Old Jun 09, 2012, 03:53 PM
WFLY 93705 is offline
Find More Posts by WFLY 93705
WFLY 93705's Avatar
United States, CA, Mendota
Joined May 2012
New Product
WFLY New 500 Size Electric Helicopter
Hello,everyone, Here is our latest new product from WFLY--Vortex 5 Large electric helicopter for most pilots who expected for a long time.
Here I want to share some of pictures and flying video for this helicopter which is quite different from other brand helicopters.
Let's look at the specification of Vortex 5
Length:810mm
Height:300mm
Main Rotor Length:425mm/430mm
Main Rotor Diameter:920mm
Tail Rotor Diameter:198mm
Motor Pinion Gear:16T/18T
Main Drive Gear:120T
Autorotation Tail Drive:80T
Tail Drive Gear:12T
Drive Gear Ratio:7.5:1:4.67/6.67:1:4.67
Max Rotor Head RPM: 2850
Weight:830G
Whole Weight:1750G
Recommend Electric Equipment
Gyro: high performance AVCS gyro.
ESC: 80A
Servo: 45-65G digital servo. the size (41.5mm*21mm*38mm)
Motor:3720size. 1100KV Note: 900KV-1300KV. Don't surpass 1300KV
Battery: 6 cells 22.2V 2800mAh 30C
Radio control system: WFT09SII/WFT09II /WFT07/WFT06II/WFT06X-A
Vortex 5 is available for electric system.
Simple and light weight design provides awesome flight performance and extreme 3D capability.
Vortex 5 adopted tail rotor belt drive system which make the helicopter more cheaper than shaft drive system and more easy for reparing.
Main Rotor head With thrust bearing on main rotor head Typical CCPM swashplate system
which easy for pilot to control the helicopter on flying when you are operating 3D flying with fast speed.
Frame Part:
Rigid carbon fiber frame design
Very easy for repairing when got unexpected crash!
Looking at the frame carefully. the size of servo mount tell you that standard servo are needed to drive directly.
Battery tray designed close to the rotor head makes it more easy to control gravity center of the helicopter.
Tail Rotor Head
Tail rotor head run with thrust bearing.
Rear tail servo mount been set on tail boom which makes it more convenient to adjust the linkage of tail servo, making tail drive rapidly
Here is the video for this helicopter
Thanks for watching
http://www.youtube.com/watch?feature...&v=lkk5fvXQ0kM
WFLY 93705 is offline Find More Posts by WFLY 93705
Old Jul 11, 2012, 01:22 AM View Post
whitebear7979
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Build Log WFLY New 500 Size Electric Helicopter WFLYRC Large Electric Helis 142 Feb 01, 2013 02:36 AM
Discussion A2pro Bell429 Scale Helicopter 500 size Bell429PilotTSV Electric Heli Talk 2 May 30, 2012 01:56 AM
Sold HK-T500 CCPM 3D EP 500 size Helicopter Kit moxjett Aircraft - Electric - Helis (FS/W) 2 Jan 18, 2012 07:31 PM
Sold Valuehobby 500 size helicopter kit ddierking Aircraft - Electric - Helis (FS/W) 3 Nov 24, 2011 12:12 PM
Discussion Super good deals on Proton ESC for 250, 450, 500 size rc helicopters hobbypartz XHeli 0 Oct 04, 2011 10:31 PM
