Old Jun 13, 2012, 12:30 PM
TBone08 is offline
Find More Posts by TBone08
AirSurfer
TBone08's Avatar
United States, VA, Arlington
Joined Sep 2011
I called Vess and asked their input about which prop for 3d, they told me 23b (to my surprise).
when asked about the 23a as it haas a lower pitch for hovering etc, they said 23b will do 3d just fine but it won't rip the engine as much as the 23a - in regular flight.
your thoughts ? I know some of you guys said you tried both ?
TBone08 is offline Find More Posts by TBone08
Old Jun 13, 2012, 01:52 PM
rjstrickjr is offline
Find More Posts by rjstrickjr
rjstrickjr's Avatar
United States, NC, Faison
Joined Jan 2011
I use a 23B on my DLE 55. 3D is no problem and sport flying with wicked snap rolls is also fun. 23B for me.
rjstrickjr is offline Find More Posts by rjstrickjr
Old Jun 13, 2012, 02:01 PM
thedeuce is offline
Find More Posts by thedeuce
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
I have quite a few flights on mine with both the 23A and B, is anyone changing the high speed carb settings with changes in the props?
thedeuce is offline Find More Posts by thedeuce
Old Jun 14, 2012, 08:37 AM
barracudahockey is offline
Find More Posts by barracudahockey
Multi-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
I'm telling y'all, try a Falcon carbon 23x9
barracudahockey is offline Find More Posts by barracudahockey
Old Jun 14, 2012, 11:44 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
barracudahockey, did you try the vess too ? how's the prop with regard to ripping and regular flight ?
Old Jun 14, 2012, 08:11 PM
Joined Sep 2004
I've tried quite a few
It simply doesn't rip. It has excellent pull, and is lighter so it spins up quickly which is useful on pull outs.
Old Jun 18, 2012, 11:11 AM
rica1 is offline
Find More Posts by rica1
United States, CA, Chula Vista
Joined Apr 2005
TBone08, the Zinger Pro is not going to give you the RPM's that the Vess or a Xoar prop will, before or after break in. If your eng is new, use a recommended smaller prop (22x8, Vess 23A probably) and follow the break in procedures to get enough time on the eng before going to a bigger prop and heavier load for 3D. Maybe look for a break in thread on the DLE 55. Good luck and have fun.
rica1 is offline Find More Posts by rica1
Last edited by rica1; Jun 18, 2012 at 11:13 AM. Reason: earlier response toTBone08
Old Jun 18, 2012, 12:54 PM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
I agree with rica1, breakin is important for all motors, but with gassers, use a prop you want to use most of the time as gassers are not like nitro's, and don't run for too long on the ground, fly it to break it in but for a few tanks don't full throttle it into vertical as it adds to much load on it.. Min 2 gallons for breakin. Also buy a NGK CM-6 for the plug and chuck the original. I never touched the carb settings for my breakin. The settings for the factory are good. Just make sure you runa good oil for the mix and look at the manufacturers specs for the oil/fuel mix. Just my experience.
Old Jun 18, 2012, 09:12 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
it's a 4 yr. old dle55.
Old Jun 19, 2012, 10:12 AM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Disregard
Old Jun 19, 2012, 11:13 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
thedeuce, thanks for the input though !
Old Sep 21, 2012, 06:21 PM
jcleland is offline
Find More Posts by jcleland
Joined Dec 2011
I know this thread is a little bit old, but I recently moved from a Xoar 23x8 to a Mejzlik 23x10 because of ripping. I was back on the needles today (engine is a DLE-55 with about 5 gallons through it, carefully broken in) and I could NOT get anything better than about 6600RPM. Is/has anyone else run this prop on a DLE-55 and gotten better RPM? It idles well, transition is smooth, but this just seems really low. I was expecting close to 7000 or at least 6800.
jcleland is offline Find More Posts by jcleland
Sold Aeroworks Rx Ready 50cc Yak 54 W/ DA 50,& Tuned Pipe, Awsome Power! gllucero Aircraft - Fuel - Airplanes (FS/W) 1 May 20, 2012 10:52 PM
Sold Aeroworks Yak 54 50cc Pipatone Aircraft - Fuel - Airplanes (FS/W) 2 Nov 08, 2011 08:13 AM
Sold Quique 50cc Yak 54 86" ARF, Brio scheme wfield0455 Aircraft - Fuel - Airplanes (FS/W) 3 Sep 14, 2011 07:18 AM
Discussion vendo yak 54 hangar 9 50cc. yak 54 quique aircraft 101" Ravelero Mexico 2 Jan 04, 2011 08:14 PM
Wanted 50cc H9 Carden Yak or 50cc AW Extra KenCz Aircraft - Fuel - Airplanes (FS/W) 2 Nov 19, 2010 11:11 PM
