Old Feb 19, 2013, 03:16 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
28mm.
OK, for anyone wanting to go nuts: http://www.shapeways.com/model/93266...ade-rotor.html
For techo types - I gave it a high central angle of attack and declined it by 17.5 at the tip. I tapered the blade, swept it back and lifted the tip to centre it with the root of the blade. There are 5 supports in the hub to maintain balance of the rotor. Shaft hole is 1.497mm in diameter. It will only print in detail and ultra detail as the blades are approx. 0.5mm in thickness. I did make them thinner first design but decided to go thicker=stronger so upped the airfoil a tad. The airfoil itself is an undercam shape.
The cost sucks as Shapeways now charges a 5 dollar setup fee each item for this material, so the rotor itself only costs around 4 bucks.
NitroCharged is offline Find More Posts by NitroCharged
Old Feb 19, 2013, 04:10 PM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Uuuummmmmm,
Wondering what you've been up too. The $100.00 Bazooka and now this rotor. Okay, I'll bite. Have some of the Mig innrunners on hand. This might be just the ticket for staying 2S and getting a bit more from them. Will order two rotors and shrouds. Will test and post results.
Ksqm
ksqm is online now Find More Posts by ksqm
Old Feb 19, 2013, 04:41 PM
fluxnstuff is offline
Find More Posts by fluxnstuff
just go fly...
fluxnstuff's Avatar
United States, CA, Palo Alto
Joined Dec 2012
Originally Posted by ksqm View Post
Uuuummmmmm,
Ksqm
ditto, but using an outrunner.
fluxnstuff is offline Find More Posts by fluxnstuff
Old Feb 20, 2013, 07:47 AM
ksqm is online now
Joined Mar 2009
NC,
Quick question or two. What motor did you originally have in mind for this rotor? Also, did you have a particular shroud to mate up with it? I'm thinking this rotor will require a bit more torque than even the AEO rotors. Thinking the 10mm class inrunners may not be up to the task, without excessive amp draw. I have Ammo 12mm, SA 14mm, and AEO C05M. I'm leaning towards the Ammo 12mm, as it has the lowest kv and is actually suited for higher loads. The SA 14mm is second due mostly to OD. Would require modding a shroud. I've had the C05M (AEO 27mm) on 3S and it humps under 6a. But I think the 10 blader on 2S would be a handful for it. Just thinking out loud.
Ksqm
Old Feb 20, 2013, 09:49 AM
dwayne loveday is offline
Find More Posts by dwayne loveday
United States, TN, Decatur
Joined Dec 2005
This is a sickness. I love it. You are a force to be rekoned with Mr. Charged. Thank you brother! D.
dwayne loveday is offline Find More Posts by dwayne loveday
Old Feb 20, 2013, 03:10 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I do have a 12mm mount version at Shapeways available: http://www.shapeways.com/model/44714...mm-motors.html
Using a larger or stronger motor is obviously better. I'll be going the35mm edf skyangel outrunner wound slightly hotter so it kicks on 2 cell.
Old Feb 20, 2013, 04:39 PM
ksqm is online now
Joined Mar 2009
Correction to my last post. The 14mm inrunner is used in the ArtTect F-86, not the Sky Angel (SA). Out the box it's 3S, but guys are going 4S. It may be a wolf in sheeps clothing and should match up good.
Ksqm
Old Feb 20, 2013, 05:33 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
woooah, hang on - a 14mm inrunner?! Do you have a link for just the motor?
Old Feb 20, 2013, 05:40 PM
Joined Dec 2005
I have an older but hardly used medusa 12mm. I think the kv is 4400. 4 something. Is that too low for 3s. Im sure for 2s. I could make a 160 4s TP25c. IDK..
Old Feb 20, 2013, 06:20 PM
ksqm is online now
Joined Mar 2009
NC,
Ooooopppsss!!! Let the cat out da bag. Guess you figured a typo in the original post. No, this puppy is 14mm. Was thinking of lining one of the Art Tech shrouds with 1mm depron and having a go with it. Check out the Art Tech F-86 thread for link. On IPhone right now. Some good info. I was late to the party, but making up for it best I can. Chester2240 wised me up.
Ksqm
Old Feb 22, 2013, 03:16 PM
LowlyElevated is offline
Find More Posts by LowlyElevated
pǝʇɹǝʌuᴉ sɐʍ I ǝsnɐɔǝq
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
I gotta hear this new fan blade, it should be awesome!
LowlyElevated is offline Find More Posts by LowlyElevated
Old Feb 23, 2013, 04:40 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I just flew my MiG on 3S...What a HOOT!!!...I was using 180mAh NanoTech 25-40C batts...The power sure was nice with being able to go from level flight to a huge loop without having to gain speed before the manuever!!!...She pulled through the vertical with power alone...
The only complaint is that the flight time was reduced to about 1/2 of what I'm used to on 2S....
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Feb 23, 2013, 05:58 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Kevin
Yeah I get about 2:00 min on my 3S 180s. And Yes it is a complete blast to fly. It is not quite 1:1 but dang close. To me it is worth the motor/bearings needing to be replaced every 30-40 flights.
-Brian
kalmon is offline Find More Posts by kalmon
Old Feb 24, 2013, 12:42 AM
just go fly...
fluxnstuff's Avatar
Joined Dec 2012
just built a new MiG15 today, 90.7grams AUW, 83g average thrust for 2 mins on 2S. worth more in the air i suspect.
1:1 P:W for the peak thrust
.91 is the average P:W
ran six TP325 2S 65C's lipos back to back, no issue. she topped in a 63mph with plenty of 55mph passes (rcspeedo). 60mph+ is now a regular thing and i can feel 65 is just within reach. flying with no nose cap, saves 2grams and i have gotten decent enough to not nose it into the ground anymore.
Old Feb 24, 2013, 12:14 PM
Joined Mar 2007
-Brian
Without having to sift through tons of script---Can someone please provide a link where I can purchase the high RPM bearings???
The higher speeds are addictive and I'm thinking that I'll fly the MiG on 3S more 2S...Once you get that little taste.......
Kevin
Discussion UMX Carbon Cub SS Mod Thread MinneFlyer Micro Ready-to-Fly 995 Jul 03, 2016 02:00 PM
Discussion UMX Beast 3D BNF vs UMX Mig 15 EDF BNF which is best? Legendary_Agent Electric Plane Talk 109 Aug 15, 2015 03:39 AM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Build Log Micro MIG 15 Mod -> Silent Seagull EDF Johannez Electric Ducted Fan Jet Talk 104 Dec 02, 2013 08:24 AM
