Old Jun 10, 2012, 11:20 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Riblets aren't for strength, only to better emulate the full scale.
portablevcb is offline Find More Posts by portablevcb
Old Jun 11, 2012, 12:33 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
And here I thought they were for barbecuing.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jun 11, 2012, 01:59 PM
RAFster is offline
Find More Posts by RAFster
United States, TN, Blountville
Joined Oct 2002
Bamboo skewers like used in barbequing can make a strong part with some shaping...provided they are long enough. They have a history of modeling use as well.
RAFster is offline Find More Posts by RAFster
Old Jun 11, 2012, 06:42 PM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Larry
I knew someone had to get a BBQing rib in there somewhere. Was just waiting.
The riblets are mainly just for show but a side effect is added strength to the LE. The LE has less open space to cover.
Jim
JIMA is offline Find More Posts by JIMA
Old Jun 11, 2012, 06:44 PM
JIMA is offline
JIMA's Avatar
Joined Jan 2003
On my Camel I used Bamboo skewers for the wing pegs. Did not have any 1/8 dowels. May do it again on the N17.
JIm
Old Jun 11, 2012, 07:04 PM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Looking good Jim,
Nice size, not too big or too small.
I will be following your build closely.
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Jun 11, 2012, 07:42 PM
Lnagel is offline
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Jim
You can always count on me to get in a rib or two.
While a stronger leading edge is an added benefit of riblets, they aren't just for show. Just as on the full size aircraft, the riblets reduce the sagging of the covering between the ribs on the wing's leading edge. This helps maintain the desired airfoil shape without the added weight of leading edge sheeting. Since the leading edge is probably the most critical part of the airfoil, this results in a more efficient wing both on the full size and the model.
Larry
Old Jun 11, 2012, 09:12 PM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Jim,
If you had ordered the Camel full kit you would have received a bamboo skewer to use in place of 1/8" dowels
charlie
Old Jun 12, 2012, 03:42 AM
PETERRAKE is online now
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Having had my wrist slapped for not taking up RAFster's comment about who would be building the Zeppelin I was drawing a line at, I suppose the answer to that should have been, 'You if you aren't careful.' Mind you, you'd need a heck of a big model room, but at least you could float it straight out through the window (or hole in the wall).
I can see it now, Jim dives his Nieuport towards the lumbering Zeppelin (making machine-gun sounds) and an electronic charge ignites the hydrogen. Most impressive, if a once only event.
Pete
PETERRAKE is online now Find More Posts by PETERRAKE
Old Jun 12, 2012, 03:19 PM
baldguy is online now
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Go ahead Pete, design a flyable Zepplin, I dare ya!
baldguy is online now Find More Posts by baldguy
Old Jun 12, 2012, 03:26 PM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Hey Pete. You could mess with these guys and design a Zep CS-1. Midkiff did one that flies really nicely as rubber FF.
Old Jun 12, 2012, 04:09 PM
I eat glue
Joined Jul 2006
Nope, wouldn't fall for that one Charlie, I already have the plans for that one!
Old Jun 12, 2012, 04:14 PM
Norfolk, England
Joined Sep 2001
I think I'll just keep my big mouth shut in future.
Old Jun 12, 2012, 04:16 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
There's also the Staaken...
James
Deuce is offline Find More Posts by Deuce
Old Jun 12, 2012, 04:23 PM
I eat glue
Joined Jul 2006
Aw come on, a Zepplin filled with helium and electric motors-real cool
Question Balsa selection for Peter Rake 33" Nieuport Platzian Scale Kit/Scratch Built 4 May 07, 2012 08:48 PM
Build Log Peter Rake IPS Nieuport Mono 65Chevelle Scale Kit/Scratch Built 139 Feb 08, 2009 08:18 AM
Sold Tritle 40 WS Nieuport 17 kit ZRS4 Aircraft - Electric - Airplanes (FS/W) 2 Feb 01, 2009 02:49 PM
Build Log Nieuport IV for IPS (designed by Peter Rake) BaZsiX Scale Kit/Scratch Built 56 Jun 24, 2007 03:00 PM
Nieuport N11 "Bebe"-- a Peter Rake design Zhack Scale Kit/Scratch Built 32 Nov 05, 2003 05:21 AM
