Old Jun 10, 2012, 11:25 AM
Physics_Dude is offline
Find More Posts by Physics_Dude
3D Printer Owner
Joined Mar 2012
Question
At what percent throttle does your quad hover?
A simple question for the quadcopter gurus out there. At approximately what percent throttle does your quadcopter like to hover at with a fresh battery?
Physics_Dude is offline Find More Posts by Physics_Dude
Old Jun 10, 2012, 11:27 AM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
50-60%
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Jun 10, 2012, 11:41 AM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Since I moved from single rotor to multi I used the same standard of around half throttle for hover.
I set my all quads up at a power>weigth ratio to get around half throttle hover. I do have a few quads that will hover at 1/4 throttle due to light weight and WAY more power than needed
shultz is offline Find More Posts by shultz
Old Jun 10, 2012, 11:48 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Roughly 50%. Which is weird since it hovers around 50% with 4S and 3S, even with batteries that weigh roughly the same. However, when you go full throttle 4S gives it a noticeable advantage.
WiseDuck is offline Find More Posts by WiseDuck
Old Jun 10, 2012, 12:22 PM
ApachePilot is offline
Find More Posts by ApachePilot
Father Francis, formerly Apach
Joined Oct 2006
Around 45%-50% here.....55% and up? out of sight.....soften down to 45% to descend and lessen to land. This is carrying a camera gimbal and gopro.
ApachePilot
ApachePilot is offline Find More Posts by ApachePilot
Old Jun 10, 2012, 12:31 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
not that simple. depends on your setup.
ive quads which hover at 50% but also 20% throttle...
warthox is offline Find More Posts by warthox
Old Jun 10, 2012, 12:34 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
about 50% when its carrying two 4s 5000 packs, an AV200 and a very light camera
Around 55-58% when I load it down with a canon T2i
Its a DW AD8HLE with 8 Avroto 2814's and APC 12x3.8 slow flyers.
not a light ship when loaded up with camera gear.
without the camera gear, its a rocket ship
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Jun 10, 2012, 02:51 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
with the setup i have now on my quad it hovers about 40%-45%.
i had a overpowered quad and it would jump from the ground at 15% and hovered at a notch from idle.. not funny to fly though....
dutchcommando is offline Find More Posts by dutchcommando
Old Jun 10, 2012, 09:57 PM
_SYCLONE_ is offline
Find More Posts by _SYCLONE_
Need for Speed ! ! !
United States, KY, Louisville
Joined Mar 2009
As soon as I arm my Hot setup quad it is almost bouncing off the ground
Think I need to prop down a little.
Will
_SYCLONE_ is offline Find More Posts by _SYCLONE_
Old Jun 10, 2012, 10:23 PM
fried onion is offline
Find More Posts by fried onion
Australia, NSW, Sydney
Joined Aug 2010
My quad is only slightly overpowered it hovers at about 30-40%
fried onion is offline Find More Posts by fried onion
Old Jan 11, 2014, 12:04 PM
ryckee is offline
Find More Posts by ryckee
Joined Jan 2014
i am bulding a hobbyking x-4 and if i keep my set-up i will get 72 % of throttle for hooving is it too much??
ryckee is offline Find More Posts by ryckee
Old Jan 11, 2014, 12:51 PM
dskoul is offline
Find More Posts by dskoul
Joined Oct 2013
I guess you are using ecalc, right?
change your current set up with bigger props (make sure they fit in your frame)
usually that helps.
dskoul is offline Find More Posts by dskoul
Old Jan 11, 2014, 01:05 PM
ecks is offline
Find More Posts by ecks
Knowledge prevents flyaways
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
I try as hard as I can to get the quad overpowered. My mini is roughly 30%
ecks is offline Find More Posts by ecks
Old Jan 11, 2014, 01:30 PM
ryckee is offline
Joined Jan 2014
yes i used ecalc and the 12 inch prop fit on the frame
Old Jan 11, 2014, 02:04 PM
ryckee is offline
Joined Jan 2014
i want a low kv for more stability,a non accrobatic flight
Question how much does your 450-600 quad weigh RTF? STANG KILLA SS Multirotor Talk 7 May 11, 2012 09:20 PM
Discussion WooKong M ----Hovers at 10% throttle--Why??? quadman Multirotor Talk 2 Mar 04, 2012 12:56 PM
Discussion Brushless ESC- So what does the throttle actually control/select? CNY_Dave Power Systems 28 Jan 30, 2012 09:22 AM
Question Calibrating Throttle on ESCs--One by One or All at the Same Time on a Quad? Dave8888 Multirotor Talk 2 Jan 29, 2012 08:16 PM
Percent throttle at hover rythmsekshun Micro Helis 2 Aug 14, 2003 11:47 AM
