Old Jun 10, 2012, 02:27 AM
bd5wingnut is offline
Find More Posts by bd5wingnut
bd5wingnut's Avatar
Austin, Texas
Joined Dec 2005
Best method to remove old EconoKote film?
Well, like the subject says, I am looking for the best way to remove some old Econokote from a skinned wing. I am pretty sure this film is the low temp variety.
I want to remove this stuff, it is old and saggy. I plan to glass the skins and need to get all the old stuff off. I started to just pull it back and the clear part of the film started to separate leaving the color stuck to the skin, so I tried briefly to apply heat but it did not seem to help.
Help.
Peace, Wolf
bd5wingnut is offline Find More Posts by bd5wingnut
Old Jun 11, 2012, 10:58 AM
jhaywood is offline
Find More Posts by jhaywood
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
Heat was the only way I could get it off of wood, and then it was hit or miss.
jhaywood is offline Find More Posts by jhaywood
Old Jun 11, 2012, 05:38 PM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I just finished doing this on an old ultra stick. Quite a bit of color was left behind even using heat. I tried wiping with acetone which DID remove more but it also imbeded some the color into the wood grain. Since I was recovering with ultracoat white, I couldnt have that. What I finally had to resort to was a heat gun and a blade. Heated up the color, then scraped lightly with a curved blade. Tedious but it got almost all of it off.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Jun 11, 2012, 06:49 PM
KrisM is offline
Find More Posts by KrisM
Site Moderator
KrisM's Avatar
Joined Oct 2011
Closing this one. Leaving this one open:
http://www.rcgroups.com/forums/showthread.php?t=1669030
KrisM is offline Find More Posts by KrisM
Question Best method to cut foam? dedStik Foamies (Scratchbuilt) 8 May 10, 2012 03:35 PM
Question Protecting paint job on a foam plane? Best methods? w1indse7 The Builders Workshop 8 Mar 13, 2012 05:46 PM
Discussion Best method to charge a 1600 NiMh flatpack? Riodiler1 Electric Sailplanes 5 Feb 29, 2012 09:46 AM
Discussion Best method for hooking up linear servos rcjim11 Indoor Pattern/F3P 7 Oct 22, 2011 12:39 PM
Discussion Best method... kerrycorcoran Foamies (Scratchbuilt) 17 Sep 30, 2011 04:14 PM
