thread this morning and was wondering where you got your paint from. I did some shopping yesterday for some silver paint chips and could not find any. I was planning on using silver latex paint. However, Krylon Metallic Nickel that I sprayed the cowl on my Camel looks like it may work. Jim |
| Thread Tools | |
| Question Balsa selection for Peter Rake 33" Nieuport | Platzian | Scale Electric Planes | 4 | May 07, 2012 08:48 PM |
| Build Log Peter Rake IPS Nieuport Mono | 65Chevelle | Scale Electric Planes | 139 | Feb 08, 2009 08:18 AM |
| Sold Tritle 40 WS Nieuport 17 kit | ZRS4 | Aircraft - Electric - Airplanes (FS/W) | 2 | Feb 01, 2009 02:49 PM |
| Build Log Nieuport IV for IPS (designed by Peter Rake) | BaZsiX | Scale Electric Planes | 56 | Jun 24, 2007 03:00 PM |
| Nieuport N11 "Bebe"-- a Peter Rake design | Zhack | Scale Electric Planes | 32 | Nov 05, 2003 05:21 AM |
